i tried to boot a
Rock Pi 4c Plus, V1.1, 2022.01.13
from mSDcard flashed with
rockpi4c_debian_buster_xfce4_arm64_20210824_0245-gpt.img.gz.
But I doesn’t boot and seems to crash somewhere inU-Boot.
Debug Console Output:
DDR Version 1.20 20190314
In
soft reset
SRX
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 315
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14800MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29007MB
FwPartOffset=2000 , 0
StorageInit ok = 66865
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: loader1, start:0x40, size:0x1f40
GPT part: 1, name: loader2, start:0x4000, size:0x2000
GPT part: 2, name: trust, start:0x6000, size:0x2000
GPT part: 3, name: boot, start:0x8000, size:0x100000
GPT part: 4, name: rootfs, start:0x108000, size:0x2b1aa9
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xf162c
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):0e7a845
NOTICE: BL31: Built : 16:13:46, Apr 17 2019
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-2696-g7c49a7da79 (Oct 12 2020 - 02:09:00 +0000), Build: jenkins-linux-build-release-366
Model: Radxa ROCK Pi 4C
PreSerial: 2
DRAM: 3.9 GiB
Relocation Offset is: f5bde000
Sysmem: init
I2c speed: 400000Hz
rk8xx_read: read reg 0x17 failed, ret=-121
"Synchronous Abort" handler, esr 0x96000010
* Relocate offset = 00000000f5bde000
* ELR(PC) = 000000000025962c
* LR = 0000000000259614
* SP = 00000000e9dc7ef0
* ESR_EL2 = 0000000096000010
EC[31:26] == 100101, Exception from a Data abort, from current exception level
IL[25] == 1, 32-bit instruction trapped
* DAIF = 00000000000003c0
D[9] == 1, DBG masked
A[8] == 1, ABORT masked
I[7] == 1, IRQ masked
F[6] == 1, FIQ masked
* SPSR_EL2 = 0000000080000349
I[7] == 0, IRQ not masked
M[4] == 0, Exception taken from AArch64
M[3:0] == 1001, EL2h
* SCTLR_EL2 = 0000000030c51835
I[12] == 1, Icaches enabled
C[2] == 1, Dcache enabled
M[0] == 1, MMU enabled
* HCR_EL2 = 000000000800003a
* VBAR_EL2 = 00000000f5dde800
* TTBR0_EL2 = 00000000f7ff0000
x0 : 0000000000000000 x1 : 00000000f5e88918
x2 : 00000000f5ea9310 x3 : 00000000e9de4cc0
x4 : 00000000ffffff87 x5 : 00000000e9dfbab0
x6 : 0000000000000021 x7 : 00000000f5ea92d0
x8 : 00000000e9dfbca0 x9 : 0000000000000008
x10: 00000000ffffffe0 x11: 0000000000000006
x12: 000000000001869f x13: 00000000f5eac398
x14: 00000000f5eac320 x15: 00000000fffffffe
x16: 0000000000000000 x17: 0000000000000000
x18: 00000000e9dd5d80 x19: 00000000e9dfbb10
x20: 0000000000000009 x21: 00000000e9dfbbf8
x22: 00000000e9de4c80 x23: 00000000f5e99be8
x24: 00000000e9df2450 x25: 000000000036ee80
x26: 00000000f5ea13fb x27: 0000000000000000
x28: 0000000000000000 x29: 00000000e9dc80d0
SP:
e9dc7ef0: 00000000 00000000 00000000 00000000
e9dc7f00: 00000000 00000000 f5e9af22 00000000
e9dc7f10: 00000000 00000000 00000000 00000000
e9dc7f20: f5e9af69 00000000 f5e9af8f 00000000
e9dc7f30: f5e9afdc 00000000 f5e9b029 00000000
e9dc7f40: f5e9b069 00000000 f5e9b0a9 00000000
e9dc7f50: f5e9b0e6 00000000 00000000 00000000
e9dc7f60: 00000000 00000000 f5e9b123 00000000
e9dc7f70: e9dc80d0 00000000 f5ddea0c 00000000
e9dc7f80: e9dfbb10 00000000 00000002 00000000
e9dc7f90: f7ff0000 00000000 0800003a 00000000
e9dc7fa0: 30c51835 00000000 e9dc7ef0 00000000
e9dc7fb0: 80000349 00000000 f5dde800 00000000
e9dc7fc0: 000003c0 00000000 96000010 00000000
e9dc7fd0: f5e3762c 00000000 00000000 00000000
e9dc7fe0: f5e88918 00000000 f5ea9310 00000000
Call trace:
PC: [< 0025962c >]
LR: [< 00259614 >]
Stack:
[< 0025962c >]
[< 002309ec >]
[< 00231ab0 >]
[< 00231b00 >]
[< 0025951c >]
[< 002030d8 >]
[< 00277f20 >]
[< 00215ef0 >]
[< 00201b8c >]
NOTE: Please use ./scripts/stacktrace.sh to parse trace info
Resetting CPU ...
Is this an issue with the image? Is there something newer?
Thanks a lot.
