Please repo sync and run build-rockpi-4c.sh to rebuild your rom.
Is it really need? I have installed Magisk and patched the boot. It works fine without this changes.
Thank you! I will try it!
I don’t think you need it for Magisk to work, but better to add it if you do lots of development work or use root a lot.
@Lili
Hi, can you also post the instructions to build separate images eg. u-boot, kernel, system?
Yes, Look again at README.
New Version Release.
Supprot USB boot Android10!!!
Thank you for your work! ![]()
I try to execute Full OTAUpdate on Android10(version 1.0.2) created from mkimage.sh ota.
But failed.
I changed RockPi4C.mk and retry. This is successed.
Blockquote
ro.product.property_source_order=product_services
ro.product.product_services.brand=rockchip
- ro.product.product_services.device=rk3399_Android10
+ ro.product.product_services.device=RockPi4C
ro.product.product_services.manufacturer=rockchip
- ro.product.product_services.model=rk3399-Android10
- ro.product.product_services.name=rk3399_Android10
+ ro.product.product_services.model=RockPi4C-RK3399
+ ro.product.product_services.name=RockPi4C
Is ro.product.product_services correct?
If you don’t want to use GMS, you can remove these configurations altogether.
Thank you for the reply!
How about builds for ROCK960?
Hello,How to keep HDMI rotation setting after reboot, please?
I tried to do below.
TunerSettings -> HDMI -> rotation -> set rotation.
persist.sys.hwrotation value is set but after reboot not turned.
HI Lili, Any good news for the Andriod box .
Wait for Rockpi4 firmware to stabilize and then directly adapt.
Android 10 not support.
No, It is very difficult.
@Lili
I can’t get gpt.img to boot from high speed micro-sd, same problem that was on Android 9 but was fixed.I updated to latest Android 10 sdk code already.
The recovery screen, firmware erasing only shows about 2 seconds then it just gets stuck on the bootanimation.
If I use update.img on emmc then the recovery screen, erasing firmware takes a lot longer and firmware boots correctly.
Is there still a bug with micro-sd booting?
I will try with other micro-sd cards too and reformat and test more.
DSI display support:
Can I use DSI displays (such as the official 7 inch Raspberry display) with this?
If so, could you please point me to some instructions on how to do so?
