ROCKpi 4C Images compatible with Penta Hat?
Hello all,
I am hoping someone can direct me to a working OS image for my Rockpi 4c with Penta hat.
I would love a link to either Armbian 20.05.4 focal or Armbian 20.05.3 buster. I have tried to find either one, but the lowest version I can find is Armbian 21.02.1
I would just like to get the fan and OLED screen working again. They were working fine before I decided to clean install to the latest armbian release and lost the fan and OLED.
To be more specific I’m trying to find a OS image that works with the command to install Penta hat software:
curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash -
I have tried so many OS images, (ubuntu, debian, armbian) with no luck.
Help would be vastly appreciated.
Thank you
Still no luck locating either Armbian 20.05.4 focal or Armbian 20.05.3 buster download links. Anyone know of where I can find one?
@setq can you give some advice,
Hi @Nathan_Ring,
What does sudo systemctl status rockpi-penta.service print?
I wasn’t able to work on this much today due to work. Here is some information of what I did today:
Fresh install of Armbian 21.05.1 Focal with Linux 5.10.35-rockchip64
run command:
Unit rockpi-penta.service could not be found
run command:
nate@rockpi-4c:~$ curl -sL https://rock.sh/get-rockpi-penta | sudo -E bash -
Only have the following information appear then nothing
*** Penta SATA Hat Install for ROCK 3/4/5
*** Tested distributions:
*** - ROCK 5A
*** Debian 11 Desktop (radxa official image)
*** - ROCK 4
*** Armbian 20.05.4 focal
*** Armbian 20.05.3 buster
*** Debian 9 Desktop (radxa official image)
*** Debian 11 Desktop/CLI (radxa official image)
*** Ubuntu Server 18.04 (radxa official image)
*** - ROCK 3
*** Debian 10 Desktop (radxa official image)
*** Ubuntu Server 20.04 (radxa official image)
*** Please report problems to [email protected] and we will try to fix.
run command:
I decided to look inside the script by downloading it:
wget https://rock.sh/get-rockpi-penta
looked inside the script using nano, found the command:
https://cos.setf.me/rockpi/sh/penta-sata/rock4-armbian.sh
Decided to experiment and ran the following command:
nate@rockpi-4c:~$ curl -sL https://cos.setf.me/rockpi/sh/penta-sata/rock4-armbian.sh | sudo -E bash -
I was prompted to install additional software so the script started, and after install fan started spinning to my surprise. OLED display still doesn’t work.
run command:
nate@rockpi-4c:~$ sudo systemctl status rockpi-penta.service
● rockpi-penta.service - Rockpi SATA Hat
Loaded: loaded (/lib/systemd/system/rockpi-penta.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2024-01-17 20:36:22 PST; 4s ago
Main PID: 3021 (python3)
Tasks: 2 (limit: 4459)
Memory: 10.5M
CGroup: /system.slice/rockpi-penta.service
├─3021 /usr/bin/python3 /usr/bin/rockpi-penta/main.py on
└─3032 /usr/bin/python3 /usr/bin/rockpi-penta/main.py on
Jan 17 20:36:22 rockpi-4c systemd[1]: Started Rockpi SATA Hat.
Jan 17 20:36:22 rockpi-4c libmraa[3021]: libmraa version v2.1.0 initialised by user ‘root’ with EUID 0
Jan 17 20:36:22 rockpi-4c libmraa[3021]: imraa: Failed to open lock file
Jan 17 20:36:22 rockpi-4c libmraa[3021]: gpio: platform doesn’t support chardev, falling back to sysfs
Jan 17 20:36:22 rockpi-4c libmraa[3021]: libmraa initialised for platform ‘ROCK Pi 4’ of type 20
Jan 17 20:36:22 rockpi-4c libmraa[3021]: pwm_init: pwm0 already exported, continuing
I think that is all relevant information. I’m willing to start from scratch again, and would actually prefer to do so.
Would like suggestions of what headless/CLI OS images work with the penta hat and provide fan and OLED. I’ll work with any suggestion.
Thanks for your time.
Small update.
Installed new OS: Armbian 22.11.0-trunk Bullseye with Linux 6.1.63-current-rockchip64
utilized this command:
rebooted and ran command:
results:
Loaded: loaded (/lib/systemd/system/rockpi-penta.service; enabled; vendor >
Active: active (running) since Fri 2024-01-19 23:52:19 PST; 3min 47s ago
Main PID: 763 (python3)
Tasks: 2 (limit: 4456)
Memory: 23.1M
CPU: 1.261s
├─ 763 /usr/bin/python3 /usr/bin/rockpi-penta/main.py on
└─1314 /usr/bin/python3 /usr/bin/rockpi-penta/main.py on
Jan 19 23:52:19 rockpi-4c systemd[1]: Started Rockpi SATA Hat.
Jan 19 23:52:20 rockpi-4c libmraa[763]: libmraa version v2.1.0-20-g9ea5a29 init>
Jan 19 23:52:20 rockpi-4c libmraa[763]: gpio: platform doesn’t support chardev,>
Jan 19 23:52:20 rockpi-4c libmraa[763]: libmraa initialised for platform 'ROCK >
lines 1-15/15 (END)…skipping…
Memory: 23.1M
CPU: 1.261s
Jan 19 23:52:20 rockpi-4c libmraa[763]: libmraa version v2.1.0-20-g9ea5a29 initialised by user ‘root’ with EUID 0
Jan 19 23:52:20 rockpi-4c libmraa[763]: gpio: platform doesn’t support chardev, falling back to sysfs
Jan 19 23:52:20 rockpi-4c libmraa[763]: libmraa initialised for platform ‘ROCK Pi 4’ of type 20
Fan works, however, OLED display does not. Any pointers on getting the OLED to function again?
@setq any advice on getting the OLED display to function again. I will provide any information you need. Thank you
Hi @Nathan_Ring,
Have you tried Debian 10 Desktop(Linux 4.4) and Ubuntu 20 Server(Linux 4.4) ?
Since ROCK 4C ended its life cycle, we did not release new images and did not test scripts for compatibility with some new images. We’ll take a moment to look at the new armbian image.
@setq Thanks for the reply. I appreciate you taking some of time to help.
I tried Debian 10 Desktop only very briefly as I would rather not have a desktop environment. The ubuntu 20(Linux 4.4) server gave me a lot of issues getting the penta hat software to function. I was never able to get the fan to work. The rockpi-penta.service would not function without errors. So far armbian has yielded the best results, besides for the OLED display everything is functioning.
Thanks again for looking into it.
