Hi All,
I have configured spi0 in the device tree to use assigned-clock-rates as 1MHz. But I could see that ROCK5B is not able to set it as I see the message “clk: couldn’t set clk_spi0 clk rate to 1000000 (-22), current rate: 198000000” in the dmesg. Does this means that 198000000 is the minimum assigned-clock-rate we can set for ROCK5B SPI0? Does this is a ROCK5B hardware limitation? My device tree changes are as follows.
&spi0 {
status = “okay”;
assigned-clocks = <&cru CLK_SPI0>;
assigned-clock-rates = <2000000>;
pinctrl-names = “default”;
pinctrl-0 = <&spi0m2_pins &spi0_interrupt_pin &spi0_reset_pin>;
num-cs = <1>;
spidev@0{
compatible = “linux,spidev”;
reg = <0>; // Chip select number
interrupt-parent = <&gpio3>;
interrupts = <RK_PA7 IRQ_TYPE_EDGE_FALLING>;
interrupt-names = “spi0_irq”;
Thanks in advance for any help.
Best regards,
Pradeep
