I need to access two different devices on SPI bus. They are operating on two different SPI modes and hence can’t hook to the same bus. So how can I enable both SPI 1 and SPI2 at the same time?
Thanks
Thanks
@Mitchell Please help to fix the issue.
Hi @ThusithaSKS, May I ask what version of software you are using?
Hi, I’m referring to https://wiki.radxa.com/RockpiS/Ubuntu. As per that I can configure only one SPI at a time.
overlays=rk3308-spi-spidev
param_spidev_spi_bus=2
param_spidev_spi_cs=0
param_spidev_max_freq=10000000
How can I configure second SPI?
Thanks
Is this the image you are using?
rockpis_ubuntu_focal_server_arm64_20210924_0418-gpt.img.gz
Unzip this package, you will get two files: rk3308-spi1-spidev.dtbo , rk3308-spi2-spidev.dtbo
Then copy these two files to the /boot/dtbs/4.4.143-65-rockchip-g58431d38f8f3/rockchip/overlay/ directory of the board.
After that, you just need to add rk3308-spi1-spidev rk3308-spi2-spidev after the overlay line in the /boot/uEnv.txt file, and that’s it, enough for reboot, you will see spidev1.0 and spidev2.0 in the /dev directory.
overlays=rk3308-uart0 rk3308-spi1-spidev rk3308-spi2-spidev
spi_dtbo.zip (1.1 KB)
Hi Mitchell,
It worked and spidev1.0 and spidev2.0 devices are connected. But when I try to open a SPI device using libmraa, it fails to initialize SPI device. (I’m trying example on https://wiki.radxa.com/RockpiS/dev/libmraa)
Thanks
I tried to enable SPI devices one by one. SPI 1 initializes as per libmraa example. But SPI 2 fails to initialize. Pls help
ROCKPI S Ver 13
OS rockpis_ubuntu_focal_server_arm64_20210924_0418-gpt.img.gz
Thanks
I had the problem of initializing SPI2 using mraa_spi_init() function. It was solved by using mraa_spi_init_raw() function.
Thanks
