您好,我最近在ROCK5B-PLUS适配IMX290出现问题,由于我能力问题,无法进一步确定原因,希望您能帮忙看看。
需求设计:
- 根据ROCK5B-PLUS的MIPI CSI CAM硬件接口定义,定制了IMX290模组,大部分都与ROCK5B-PLUS CSI引脚定义一致,只是将FPC线的28,29,30分别定义为IMX290的vddd、vdddo、vdda,和ROCK5B-PLUS的MIPI CSI CAM的28、29、30定义不太一致。
- 参照Radxa Camera 4K的设备树实现了IMX290的Overlay设备树,并在内核源码中启用了编译了IMX290驱动。
- 如图所示连接IMX290与ROCK5B-PLUS的CAM0口;
问题描述:
在系统中启用IMX290设备树,并加载imx290.ko;打印以下错误:
疑问:
- 我的IMX290设备树实现有什么问题吗?
- ROCK5B-PLUS的28、29、30引脚可以配置为(vddd、vdddo、vdda)对应的电压范围吗?
相关资料:
ROCK5B-PLUS CSI2引脚定义:
IMX290模组CSI2的引脚定义:
IMX290设备树实现:
/dts-v1/;
/plugin/;
#include <dt-bindings/clock/rk3588-cru.h>
#include <dt-bindings/power/rk3588-power.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pinctrl/rockchip.h>
metadata {
title ="Enable Radxa Camera IMX290 on CAM0";
compatible = "radxa,rock-5b-plus";
category = "camera";
exclusive = "csi2_dphy0";
description = "Enable Radxa Camera IMX290 on CAM0.";
fragment@0 {
target = <&i2c3>;
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&i2c3m0_xfer>;
status = "okay";
#address-cells = <1>;
#size-cells = <0>;
imx290: imx290@1a {
status = "okay";
compatible = "sony,imx290";
reg = <0x1a>;
clocks = <&cru CLK_MIPI_CAMARAOUT_M3>;
clock-names = "xclk";
clock-frequency = <37125000>;
pinctrl-0 = <&mipim0_camera1_clk>;
/* 电源按顺序定义 */
vddd-supply = <&camera_vddd_1v3>;
vdddo-supply = <&camera_vdddo_1v8>;
vdda-supply = <&camera_vdda_2v8>;
/* 复位信号 */
reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_LOW>;
rockchip,camera-module-index = <0>;
rockchip,camera-module-facing = "front";
rockchip,camera-module-name = "RADXA-CAMERA-IMX290";
rockchip,camera-module-lens-name = "DEFAULT";
port {
imx290_out0: endpoint {
remote-endpoint = <&mipidphy0_in_ucam0>;
data-lanes = <1 2 3 4>;
link-frequencies = /bits/ 64 <222750000 148500000>;
fragment@1 {
target = <&csi2_dphy0_hw>;
__overlay__ {
status = "okay";
fragment@2 {
target = <&csi2_dphy0>;
__overlay__ {
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
mipidphy0_in_ucam0: endpoint@1 {
reg = <1>;
remote-endpoint = <&imx290_out0>;
port@1 {
reg = <1>;
#size-cells = <0>;
csidphy0_out: endpoint@0 {
reg = <0>;
remote-endpoint = <&mipi2_csi2_input>;
fragment@3 {
target = <&mipi2_csi2>;
__overlay__ {
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
mipi2_csi2_input: endpoint@1 {
reg = <1>;
remote-endpoint = <&csidphy0_out>;
port@1 {
reg = <1>;
#size-cells = <0>;
mipi2_csi2_output: endpoint@0 {
reg = <0>;
remote-endpoint = <&cif_mipi2_in0>;
fragment@4 {
target = <&rkcif>;
__overlay__ {
status = "okay";
fragment@5 {
target = <&rkcif_mipi_lvds2>;
__overlay__ {
status = "okay";
port {
cif_mipi2_in0: endpoint {
remote-endpoint = <&mipi2_csi2_output>;
fragment@6 {
target = <&rkcif_mipi_lvds2_sditf>;
__overlay__ {
status = "okay";
port {
mipi_lvds2_sditf: endpoint {
remote-endpoint = <&isp0_vir0>;
fragment@7 {
target = <&rkcif_mmu>;
__overlay__ {
status = "okay";
fragment@8 {
target = <&isp0_mmu>;
__overlay__ {
status = "okay";
fragment@9 {
target = <&rkisp0>;
__overlay__ {
status = "okay";
fragment@10 {
target = <&rkisp0_vir0>;
__overlay__ {
status = "okay";
port {
#size-cells = <0>;
isp0_vir0: endpoint@0 {
reg = <0>;
remote-endpoint = <&mipi_lvds2_sditf>;
fragment@11 {
target-path = "/";
__overlay__ {
/* 第一级:3.3V转1.3V (DVDD) */
camera_vddd_1v3: regulator-vddd {
compatible = "regulator-fixed";
regulator-name = "camera_vddd_1v3";
regulator-min-microvolt = <1300000>;
regulator-max-microvolt = <1300000>;
/* 指定输入源为PMUIO2的3.3V */
vin-supply = <&vcc_3v3_s3>;
gpio = <&gpio1 RK_PB0 GPIO_ACTIVE_HIGH>; // 使能引脚
enable-active-high;
startup-delay-us = <1000>;
pinctrl-0 = <&cam_pwdn_gpio>;
/* 第二级:1.3V转1.8V (I/O电源) */
camera_vdddo_1v8: regulator-vdddo {
regulator-name = "camera_vdddo_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
/* 依赖DVDD的输出 */
vin-supply = <&camera_vddd_1v3>;
/* 第三级:1.8V转2.8V (模拟电源) */
camera_vdda_2v8: regulator-vdda {
regulator-name = "camera_vdda_2v8";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
/* 依赖I/O电源的输出 */
vin-supply = <&camera_vdddo_1v8>;
// fragment@12 {
// /* GPIO引脚控制配置 */
// target = <&pinctrl>;
// __overlay__ {
// pwdn_gpio: pwdn-gpio {
// /* 复位信号配置 */
// rockchip,pins = <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
