You need a button between 16PIN and 3.3V.
Press the button to connect 3.3V, or ground.
I tried to make ota package from AOSP(version:20200522_1559,commit 2f865d49c2f9da2429fa0b77a34ea668d19a6ab2).
But failed. Iād like to fix it. Is there information this issue?
Make sure you use stock /bootable/recovery and not the twrp /bootable/recovery currently used.
Look on Gitlab rk-vendor for the stock recovery and replace it in your SDK if you want to build ota packages.
Use this, download as tar.gz and replace.
Hi. I also wanted to do OTA package, and replaced twrp ābootable/recoveryā folder to stock from this gitlab link, but make gives a lot of errors. Output uploaded here: https://pastebin.com/1Cjzjw4R
You have to delete the out folder or do make installclean and try again.
Also copy the commit_id.xml from the .manifest folder to your root sdk folder and make it read-only.
If you make changes to the SDK and donāt commit the changes with git, the commit_id.xml file will be empty and cause that error.
Thanks for your help. make is done, but make otapackage is fail.
build/core> git diff
diff --git a/tools/releasetools/common.py b/tools/releasetools/common.py
index 74b7b3e..d4ce24f 100755
--- a/tools/releasetools/common.py
+++ b/tools/releasetools/common.py
@@ -237,11 +237,11 @@ def LoadInfoDict(input_file, input_dir=None):
system_root_image = d.get("system_root_image", None) == "true"
if d.get("no_recovery", None) != "true":
- recovery_fstab_path = "RECOVERY/RAMDISK/etc/recovery.fstab"
+ recovery_fstab_path = "RECOVERY/RAMDISK/etc/recovery.emmc.fstab"
d["fstab"] = LoadRecoveryFSTab(read_helper, d["fstab_version"],
recovery_fstab_path, system_root_image)
elif d.get("recovery_as_boot", None) == "true":
- recovery_fstab_path = "BOOT/RAMDISK/etc/recovery.fstab"
+ recovery_fstab_path = "BOOT/RAMDISK/etc/recovery.emmc.fstab"
else:
I tired this Android Version and the new Android 10, still having problems with my HP EX900 1TB M.2 NVMe Every time I try to connect to the internet with WIFI or cable the rockpi crashes.
Check your power supply first. What power adapter are you using?
Can you please give your email or other contact. I will write you and ask some question about nvme) I want to install Android on nvme but i met some troubles with this.
Iām new one in AOSP. Any one help me to install MT6739WA device. Which os i can build and how can i do it.
@Anand_G Spam somewhere else.
Go read topics on xda forum about how to build Android OS.
Hi, PPPoE Ethernet in Android 9 (login & pass) - how to enable?
ROCK Pi 4B+ (Android 9 HDMI 4K)
No PPPoE option in Ethernet settings. Only DHCP & Static.
Although in /etc/ppp/ are PPPoE files.
How do I connect to the network?
Make a patch PPPoE AOSP for TWRP.
Android 9 (HDMI 4K), rockpi-4b-rk3399-android9-20200827_1006_94736e8-gpt
Reset RGB 8-bit after rebooting.
Where configuration files are stored?
There used to be here: sys/class/display/HDMI/color
echo mode=1 > sys/class/display/HDMI/color
What to apply the init.d script for TUNER āCOLORā after rebooting?
