I would like the password as well!
Thank you
Thank you
can i use rock 5a ?
Yeah @mo123 when an android image for the Rock 5A? Folks at discord are asking
Hey Bro. I Downloaded NVME Firmware . Need the password please~
Are there any Updates for native Amazon & Netflix support in sight?
Again, thank you for your work
@localhost
For Netflix you can try OpenFydeOS or Batocera Linux then you should have 1080p Netflix.
Unfortunately Netflix will never grant a license to a STB manufacturer since they require a locked bootloader meaning no booting of custom Android or Linux OSβs.
The Amazon mobile app works and through Chrome browser.
@shy
There are several bugs Radxa needs to fix for Rock5A first.
@mo123 Hi, I am using a third-party rtl8852be, wifi works for me but not Bluetooth. Any idea how should I fix it? Thanks a lot.
Hello! @mo123 New Rock 5b Board owner here, going to test out the NVME version of the image w/ the A8 module. Would appreciate the password =D
@Richard_H Can you run lspci on Linux to identify the bluetooth of the rtl8852be?
Hello, I need instructions on how to flash Root Magisk.
rock@rock-5b:~$ lspci
0002:20:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 3588 (r
ev 01)
0002:21:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
0004:40:00.0 PCI bridge: Fuzhou Rockchip Electronics Co., Ltd Device 3588 (r
ev 01)
0004:41:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.
5GbE Controller (rev 05)
rock@rock-5b:~$ lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0bda:4853 Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 003: ID 0406:2814 Fujitsu-ICL Computers 2.4G Composite Devic
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Sorry for the late reply.
any plans to bring to 5a?
@kinjo
Yes, there are just lots of things missing or broken for 5A so waiting for Radxa to fix it.
Thanks, letβs see what sort of fixes radxa can implement.
Hi! I would really like to try this build! Could you please send me the password as well? Thank you
how do you make it boot?
I flashed it to EMMC and I have no HDMI signal, the light is solid green when I plug it in, it never flashes or blink just stays olid green and I have no video output at all
I trued short and long pressing the buttons and nothing, no HDMI signal from either ports, what am I doing wrong?
@anthony_rossetti
Check your HDMI cable and try with a different power adapter.
Do you use the correct flash tools?
AndroidTool v2.96 or higher if flashing the update.img to emmc.
SDDiskTool v1.72 with only SDBoot option selected if flashing the update.img to a micro-sd card.
Etcher v1.18.11 is flashing the gpt.img to emmc or a micro-sd card.
Hello, would you share the password? thanks
Rock5A Firmware has been uploaded.
Enjoy.
