RockPi 4B with MCP2515
Hello all,
I am trying to interface with the MCP2515 on SPI2 of the RockPi4B on Armbian 22.08.6 Bullseye with Linux 5.15.74-rockchip64 and encountering some issues.
The rockpi4B pins that I am using to connect to the MCP2515 on a custom-made PCB. I can confirm that the custom PCB that is made works reliably on a raspberry pi device with no issues, I only began encountering issues when trying with the RockPi.
INT - GPIO2_A7
MOSI - GPIO2_B2
MISO - GPIO2_B1
CLK - GPIO2_B3
CS - GPIO2_B4
When using the overlay file that I have shown below, the output for “dmesg | grep mcp”:
[ 6.662536] rockchip-pinctrl pinctrl: unable to find group for node mcp2515_int_pin
I have been able to get the MCP2515 to initialize successfully, but only if I comment out the pinctrl-0 reference to the mcp2515_int_pin in the overlay. Doing this I can bring up the device but I am only able to send/receive a few messages before candump shows it’s not transmitting any messages until I bring down and up the can0 device where it will do the same thing. The interesting thing is, when the device doesn’t communicate I can still see that the can0 device is still in the “Error-Active” mode, so theoretically I should still be able to interface with it?
Also, I would like to mention the reason I am using SPI2 instead of SPI1 is that the RockPi that I have has the SPI flash module installed which causes canbus fault messages.
So, I am led to believe the issue I am encountering is due to that comment line to pinctrl-0 in the overlay. Just not sure of the solution to this. I have looked about just about every forum that makes reference to the MCP2515 and have not found any promising solutions. I have tried changing the target on fragment@0 to <&gpio>, <&gpio2>, etc.
Here is a look at the DTS overlay I am using for the MCP2515:
`//This devicetree overlay is used for RS485 CAN HAT.
/dts-v1/;
/plugin/;
compatible = “rockchip,rockpi”,“rockchip,rk3399”, “rockchip,rk3399-pinctrl”;
    fragment@0 {
            target = <&pinctrl>;
            __overlay__ {
                    mcp2515_int_pin: mcp2515_int_pin {
                            rockchip,pins = <2 7 0 &pcfg_pull_none>;
    fragment@1 {
            target-path = "/";
            __overlay__ {
                    can_mcp2515_osc: can-mcp2515-osc {
                            compatible = "fixed-clock";
                            clock-frequency = <16000000>;
                            #clock-cells = <0>;
    fragment@2 {
            target = <&spi2>;
            __overlay__ {
                    status = "okay";
                    max-freq = <10000000>;
                    #address-cells = <1>;
                    #size-cells = <0>;
                    can_mcp2515: can-mcp2515@0 {
                            status = "okay";
                            compatible = "microchip,mcp2515";
                            reg = <0>;
                            interrupt-parent = <&gpio2>;
                            interrupts = <7 2 8>;
                            spi-max-frequency = <10000000>;
                            clocks = <&can_mcp2515_osc>;
                            vdd-supply = <&vcc3v3_sys>;
                            xceiver-supply = <&vcc3v3_sys>;
                            pinctrl-names = "default";
                            pinctrl-0 = <&mcp2515_int_pin>;
And my armbianEnv.txt:
verbosity=1
bootlogo=false
overlay_prefix=rockchip
fdtfile=rockchip/rk3399-rock-pi-4b.dtb
rootdev=UUID=fa2cbc7c-56d1-448b-9ab3-fe864e21fbc5
rootfstype=ext4
overlays=spi-spidev
param_spidev_spi_bus=1
user_overlays=spi1-mcp2515-can0-overlay
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
Here’s a link to my armbianmonitor -u: https://paste.armbian.com/azameworos
I would like to mention I am not very skilled with Linux based devices so please bear with me.
Any help would be greatly appreciated!
Best,
Austin
Hello! Tell me how to run mcp2515, tried all the instructions and tips from the forums. can 0 is not created. Can someone send a working image?
