is the google tv GPT version ok for nvme boot? Or do I have to use atv version? Thanks and sorry for my bad english, I’m italian
[ROM] ROCK 5B Android 12.1 rkr10 GoogleTV
I’m not able to wake the device up from suspension. Power and reset buttons do not work. HDMI CEC is also to no avail. Is there anything I should do? Also the image does not seem to be rooted. The power off app says it needs root.
Also, is there a reason why I can’t change my home launcher? When I try to do it in Seetings->Advanced->Home Launcher it doesn’t update.
Is the board’s blue light flashing, solid, or not on?
It is in that case. When the board is turned off I just get the green LED. Waking up sometimes works on some bluetooth controllers. Some controllers work to wake it some don’t.
I’ll be testing the ATV image now since I got it to work which it wasn’t before a full EMMC wipe.
Update: HDMI control is still not working in the ATV image on an EMMC.
Hi to all, I run the ATV version and works very nice except Amazon Prime Video that give error every time I try to watch something. How can I fix it ? Thanks
Hey guys. I just installed ATV version and wifi/bt doesnt work with Radxa Wireless module A8 (Realtek RTL8852BE chip). What wifi card do you use with that build?
I successfullly got the image to flash to my EMMC but I have no signal, HDMI is not outputing anyhting , the light is solid green the buttons do nothing whe short of long pressed, how do I make it boot?
the fan is not spining either, the board does nothing but light the LED solid green it gos solid green the second it gets poer and does not blink at al what does that mena and where can I even find a chart of LED codes for this board?
@thc013 This is a patch to support the normal operation of Intel WiFi on Android12. It only debugs the WiFi part of Intel AX210 and Intel 7265, and does not include Bluetooth.
https://mega.nz/folder/2YlGkZgZ#46aBh6R9Nqmnqfc1h2EjWw
Is it possible to install this firmware into H96 Max V58? I been trying to find a solution for ages now.
Can someone confirm if this latest firmware fixes green screen in hevc.
How did you do that?
I pluged it into Windows 8.1 and it gets detected as unknown device, where do I get drivers, it doensn’t show up in windows explorer or disk management.
Same for me, used rkdevtool from windows, rk3588_spl_loader_v1.08.111.bin as loader, image flashed fine. It kept rebooting after that, then I also flashed “minimal_update.img” with rkdevtool upgrade firmware tab. All went successfull. It now hangs on the RockChip logo.
@liuxian @thc013 thank you. Has this patch been applied to latest build if not could you share instructions how to apply?
Hey! I’m facing same issue? Did you solve it?
Hi, I just flashed the GPT version to an sd card. When try to boot, it’s stuck in a boot loop. Any suggestions?
Thanks!
