RockPi4 SE - GPU drivers / configuration
for our project I need to work around the hardware video acceleration and gpu for gstreamer and udpsink.
I have installed glmarks. After I run it, I get following error message:
radxa@rock-4se:~$ glmark2
libGL error: failed to create dri screen
libGL error: failed to load driver: rockchip
** GLX does not support GLX_EXT_swap_control or GLX_MESA_swap_control!
** Failed to set swap interval. Results may be bounded above by refresh rate.
	glmark2 2021.12
	OpenGL Information
	GL_VENDOR:      Mesa/X.org
	GL_RENDERER:    llvmpipe (LLVM 11.0.1, 128 bits)
	GL_VERSION:     3.1 Mesa 20.3.5
	Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=32 stencil=0
	Surface Size:   800x600 windowed
[build] use-vbo=false: FPS: 23 FrameTime: 43.478 ms
I would really appreciate it if someone can tell me if this message is ok. Or are the drivers for GPU drivers not installed or configured correctly?
Regards,
Rami
I dunno about stream or stuff but if u need an OS with installed GPU driver for Rock Pi 4 SE, i suggest Twister OS
It make for Rock pi 4B but our board work fine. I dunno if it help but good luck
Follow this tutorial to fix itss boot problem first
Title
Hi chay,
thanks for the replay.
I took lot of time and effort to develop our firmware for this project on RockPi4 SE Debian 11. We are already using gstreamer for capturing the video signal. We are using some gstreamer elements for another tasks, like encoding, threading etc. What we want to do now is to draw some text and images on the video signal via the gstreamer GPU element “gloverlay”, before we broadcast the signal via udpsink.
My question is how to do this kind of drawing with gstreamer via GPU? which drivers should I have installed, to get it worked in our firmware?
Thanks,
Rami
Hi Rami,
I apologize, but I’m just a regular user. I haven’t tried those things yet.
Search “gloverlay” in this forum (all board) and your anwser is the only result so i guess u won’t find any help here.
Anyway, gud luck with what u’re doing.
Many thanks Chay for your replay
