I am using RAUC on Rockchip RK3588 (Rock 5B) with Yocto , but when I use the file rockchip-dual.wks.in from /meta-rauc-rockchip , my device no longer boots, and I don’t understand the reason why.
Can someone help me?
file rockchip-dual.wks.in :
+++ b/meta-rauc-rockchip/wic/rockchip-dual.wks.in
@@ -19,17 +19,17 @@
atf 24576 8192 (trusted OS e.g. ATF, OP-TEE, etc)
root 32768 -
-part loader1 --offset 64s --fixed-size 3552K --fstype=none --part-name loader1 --source rawcopy --sourceparams=“file=${SPL_BINARY}”
+part loader1 --offset 64s --fixed-size 3552K --fstype=none --part-name loader1 --source rawcopy --sourceparams=“file=${DEPLOY_DIR_IMAGE}/idblock.img”
part v_storage --offset 7168s --fixed-size 256K --fstype=none --part-name v_storage
part reserved --offset 7680s --fixed-size 192K --fstype=none --part-name reserved
part reserved1 --offset 8064s --fixed-size 32K --fstype=none --part-name reserved1
part uboot_env --offset 8128s --fixed-size 32K --fstype=none --part-name uboot_env ${RK_UBOOT_ENV}
part reserved2 --offset 8192s --fixed-size 4096K --fstype=none --part-name reserved2
-part loader2 --offset 16384s --fixed-size 4096K --fstype=none --part-name loader2 --source rawcopy --sourceparams=“file=u-boot.${UBOOT_SUFFIX}”
+part loader2 --offset 16384s --fixed-size 4096K --fstype=none --part-name loader2 --source rawcopy --sourceparams=“file=${DEPLOY_DIR_IMAGE}/uboot.img”
part atf --offset 24576s --fixed-size 4096K --fstype=none --part-name atf
part /boot --source rootfs --rootfs-dir=${IMAGE_ROOTFS}/boot --fstype=ext4 --label boot --fixed-size 32M
part / --label rootfs_A --fstype=ext4 --part-name rootfsA --source rootfs
part / --label rootfs_B --fstype=ext4 --part-name rootfsB --source rootfs
-part /data --fixed-size 100M --ondisk mmcblk1 --fstype=ext4 --label data
+#part /data --fixed-size 100M --ondisk mmcblk0 --fstype=ext4 --label data
bootloader --ptable gpt
