ROCKPI 4B+ EMMC download image, ERROR:Test Device Fail
I am download EMMC according to the following documents [https://wiki.radxa.com/Rockpi4/dev/usb-install] , but there is an error as shown in the following picture, I don’t know why?
What version of hardware are you using? V1.6?
Do you have serial console?
Yes, it’s V1.6. But I don’t have serial console. If the serial console is important, I can simulate one with ESP32.
Can esp32 support 1.5M baud rate? Also, there is a log folder in the windows tool directory, please send the failure log.
The ESP32 supports 1.5M and can read serial output from the board.
And is the failure log this?
10:48:57 691 RKDevTool v2.6.9.0 start run
10:49:08 180 Layer<1-1>:Download Boot Start
10:49:11 746 Layer<1-1>:Download Boot Success
10:49:11 746 Layer<1-1>:Wait For Maskrom Start
10:49:12 172 Layer<1-1>:Wait For Maskrom Success
10:49:12 172 Layer<1-1>:Test Device Start
10:49:12 172 Error:RKU_Write–>WriteFile failed,bRet=0,err=31,size=31,write=0
10:49:34 217 INFO:RKU_ResetPipe–>DeviceIoControl OK
10:49:34 219 Error:RKU_Write–>WriteFile failed,bRet=0,err=31,size=31,write=0
10:49:34 219 <LAYER 1-1> ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3),path=\?\USB#VID_2207&PID_330C#5&2956BF20&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
10:49:40 225 Error:RKU_Write–>WriteFile failed,bRet=0,err=995,size=31,write=0
10:49:42 228 ERROR:RKU_ResetPipe–>DeviceIoControl failed,err=31
10:49:42 228 <LAYER 1-1> ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3),path=\?\USB#VID_2207&PID_330C#5&2956BF20&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
10:49:48 247 Error:RKU_Write–>WriteFile failed,bRet=0,err=995,size=31,write=0
10:49:50 249 ERROR:RKU_ResetPipe–>DeviceIoControl failed,err=31
10:49:50 249 <LAYER 1-1> ERROR:TestDevice–>RKU_TestDeviceReady failed,RetCode(-3),path=\?\USB#VID_2207&PID_330C#5&2956BF20&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
10:49:51 254 Error:Layer<1-1>:Test Device Fail
10:49:51 264 Layer<1-1>: RunProc is ending, ret=0
It looks like a communication issue, after reboot, PC lost the ROCK Pi 4.
Are you using laptop or PC to flash the ROCK Pi 4? If laptop, try different USB ports, if PC, try the backpanel USB.
Do you have SPI shortcut? You should remove it after maskrom mode.
Thanks for the help, I am using the laptop. I replaced the desktop and it worked. But before that, I installed img for eMMC with the ‘dd’ command of SDcard Linux.
