Good evening, I have tried to set up a penta sata hat with a RockPi 4C following this official guide and I have an error installing the script provided.
I have installed the last image of Ubuntu Server 20.04 on the official download page of Radxa.
I have tried to send an email to setq@radxa.com as they suggest in case of error but I have not received any answer, so I’m here asking you for help.
This is the output of the script:
root@termin-rockpi4c:/home/rock# curl -sL https://rock.sh/get-rockpi-penta | bash -
*** Penta SATA Hat Install for ROCK Pi 4
*** Tested distributions:
*** Armbian 20.05.4 focal
*** Armbian 20.05.3 buster
*** Debian 9 Desktop (radxa official image)
*** Ubuntu Server 18.04 (radxa official image)
*** Please report problems to setq@radxa.com and we will try to fix.
Package(s) rockpi4c-rk-u-boot-latest libmraa python3-dev python3-pip python3-pil is required.
Would you like to apt-get install the packages? [Y/n] y
Hit:1 http://apt.radxa.com/focal-stable focal InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:3 http://software.virtualmin.com/vm/6/gpl/apt virtualmin-focal InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Hit:5 http://software.virtualmin.com/vm/6/gpl/apt virtualmin-universal InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:7 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Reading package lists... Done
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://software.virtualmin.com/vm/6/gpl/apt virtualmin-focal InRelease' doesn't support architecture 'arm64'
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'http://software.virtualmin.com/vm/6/gpl/apt virtualmin-universal InRelease' doesn't support architecture 'arm64'
Building dependency tree
E: Unable to locate package rockpi4c-rk-u-boot-latest
E: Unable to locate package libmraa
running install
running bdist_egg
running egg_info
creating Adafruit_SSD1306.egg-info
writing Adafruit_SSD1306.egg-info/PKG-INFO
writing dependency_links to Adafruit_SSD1306.egg-info/dependency_links.txt
writing requirements to Adafruit_SSD1306.egg-info/requires.txt
writing top-level names to Adafruit_SSD1306.egg-info/top_level.txt
writing manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt'
reading manifest file 'Adafruit_SSD1306.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
creating build
creating build/lib
creating build/lib/Adafruit_SSD1306
copying Adafruit_SSD1306/SSD1306.py -> build/lib/Adafruit_SSD1306
copying Adafruit_SSD1306/__init__.py -> build/lib/Adafruit_SSD1306
creating build/bdist.linux-aarch64
creating build/bdist.linux-aarch64/egg
creating build/bdist.linux-aarch64/egg/Adafruit_SSD1306
copying build/lib/Adafruit_SSD1306/SSD1306.py -> build/bdist.linux-aarch64/egg/Adafruit_SSD1306
copying build/lib/Adafruit_SSD1306/__init__.py -> build/bdist.linux-aarch64/egg/Adafruit_SSD1306
byte-compiling build/bdist.linux-aarch64/egg/Adafruit_SSD1306/SSD1306.py to SSD1306.cpython-38.pyc
byte-compiling build/bdist.linux-aarch64/egg/Adafruit_SSD1306/__init__.py to __init__.cpython-38.pyc
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying Adafruit_SSD1306.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/Adafruit_SSD1306-1.6.2-py3.8.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing Adafruit_SSD1306-1.6.2-py3.8.egg
Removing /usr/local/lib/python3.8/dist-packages/Adafruit_SSD1306-1.6.2-py3.8.egg
Copying Adafruit_SSD1306-1.6.2-py3.8.egg to /usr/local/lib/python3.8/dist-packages
Adafruit-SSD1306 1.6.2 is already the active version in easy-install.pth
Installed /usr/local/lib/python3.8/dist-packages/Adafruit_SSD1306-1.6.2-py3.8.egg
Processing dependencies for Adafruit-SSD1306==1.6.2
Searching for Adafruit-GPIO>=1.0.5
Downloading https://s3.setq.io/rockpi/pypi/Adafruit-GPIO-v1.0.5.zip
Best match: Adafruit-GPIO 1.0.5
Processing Adafruit-GPIO-v1.0.5.zip
Writing /tmp/easy_install-91jz3lg5/Adafruit-GPIO-v1.0.5/setup.cfg
Running Adafruit-GPIO-v1.0.5/setup.py -q bdist_egg --dist-dir /tmp/easy_install-91jz3lg5/Adafruit-GPIO-v1.0.5/egg-dist-tmp-frbgdisa
File "/tmp/easy_install-91jz3lg5/Adafruit-GPIO-v1.0.5/setup.py", line 11, in <module>
classifiers = ['Development Status :: 4 - Beta',
ModuleNotFoundError: No module named 'pip'
During handling of the above exception, another exception occurred:
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 154, in save_modules
yield saved
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 195, in setup_context
yield
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 250, in run_setup
_execfile(setup_script, ns)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 45, in _execfile
exec(code, globals, locals)
File "/tmp/easy_install-91jz3lg5/Adafruit-GPIO-v1.0.5/setup.py", line 14, in <module>
'Intended Audience :: Developers',
ModuleNotFoundError: No module named 'ensurepip'
File "setup.py", line 20, in <module>
setup(name = 'Adafruit_SSD1306',
File "/usr/lib/python3/dist-packages/setuptools/__init__.py", line 144, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/usr/lib/python3/dist-packages/setuptools/command/install.py", line 67, in run
self.do_egg_install()
File "/usr/lib/python3/dist-packages/setuptools/command/install.py", line 117, in do_egg_install
cmd.run(show_deprecation=False)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 450, in run
self.easy_install(spec, not self.no_deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 693, in easy_install
return self.install_item(None, spec, tmpdir, deps, True)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 740, in install_item
self.process_distribution(spec, dist, deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 784, in process_distribution
distros = WorkingSet([]).resolve(
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 781, in resolve
dist = best[req.key] = env.best_match(
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1066, in best_match
return self.obtain(req, installer)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1078, in obtain
return installer(requirement)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 712, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 738, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 923, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1191, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/lib/python3/dist-packages/setuptools/command/easy_install.py", line 1177, in run_setup
run_setup(setup_script, args)
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 253, in run_setup
raise
File "/usr/lib/python3.8/contextlib.py", line 131, in __exit__
self.gen.throw(type, value, traceback)
yield
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 166, in save_modules
saved_exc.resume()
File "/usr/lib/python3/dist-packages/setuptools/sandbox.py", line 141, in resume
six.reraise(type, exc, self._tb)
File "/usr/lib/python3/dist-packages/setuptools/_vendor/six.py", line 685, in reraise
raise value.with_traceback(tb)
yield saved
yield
(Reading database ... 180884 files and directories currently installed.)
Preparing to unpack /tmp/tmp.67UggUVbw2 ...
Removed /etc/systemd/system/multi-user.target.wants/rockpi-penta.service.
Unpacking rockpi-penta (0.10) over (0.10) ...
Setting up rockpi-penta (0.10) ...
Created symlink /etc/systemd/system/multi-user.target.wants/rockpi-penta.service → /lib/systemd/system/rockpi-penta.service.
File "/usr/bin/rockpi-penta/misc.py", line 6, in <module>
import mraa # pylint: disable=import-error
ModuleNotFoundError: No module named 'mraa'
