RockPi Sata Hat - configuration file wrong name
I just reinstalled my RaspberryPi 4 NAS with the RockPi Quad Sata Hat after server years.
The installation process changed from sh script to deb package on the wiki.:
https://wiki.radxa.com/Dual_Quad_SATA_HAT
After following the installation steps, I discovered, that the configuration set in the generated file /etc/rockpi-quad.conf is not applying.
After further investigation I found out,
that the main.py script calls fan.py which calls misc.py which expects a confiugration file named and located in /etc/rockpi-penta.conf.
After renameng the configuration file all is working fine again.
Maybe you could fix that in the deb package.
Kind regards, Wachi
