No, itâs vendor, oem and system combined.
Try creating rockdev then run ./mkimage.sh
Then in the rockdev folder rename the RockPi4B to Image and copy to RKTools/Linux/RK_Pack_Firmware and run mkupdate_rk3399.sh in this folder.
Yes that is right.
I forgot when you run the included script that it doesnât save the commands for manual try later.
source build/envsetup.sh then
lunch RockPi4C-userdebug or lunch and select it from the list.
So, I have big issue with ROM.
I added gapps and gps.default.so library in /vendor/lib64/hw folder.
I built ROM with command ./build-rockpi-4c.sh and had the first issue.
I made this steps and got the update.img
Out folder contains all standart library and my gps.default.so file.
I flash my ROM and go to /vendor/lib64/hw folder. This folder contains libraries and HIDL services, but almost all have size 0. Gapps are work fine.
Why is it happened? Nothing to work!
I executed this script. but created image was uncomplete.
âdevice/rockchip/rk3399/RockPi4C/parameter.txtâ donât have system,vendor partition.
May I need to recreate parameter.txt?
@Lili
Hope you can get gpt images to build too.
Also SDDiskTool v1.62 if you use SD Boot on RKFirmware images to burn firmware to a micro-sd card, it boots to recovery and doesnât load Android.
I added with PRODUCT_COPY_FILES in RockPi4C.mk file, but it doesnât matter, the standart library is empty too! Why? They have size in out folder, but size is ZERO in ROM.
davemf@i7-8700-64gb-ram:~/ROCK_Pi4c$ ./mkimage.sh
device/rockchip/common/device.mk:868: warning: Please set client id with your own MADA ID!
TARGET_PRODUCT=RockPi4C
TARGET_BASE_PARAMETER_IMAGE==
HIGH_RELIABLE_RECOVERY_OTA=false
BOARD_AVB_ENABLE=false
system filesysystem is ext4
create dtbo.img....
done.
create boot.img....
BOARD_AVB_ENABLE is false, make boot.img from kernel.
done.
create recovery.img....
BOARD_AVB_ENABLE is false, make recovery.img from kernel && out.
done.
create system.img.... BOARD_AVB_ENABLE is false, make system.img from out.
in=/home/davemf/ROCK_Pi4c/out/target/product/RockPi4C/system.img out=/home/davemf/ROCK_Pi4c/out/target/product/RockPi4C/system.img.out align=1024
Total of 297916 4096-byte output blocks in 14 input chunks.
Generating optimized sparse image done,total_chunk=12.
done.
create vbmeta.img.... BOARD_AVB_ENABLE is false,use default vbmeta.imgdone.create vendor.img...BOARD_AVB_ENABLE is false, make vendor.img from out.
in=/home/davemf/ROCK_Pi4c/out/target/product/RockPi4C/vendor.img out=/home/davemf/ROCK_Pi4c/out/target/product/RockPi4C/vendor.img.out align=1024
Total of 64623 4096-byte output blocks in 6 input chunks.
Generating optimized sparse image done,total_chunk=4.
done.create odm.img...BOARD_AVB_ENABLE is false, make odm.img from out.
in=/home/davemf/ROCK_Pi4c/out/target/product/RockPi4C/odm.img out=/home/davemf/ROCK_Pi4c/out/target/product/RockPi4C/odm.img.out align=1024
Total of 1175 4096-byte output blocks in 2 input chunks.
Generating optimized sparse image done,total_chunk=2.
done.
copy super.img...
create misc.img.... done.
create uboot.img...done.
create trust.img...done.
create loader...done.
create resource.img...done.
create kernel.img...done.
create config.cfg...done.
create parameter...done.
@mo123 Do you have zero library size in /vendor/lib64/hw folder?
Yes, it is need, but if you add this changes your board never boot, if shows bootanimation only. Because gps.default.so file is empty and hidl service cannot start it again and again.
My question is: Why ROM has empty library files?
