jay_wu
August 20, 2021, 9:22am
1
We have bought the RockpiN10 to do some research.
But it hit some problem when downloading the source code from repo command
According to
https://wiki.radxa.com/RockpiN10/Android8
radxa$ repo init -u https://github.com/radxa/manifests.git -b rk3399pro-android-8.1 -m rk3399pro-rk-vendor-release.xml
radxa$ repo sync -d --no-tags -j4
The related git repository on github is not available.
RKDocs-android:
remote: Repository not found.
fatal: repository 'https://github.com/rockchip-toybrick/RKDocs-android/' not found
error: Cannot fetch RKDocs-android from https://github.com/rockchip-toybrick/RKDocs-android
There are much more git projects in the manifest.xml are missing in rockchip-toybrick · GitHub
Does Radxa provide the whole source code tar file?
Thanks
jack
August 20, 2021, 10:41am
2
RKDocs-android is documents repo, it’s not important. Just comment it and try again.
jay_wu
August 22, 2021, 2:11am
3
But there are still bunch of github repositories may not exist any more.
<remote fetch="https://github.com/rockchip-toybrick/" name="origin" review="https://android-review.googlesource.com/"/>
<project name="RKDocs-android" path="RKDocs/android" remote="origin" revision="2becde975e0b535236a41e4b88979f5d29ec07ca" upstream="master"/>
<project name="RKDocs-common" path="RKDocs/common" remote="origin" revision="ba6f960caf9e66d77794b15cbdc7a5aa6bf5e1e6" upstream="master"/>
<project name="RKDocs-rk3399pro" path="RKDocs/rk3399pro" remote="origin" revision="3d34658c9c8f8c9eb2a0f58f413f88e500c1762f" upstream="master"/>
<project name="RKNPUTool" path="RKNPUTools" remote="origin" revision="5ccbe26c8063273f51ef93b4e0d26e0f2718e936" upstream="master"/>
<project name="RKTools" remote="origin" revision="b0c8a69ce401577ef2fe988bb299f47b2b4b22ca" upstream="master"/>
<project groups="pdk" name="bionic" remote="origin" revision="f8822112d3f3062028c24dd8a7bea48259412d39" upstream="master"/>
<project groups="pdk" name="bootable-recovery" path="bootable/recovery" remote="origin" revision="82f5596d3277f016823a9c13b40e0ee9e6768b67" upstream="master"/>
<project groups="pdk" name="build-make" path="build/make" remote="origin" revision="d491bbb54f15dcf2aed144b9c05b8ec273868eb1" upstream="master">
<project groups="pdk,tradefed" name="build-soong" path="build/soong" remote="origin" revision="aefe1a6ed840bd8c1ef7a12a3406b98645ead08e" upstream="master">
<project name="device-rockchip-common" path="device/rockchip/common" remote="origin" revision="edc2f966ab24e22ab386d11b7a289c194d4b2edd" upstream="master">
<project name="device-rockchip-rk3399pro" path="device/rockchip/rk3399pro" remote="origin" revision="43666a6618a82f6bf9d7a4a2123c6ff9d4910f44" upstream="master">
<project name="external-abc" path="external/abc" remote="origin" revision="7b8d432bb7451427d4ea4a06ca301e78dca20214" upstream="master"/>
<project groups="pdk" name="external-avb" path="external/avb" remote="origin" revision="bfdbd311dc69e5c3184b0bb136cd929a64eb8893" upstream="master"/>
<project name="external-io" path="external/io" remote="origin" revision="ce23c82ae301239f8500e91a0008faa06db15147" upstream="master"/>
<project name="external-iperf" path="external/iperf" remote="origin" revision="2879774647ed7083f88735cd430222afbf29b016" upstream="master"/>
<project groups="pdk" name="external-libdrm" path="external/libdrm" remote="origin" revision="c6c4756adfc4f6fc1b88ee5268da3f3ca1eaa5ce" upstream="master"/>
<project groups="pdk" name="external-libusb-compat" path="external/libusb-compat" remote="origin" revision="84a04919b7bd62a5945df55c05662ed47aa5bdaf" upstream="master"/>
<project name="external-ntfs-3g" path="external/ntfs-3g" remote="origin" revision="26216247ade4637ab2bd812ffa0372b5276efb77" upstream="master"/>
<project groups="pdk" name="external-ppp" path="external/ppp" remote="origin" revision="4845f78dcebbb221727166ccfa770e3592d5c1a9" upstream="master"/>
<project groups="pdk" name="external-rk-pcba-test" path="external/rk-pcba-test" remote="origin" revision="a9c756be76b7559c7933d52848966d62348ca251" upstream="master"/>
<project name="external-rk_tee_user" path="external/rk_tee_user" remote="origin" revision="e1aa9109bdfa53ee0e331eea07ee8ad360d97706" upstream="master"/>
<project groups="pdk,qcom_msm8x26" name="external-skia" path="external/skia" remote="origin" revision="c2a5ea562aa8e469225a79edffb01c3c90698875" upstream="master"/>
<project groups="pdk" name="external-tinyalsa" path="external/tinyalsa" remote="origin" revision="8b757f9c51ab4c3712f934b298162f35b2a160ac" upstream="master"/>
<project name="external-usb_modeswitch" path="external/usb_modeswitch" remote="origin" revision="61288cec5f63186f73cc0e3f2c3948dbd2693214" upstream="master"/>
<project groups="pdk" name="external-wpa_supplicant_8" path="external/wpa_supplicant_8" remote="origin" revision="ef7578e4af8dfa79bbe871025b46fbb04b3afdc7" upstream="master"/>
<project groups="pdk" name="frameworks-av" path="frameworks/av" remote="origin" revision="19fa0e8dd9c231f98f81d95501712ec82ea787cc" upstream="master"/>
<project name="frameworks-base" path="frameworks/base" remote="origin" revision="b1828831120f4938a224703b25e649daa18c749f" upstream="master"/>
<project groups="pdk-cw-fs,pdk-fs" name="frameworks-ex" path="frameworks/ex" remote="origin" revision="33ccc61d9ef90b0d6b426e3b6fba29c7393c1709" upstream="master"/>
<project groups="pdk" name="frameworks-ml" path="frameworks/ml" remote="origin" revision="5b9cded3a364389955a62777d0d95ac3485220b0" upstream="master"/>
<project groups="pdk" name="frameworks-native" path="frameworks/native" remote="origin" revision="e4d587f717a3254d5929559d67a1109fdf0d2204" upstream="master"/>
<project groups="pdk-fs" name="frameworks-opt-net-ethernet" path="frameworks/opt/net/ethernet" remote="origin" revision="70f267ce2df126b69cbbea23529d76b114ff4d1b" upstream="master"/>
<project groups="pdk-fs" name="frameworks-opt-net-pppoe" path="frameworks/opt/net/pppoe" remote="origin" revision="c06ee5486eb46f9dc337ef200cf042840d946cf6" upstream="master"/>
<project name="frameworks-opt-net-wifi" path="frameworks/opt/net/wifi" remote="origin" revision="3d4358bbd3df3dc56159cb1e6c53a22ef5ed7c0e" upstream="master"/>
<project groups="pdk" name="frameworks-opt-telephony" path="frameworks/opt/telephony" remote="origin" revision="f1746d15639220d86756b786b2b7b60330c75082" upstream="master"/>
<project groups="pdk" name="hardware-broadcom-libbt" path="hardware/broadcom/libbt" remote="origin" revision="29bf60b09c29ffafaaa1ec395f5d1df93c60c681" upstream="master"/>
<project groups="pdk,broadcom_wlan" name="hardware-broadcom-wlan" path="hardware/broadcom/wlan" remote="origin" revision="3581b0ee5d8f7a9a0452b63cc5d5a0d3697a4beb" upstream="master"/>
<project groups="pdk" name="hardware-interfaces" path="hardware/interfaces" remote="origin" revision="359d9afb0ba9790bff948c1f9b743f859236a343" upstream="master"/>
<project groups="pdk" name="hardware-libhardware" path="hardware/libhardware" remote="origin" revision="f1c81230c76dcc18d7d9e824b941d444919ed0b8" upstream="master"/>
<project name="hardware-realtek" path="hardware/realtek" remote="origin" revision="b4c44d81a94ff1c4bf8d04d5016dc484dc77ee29" upstream="master"/>
<project name="hardware-ril" path="hardware/ril" remote="origin" revision="408d27b7ee63d216351a2d0c226a478cdd44300f" upstream="master"/>
<project name="hardware-rockchip-audio" path="hardware/rockchip/audio" remote="origin" revision="e3836a528250d57b4f128869fc70e50fae2201b6" upstream="master"/>
<project name="hardware-rockchip-camera" path="hardware/rockchip/camera" remote="origin" revision="6479534032319a35cb32a46bb1549b2a281addb7" upstream="master"/>
<project name="hardware-rockchip-drmservice" path="hardware/rockchip/drmservice" remote="origin" revision="a8f7927d99facc0d0eb2f984773c58c97a7fd85d" upstream="master"/>
<project name="hardware-rockchip-hwcomposer" path="hardware/rockchip/hwcomposer" remote="origin" revision="60f7d99defa6dd9a9b614c82bedabef34b1d9c1d" upstream="master"/>
<project name="hardware-rockchip-jpeghw" path="hardware/rockchip/jpeghw" remote="origin" revision="72b3537df45b9f20c93c9c1031aaaa73733924a2" upstream="master"/>
<project name="hardware-rockchip-libdirect-texture" path="hardware/rockchip/libdirect-texture" remote="origin" revision="b0b6b3560ca0ab483a95ad32c6e6e77dfcbf6255" upstream="master"/>
<project name="hardware-rockchip-libgralloc" path="hardware/rockchip/libgralloc" remote="origin" revision="36ac519806b753f025d14827295769b713fad2a2" upstream="master"/>
<project name="hardware-rockchip-libiep" path="hardware/rockchip/libiep" remote="origin" revision="1c2f90b56f46ba183c7707947ce4d80232b3317a" upstream="master"/>
<project name="hardware-rockchip-liblights" path="hardware/rockchip/liblights" remote="origin" revision="b29a973a3a6562c6733f67dbbd64c43c18079fb4" upstream="master"/>
<project name="hardware-rockchip-librga" path="hardware/rockchip/librga" remote="origin" revision="76cfbd3a004cce12540543b2aaa2bec8dba3225a" upstream="master"/>
<project name="hardware-rockchip-librkvpu" path="hardware/rockchip/librkvpu" remote="origin" revision="4c9cc509456cdef94cda50a1a4713c80dd227b4a" upstream="master"/>
<project name="hardware-rockchip-npu_powerctrl" path="hardware/rockchip/npu_powerctrl" remote="origin" revision="373c5511dee05379340305b4fa36618e206cbd69" upstream="master"/>
<project name="hardware-rockchip-npu_transfer" path="hardware/rockchip/npu_transfer" remote="origin" revision="3959d56d2bc2cc2a05d5591a5bea864b320fbdb9" upstream="master"/>
<project name="hardware-rockchip-omx_il" path="hardware/rockchip/omx_il" remote="origin" revision="23c87d6e03ddcd15d8b80681f201308ad484c8bb" upstream="master"/>
<project name="hardware-rockchip-power" path="hardware/rockchip/power" remote="origin" revision="1a59ac7bba593cd69ed394a1730989975fa5d958" upstream="master"/>
<project name="hardware-rockchip-sensor" path="hardware/rockchip/sensor" remote="origin" revision="fff7a59402643bd803239cc4d0212c0dd09a2c00" upstream="master"/>
<project name="hardware-rockchip-upgrade_tool" path="hardware/rockchip/upgrade_tool" remote="origin" revision="7fc46ddb0079b5b7454938d959a3271c5b3c461f" upstream="master"/>
<project name="kernel" remote="origin" revision="ef202254ab92f5920d24ff091bf6059b8c781311" upstream="stable"/>
<project groups="pdk-cw-fs,pdk-fs" name="packages-apps-Bluetooth" path="packages/apps/Bluetooth" remote="origin" revision="ee5813ffb2d7aaca1baec799882f4e737055f6ed" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Browser2" path="packages/apps/Browser2" remote="origin" revision="08e5514f97c94d674de472aeeed6f52bf66d4ab4" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Camera2" path="packages/apps/Camera2" remote="origin" revision="6ffeaab828e6ac1ef661f0bf4b41644b822f2ad8" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Contacts" path="packages/apps/Contacts" remote="origin" revision="51d9dc3e80626b06cb565e30ad1a96a437b414cf" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-DeskClock" path="packages/apps/DeskClock" remote="origin" revision="7318b2bc09cfe5e48ece26e49da70c5dbbc012af" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-ExactCalculator" path="packages/apps/ExactCalculator" remote="origin" revision="ed7f0a04cdddb27cbb1665f63f3c7a2d693ca70b" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Gallery2" path="packages/apps/Gallery2" remote="origin" revision="e2b8fd33181133030f479184aad39cc90d9c0b77" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Launcher3" path="packages/apps/Launcher3" remote="origin" revision="0e5fcd4af3dad8e3dcdc40fe70296cc1b5f3e98d" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Music" path="packages/apps/Music" remote="origin" revision="025d4f4e4302d1e842e78ab99b7601d5bf356fc5" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-Settings" path="packages/apps/Settings" remote="origin" revision="a2f25ef657644dcf8d24ebeac5ca895111d3de1b" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-SoundRecorder" path="packages/apps/SoundRecorder" remote="origin" revision="673c9be3226f858bf96813e45fd816c921cca0d6" upstream="master"/>
<project groups="pdk-fs" name="packages-apps-WallpaperPicker" path="packages/apps/WallpaperPicker" remote="origin" revision="d3d5a41679d6c8b1e95148f0551c5ea8394fa8aa" upstream="master"/>
<project groups="pdk-fs" name="packages-inputmethods-LatinIME" path="packages/inputmethods/LatinIME" remote="origin" revision="53d1623afd47601d166bd8bb9f6fc52111755cde" upstream="master"/>
<project groups="pdk-cw-fs,pdk-fs" name="packages-providers-MediaProvider" path="packages/providers/MediaProvider" remote="origin" revision="2db41e549877e0877074cbda792a8f307340245a" upstream="master"/>
<project groups="pdk-fs" name="packages-screensavers-PhotoTable" path="packages/screensavers/PhotoTable" remote="origin" revision="e2272378a98eefc7f2f1cf77321b5838f455ead6" upstream="master"/>
<project groups="pdk-cw-fs,pdk-fs" name="packages-services-Telephony" path="packages/services/Telephony" remote="origin" revision="d407e46f53799a8b765bd164a534d10061ec1eff" upstream="master"/>
<project name="prebuilts-gcc-linux-x86-aarch64-gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu" path="prebuilts/gcc/linux-x86/aarch64/gcc-linaro-6.3.1-2017.05-x86_64_aarch64-linux-gnu" remote="origin" revision="f96f76d6be89a6e28d4dac1f233f9aca9921f69b" upstream="master"/>
<project name="prebuilts-gcc-linux-x86-arm-gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf" path="prebuilts/gcc/linux-x86/arm/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf" remote="origin" revision="dd4df7dff4f1df65d78939a958b760a79e3650a1" upstream="master"/>
<project name="rkbin" remote="origin" revision="8a2c446756d8321a226d6d319a5b90aa882d9eec" upstream="master"/>
<project name="rkst" remote="origin" revision="c264f23734649fdb83d983bea7bcf11612651926" upstream="master"/>
<project groups="pdk" name="system-bt" path="system/bt" remote="origin" revision="97e7cf1d4cd16318503953af450d1e041668f21e" upstream="master"/>
<project groups="pdk" name="system-core" path="system/core" remote="origin" revision="cfc9c2005212253162ef844d31206f9da21b610a" upstream="master"/>
<project groups="pdk" name="system-sepolicy" path="system/sepolicy" remote="origin" revision="a3bf1cab1b67c1b0bb4cc57e89938ba05e2a7a78" upstream="master"/>
<project groups="pdk" name="system-vold" path="system/vold" remote="origin" revision="f377bc57377c922aee2cdcec92872c461a1ff437" upstream="master"/>
<project name="u-boot" remote="origin" revision="afd25a447a447140c2fd004f71730c5ed97d3e4b" upstream="master"/>
<project name="vendor-rockchip-common" path="vendor/rockchip/common" remote="origin" revision="58f78ca026a51ac569a542c330a30917569dd7ea" upstream="master"/>
Make Example, the last one “vendor-rockchip-common”
https://github.com/rockchip-toybrick/?q=vendor-rockchip-common&type=&language=&sort=
This project seems renamed to rk_platform_vendor_rockchip_common (GitHub - rockchip-toybrick/rk_platform_vendor_rockchip_common )
It is hard to skip every missing git and make compilation success.
Or you could provide new manifest.xml which on your manifests git without missing git error and could compile success.
It is easier and better to just provide one tar file which contains all source code for us.
Thanks
jack
August 22, 2021, 2:36am
4
We will fix this by pushing our local copy to radxa github, please wait for some time. Toybrick team were not aware that their repos are used by downstreams.
jay_wu
August 25, 2021, 3:27am
6
Hi Jack
Do you have schedule about this github problem?
I believe this will take some time, but could you release it eariler?
Thanks
Hi @jay_wu
This issue is fixed. Please check it again according to this guide, https://wiki.radxa.com/RockpiN10/Android8 .
Please note that you need to update manifests .
jay_wu
September 2, 2021, 12:33am
8
We download the code and compiled successfully.
Thanks
