This RockPi 4 looks to be one of my worst purchasing decisions of all time. The designers must have been on drugs - for instance, you cannot get to the eMMC without removing the heatsink first.
Other things that you take for granted - like the TTY being correctly sized to your monitor on boot - are broken on the RockPi 4. It opens the TTYs to what looks like about 640x480 on a 1920x1080 monitor. I have to install the fbset command to fix it, and that has to be done on every TTY. Also the boot menu does not show, so there is no way to choose kernel. I am using extlinux on the Ubuntu Server image.
What is worse is that the onboard devices such as USB and the GPU are “magically” connected - they do not appear on the PCI busses. This is horrible for configuration and development purposes.
Anyway, the question I have is the following:
If I use a Samsung 950 Pro SSD, I only get 600MB/s, which is very slow for PCIe 2.0 x4. Looking into the configuration, it appears that it is only running at 2.5GT/s. How do I get it to work at 5.0GT/s?
It does not matter if I use the ribbon cable or shove the SSD straight in the board, sticking out of the side.
Thanks
I found you have to use dtbo to enable 5GT/s. This is a poor design - PCIe should automatically choose the highest link speed supported by the two endpoints.
Also, my Samsung 950 Pro is now reading at 645MB/s - only a tiny improvement, and much lower than advertised for NVMe speeds for this board.
Based on experiences with X86, PCIe 2.0 x4 or PCIe 3.0 x2 should be good for about 1500-1600MB/s for NVMe after overheads. Something is clearly still wrong here.
Thanks
Another issue is that the IOMMU is not working - it is enabled, but does not place the PCIe devices behind it. Only some other obscure devices.
Another strange thing is that there are six cores running, and two disabled - is the RK3399 actually an 8 core silicon with two cores disabled? Is there any way to enable them? Thanks.
https://wiki.radxa.com/Rockpi4/hardware/devtree_overlays
pcie-gen2 |
| Info: |
Overlay for activation of pcie running on GEN2 mode. |
| Load: |
intfc:dtoverlay=pcie-gen2 |
Thanks. As I said, I figured that out.
But can you tell me why it is still only at 645MB/s sequential reads, even though it is running at 5GT/s? And how to get the IOMMU working?
Dunno here is an EVO 970 on the RockPi4
Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Output is in kBytes/sec
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
102400 4 52099 77524 104207 105324 48114 78504
102400 16 160544 231475 276300 278531 160180 233806
102400 512 738881 809485 685261 707192 676594 811610
102400 1024 795915 841642 708547 730494 693498 851120
102400 16384 1111519 1167200 1098700 1139913 1110364 1193693
