3.5inch RPi LCD (A) and 3.5inch RPi LCD (B) are hardware compatible with each other (uses different driver), and can be mutually substituted in most cases. (A) for low cost ver. while (B) for IPS ver. with better displaying.
Model A and B should be the same, just IPS vs none IPS.
I have two RockPi S v1.2, so the selected overlay was this one:
rockpis-v12-spi2-waveshare35b-v2
I also modified the config file /etc/X11/xorg.conf.d/20-modesetting.conf, trying with both “/dev/fb0” or “/dev/fb1”.
I did not install any desktop manager, I’d like to see the terminal on the screen. Am I missing something? did someone else tried that overlay with latest image?
Hello, with the new update on the chip working only with the Ubuntu focal server i have a hard time setting up any GUI on top. Although using the documentation i can get the display working without a gui, once i install the LXDE or any other ubuntu-desktop i get a blinking cursor at the startup.
Any chance you could drop the steps you followed to get the LXDE installed?
