Rock5b,最新的debian固件,无法正常使用xrdp
使用固件,官方的b36固件,xfce4版本的debian系统,安装xrdp,之后Windows无法正常连接rock5b
[20230805-21:19:13] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:19:13] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:19:13] [DEBUG] xrdp_mm_module_cleanup
[20230805-21:24:11] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:24:11] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:24:11] [INFO ] xrdp_listen_pp done
[20230805-21:24:11] [DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
[20230805-21:24:13] [INFO ] starting xrdp with pid 2105
[20230805-21:24:13] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:24:13] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:24:13] [INFO ] xrdp_listen_pp done
[20230805-21:24:17] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.172 port 54909
[20230805-21:24:17] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:24:17] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:24:17] [INFO ] Socket 12: AF_INET6 connection received from fdbc:fbea:f52c:0:8532:4807:1c19:5cc2 port 54910
[20230805-21:24:17] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230805-21:24:17] [DEBUG] Closed socket 12 (AF_INET6 fdbc:fbea:f52c::59c2 port 3389)
[20230805-21:24:17] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230805-21:24:17] [DEBUG] TLSv1.3 enabled
[20230805-21:24:17] [DEBUG] TLSv1.2 enabled
[20230805-21:24:17] [DEBUG] Security layer: requested 11, selected 1
[20230805-21:24:17] [INFO ] connected client computer name: LAPTOP-EE7KL8B9
[20230805-21:24:17] [INFO ] adding channel item name rdpdr chan_id 1004 flags 0x80800000
[20230805-21:24:17] [INFO ] adding channel item name rdpsnd chan_id 1005 flags 0xc0000000
[20230805-21:24:17] [INFO ] adding channel item name cliprdr chan_id 1006 flags 0xc0a00000
[20230805-21:24:17] [INFO ] adding channel item name drdynvc chan_id 1007 flags 0xc0800000
[20230805-21:24:17] [INFO ] TLS connection established from ::ffff:192.168.1.172 port 54909: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384
[20230805-21:24:17] [DEBUG] xrdp_0000083c_wm_login_mode_event_00000001
[20230805-21:24:17] [INFO ] Cannot find keymap file /etc/xrdp/km-00000804.ini
[20230805-21:24:17] [INFO ] Loading keymap file /etc/xrdp/km-00000409.ini
[20230805-21:24:17] [WARN ] local keymap file for 0x00000804 found and doesn’t match built in keymap, using local keymap file
[20230805-21:24:29] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20230805-21:24:29] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230805-21:24:29] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait…
[20230805-21:24:29] [DEBUG] return value from xrdp_mm_connect 0
[20230805-21:24:29] [INFO ] xrdp_wm_log_msg: login successful for display 13
[20230805-21:24:29] [DEBUG] xrdp_wm_log_msg: started connecting
[20230805-21:24:33] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:36] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:40] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:43] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:47] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:50] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:54] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:24:57] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:01] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:04] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:08] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:11] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:12] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:25:14] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:14] [DEBUG] xrdp_wm_log_msg: some problem
[20230805-21:25:14] [DEBUG] xrdp_mm_module_cleanup
[20230805-21:25:14] [DEBUG] Closed socket 18 (AF_INET6 ::1 port 42302)
[20230805-21:25:14] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:25:15] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:25:15] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:25:15] [INFO ] xrdp_listen_pp done
[20230805-21:25:15] [DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
[20230805-21:25:17] [INFO ] starting xrdp with pid 2206
[20230805-21:25:17] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:25:17] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:25:17] [INFO ] xrdp_listen_pp done
[20230805-21:25:20] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.172 port 54960
[20230805-21:25:20] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:25:20] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:25:20] [INFO ] Socket 12: AF_INET6 connection received from fdbc:fbea:f52c:0:8532:4807:1c19:5cc2 port 54961
[20230805-21:25:20] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230805-21:25:20] [DEBUG] Closed socket 12 (AF_INET6 fdbc:fbea:f52c::59c2 port 3389)
[20230805-21:25:20] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230805-21:25:20] [DEBUG] TLSv1.3 enabled
[20230805-21:25:20] [DEBUG] TLSv1.2 enabled
[20230805-21:25:20] [DEBUG] Security layer: requested 11, selected 1
[20230805-21:25:20] [INFO ] connected client computer name: LAPTOP-EE7KL8B9
[20230805-21:25:20] [INFO ] adding channel item name rdpdr chan_id 1004 flags 0x80800000
[20230805-21:25:20] [INFO ] adding channel item name rdpsnd chan_id 1005 flags 0xc0000000
[20230805-21:25:20] [INFO ] adding channel item name cliprdr chan_id 1006 flags 0xc0a00000
[20230805-21:25:20] [INFO ] adding channel item name drdynvc chan_id 1007 flags 0xc0800000
[20230805-21:25:20] [INFO ] TLS connection established from ::ffff:192.168.1.172 port 54960: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384
[20230805-21:25:20] [DEBUG] xrdp_0000089f_wm_login_mode_event_00000001
[20230805-21:25:20] [INFO ] Cannot find keymap file /etc/xrdp/km-00000804.ini
[20230805-21:25:20] [INFO ] Loading keymap file /etc/xrdp/km-00000409.ini
[20230805-21:25:20] [WARN ] local keymap file for 0x00000804 found and doesn’t match built in keymap, using local keymap file
[20230805-21:25:23] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20230805-21:25:23] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230805-21:25:23] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait…
[20230805-21:25:23] [DEBUG] return value from xrdp_mm_connect 0
[20230805-21:25:23] [INFO ] xrdp_wm_log_msg: login successful for display 14
[20230805-21:25:23] [DEBUG] xrdp_wm_log_msg: started connecting
[20230805-21:25:27] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:30] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:34] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:37] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:41] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:44] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:45] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:25:47] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:25:47] [DEBUG] xrdp_wm_log_msg: some problem
[20230805-21:25:47] [DEBUG] xrdp_mm_module_cleanup
[20230805-21:25:47] [DEBUG] Closed socket 18 (AF_INET6 ::1 port 42304)
[20230805-21:25:47] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:25:48] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:25:48] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:25:48] [INFO ] xrdp_listen_pp done
[20230805-21:25:48] [DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
[20230805-21:25:50] [INFO ] starting xrdp with pid 2251
[20230805-21:25:50] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:25:50] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:25:50] [INFO ] xrdp_listen_pp done
[20230805-21:25:52] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.172 port 54986
[20230805-21:25:52] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:25:52] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:25:52] [INFO ] Socket 12: AF_INET6 connection received from fdbc:fbea:f52c:0:8532:4807:1c19:5cc2 port 54987
[20230805-21:25:52] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230805-21:25:52] [DEBUG] Closed socket 12 (AF_INET6 fdbc:fbea:f52c::59c2 port 3389)
[20230805-21:25:52] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230805-21:25:52] [DEBUG] TLSv1.3 enabled
[20230805-21:25:52] [DEBUG] TLSv1.2 enabled
[20230805-21:25:52] [DEBUG] Security layer: requested 11, selected 1
[20230805-21:25:52] [INFO ] connected client computer name: LAPTOP-EE7KL8B9
[20230805-21:25:52] [INFO ] adding channel item name rdpdr chan_id 1004 flags 0x80800000
[20230805-21:25:52] [INFO ] adding channel item name rdpsnd chan_id 1005 flags 0xc0000000
[20230805-21:25:52] [INFO ] adding channel item name cliprdr chan_id 1006 flags 0xc0a00000
[20230805-21:25:52] [INFO ] adding channel item name drdynvc chan_id 1007 flags 0xc0800000
[20230805-21:25:52] [INFO ] TLS connection established from ::ffff:192.168.1.172 port 54986: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384
[20230805-21:25:52] [DEBUG] xrdp_000008cc_wm_login_mode_event_00000001
[20230805-21:25:52] [INFO ] Cannot find keymap file /etc/xrdp/km-00000804.ini
[20230805-21:25:52] [INFO ] Loading keymap file /etc/xrdp/km-00000409.ini
[20230805-21:25:52] [WARN ] local keymap file for 0x00000804 found and doesn’t match built in keymap, using local keymap file
[20230805-21:25:54] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20230805-21:25:54] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230805-21:25:54] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait…
[20230805-21:25:54] [DEBUG] return value from xrdp_mm_connect 0
[20230805-21:25:55] [INFO ] xrdp_wm_log_msg: login successful for display 15
[20230805-21:25:55] [DEBUG] xrdp_wm_log_msg: started connecting
[20230805-21:25:58] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:02] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:05] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:09] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:12] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:16] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:19] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:23] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:26] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:30] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:34] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:37] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:41] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:44] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:48] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:51] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:55] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:58] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:26:59] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:27:01] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:27:01] [DEBUG] xrdp_wm_log_msg: some problem
[20230805-21:27:01] [DEBUG] xrdp_mm_module_cleanup
[20230805-21:27:01] [DEBUG] Closed socket 18 (AF_INET6 ::1 port 42306)
[20230805-21:27:01] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:27:01] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:27:01] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:27:01] [INFO ] xrdp_listen_pp done
[20230805-21:27:01] [DEBUG] Closed socket 7 (AF_INET6 :: port 3389)
[20230805-21:27:03] [INFO ] starting xrdp with pid 2292
[20230805-21:27:03] [INFO ] address [0.0.0.0] port [3389] mode 1
[20230805-21:27:03] [INFO ] listening to port 3389 on 0.0.0.0
[20230805-21:27:03] [INFO ] xrdp_listen_pp done
[20230805-21:31:53] [INFO ] Socket 12: AF_INET6 connection received from ::ffff:192.168.1.110 port 58412
[20230805-21:31:53] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
[20230805-21:31:53] [DEBUG] Closed socket 11 (AF_INET6 :: port 3389)
[20230805-21:31:53] [INFO ] Using default X.509 certificate: /etc/xrdp/cert.pem
[20230805-21:31:53] [INFO ] Using default X.509 key file: /etc/xrdp/key.pem
[20230805-21:31:53] [DEBUG] TLSv1.3 enabled
[20230805-21:31:53] [DEBUG] TLSv1.2 enabled
[20230805-21:31:53] [DEBUG] Security layer: requested 11, selected 1
[20230805-21:31:58] [INFO ] connected client computer name: PHP110
[20230805-21:31:58] [INFO ] adding channel item name rdpdr chan_id 1004 flags 0x80800000
[20230805-21:31:58] [INFO ] adding channel item name rdpsnd chan_id 1005 flags 0xc0000000
[20230805-21:31:58] [INFO ] adding channel item name cliprdr chan_id 1006 flags 0xc0a00000
[20230805-21:31:58] [INFO ] adding channel item name drdynvc chan_id 1007 flags 0xc0800000
[20230805-21:31:58] [INFO ] TLS connection established from ::ffff:192.168.1.110 port 58412: TLSv1.2 with cipher ECDHE-RSA-AES256-GCM-SHA384
[20230805-21:31:58] [DEBUG] xrdp_000008f9_wm_login_mode_event_00000001
[20230805-21:31:58] [INFO ] Loading keymap file /etc/xrdp/km-00000409.ini
[20230805-21:31:58] [WARN ] local keymap file for 0x00000409 found and doesn’t match built in keymap, using local keymap file
[20230805-21:32:10] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20230805-21:32:10] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230805-21:32:10] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait…
[20230805-21:32:10] [DEBUG] return value from xrdp_mm_connect 0
[20230805-21:32:12] [INFO ] xrdp_wm_log_msg: login failed for display 0
[20230805-21:32:12] [DEBUG] xrdp_mm_module_cleanup
[20230805-21:32:12] [DEBUG] Closed socket 18 (AF_INET6 ::1 port 42308)
[20230805-21:32:32] [DEBUG] xrdp_wm_log_msg: connecting to sesman ip 127.0.0.1 port 3350
[20230805-21:32:32] [INFO ] xrdp_wm_log_msg: sesman connect ok
[20230805-21:32:32] [DEBUG] xrdp_wm_log_msg: sending login info to session manager, please wait…
[20230805-21:32:32] [DEBUG] return value from xrdp_mm_connect 0
[20230805-21:32:33] [INFO ] xrdp_wm_log_msg: login successful for display 16
[20230805-21:32:33] [DEBUG] xrdp_wm_log_msg: started connecting
[20230805-21:32:36] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:32:40] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:32:43] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:32:47] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:32:50] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:32:54] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:32:57] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:01] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:04] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:08] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:11] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:15] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:18] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:22] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:26] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:29] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:33] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:36] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:40] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:43] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:47] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:50] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:54] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:33:57] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:01] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:04] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:08] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:11] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:15] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:18] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:22] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:25] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:29] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:32] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:36] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:39] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:43] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:47] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:50] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:54] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:34:57] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:01] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:04] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:08] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:11] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:15] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:18] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:22] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:25] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:29] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:32] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:36] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:39] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:43] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:46] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:50] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:53] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:35:57] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:36:01] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:36:04] [DEBUG] xrdp_wm_log_msg: connection problem, giving up
[20230805-21:36:04] [DEBUG] Closed socket 19 (AF_UNIX)
[20230805-21:36:04] [DEBUG] xrdp_wm_log_msg: some problem
[20230805-21:36:04] [DEBUG] xrdp_mm_module_cleanup
[20230805-21:36:04] [DEBUG] Closed socket 18 (AF_INET6 ::1 port 42310)
[20230805-21:36:04] [DEBUG] Closed socket 12 (AF_INET6 ::ffff:192.168.1.151 port 3389)
I’m having the same problem after upgrading Debian bullseye CLI from GitHub to bookworm (changing inside sources.list and radxa.list). xrdp stopped working.
after adding rock to tty group i’m taking this error on Xorg logs (inside userdir)
xf86OpenConsole: Cannot open virtual console 2 (Permission denied)
When I try to modify /dev/tty2 permission or ownership, I take
Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices
It seems to be a problem in current kernel.
uname -a returns
Linux rock-5b 6.1.43-12-rk2312 #64ff16134 SMP Thu Jun 27 07:32:21 UTC 2024 aarch64 GNU/Linux
anything else that could help to investigate?
