系统:rock-5b_debian_bullseye_kde_b36.img
kernel:linux-5.10-gen-rkr3.4
命令:sudo dpkg -i linux-image-5.10.110-12-rockchip-g82f5f5cb8c6d_5.10.110-12-rockchip_arm64.deb
再次重启就进不了系统了
root@rock-5b:/home/rock/packages# sudo dpkg -i linux-image-5.10.110-12-rockchip-g82f5f5cb8c6d_5.10.110-12-rockchi p_arm64.deb
(Reading database ... 146518 files and directories currently installed.)
Preparing to unpack linux-image-5.10.110-12-rockchip-g82f5f5cb8c6d_5.10.110-12-rockchip_arm64.deb ...
Unpacking linux-image-5.10.110-12-rockchip-g82f5f5cb8c6d (5.10.110-12-rockchip) over (5.10.110-12-rockchip) ...
P: Checking for EXTLINUX directory... found.
P: Writing config for vmlinuz-5.10.110-12-rockchip-g82f5f5cb8c6d.dpkg-tmp...
P: Writing config for vmlinuz-5.10.110-12-rockchip-g82f5f5cb8c6d...
P: Writing config for vmlinuz-5.10.110-11-rockchip...
Setting up linux-image-5.10.110-12-rockchip-g82f5f5cb8c6d (5.10.110-12-rockchip) ...
dkms: running auto installation service for kernel 5.10.110-12-rockchip-g82f5f5cb8c6d:
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
make -j8 KERNELRELEASE=5.10.110-12-rockchip-g82f5f5cb8c6d -C /lib/modules/5.10.110-12-rockchip-g82f5f5cb8c6d/buil d M=/var/lib/dkms/8852be/1.15.10.0.5.0-3/build....(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.10.110-12-rockchip-g82f5f5cb8c6d (aarch64)
Consult /var/lib/dkms/8852be/1.15.10.0.5.0-3/build/make.log for more information.
Building module:
make -j8 KERNELRELEASE=5.10.110-12-rockchip-g82f5f5cb8c6d -C /lib/modules/5.10.110-12-rockchip-g82f5f5cb8c6d/build M=/var/lib/dkms/8852bu/1.15.7.112-2/build.....(bad exit status: 2)
Consult /var/lib/dkms/8852bu/1.15.7.112-2/build/make.log for more information.
Building module:
make -j8 KERNELRELEASE=5.10.110-12-rockchip-g82f5f5cb8c6d -C /lib/modules/5.10.110-12-rockchip-g82f5f5cb8c6d/build M=/var/lib/dkms/r8125/9.010.01/build.....(bad exit status: 2)
Consult /var/lib/dkms/r8125/9.010.01/build/make.log for more information.
Building module:
make -j8 KERNELRELEASE=5.10.110-12-rockchip-g82f5f5cb8c6d -C /lib/modules/5.10.110-12-rockchip-g82f5f5cb8c6d/build M=/var/lib/dkms/rtk_btusb/20220330-1/build....(bad exit status: 2)
Consult /var/lib/dkms/rtk_btusb/20220330-1/build/make.log for more information.
update-initramfs: Generating /boot/initrd.img-5.10.110-12-rockchip-g82f5f5cb8c6d
Updating overlays for 5.10.110-12-rockchip-g82f5f5cb8c6d ...
P: Updating /boot/extlinux/extlinux.conf...
Decompressing /boot/vmlinuz-5.10.110-12-rockchip-g82f5f5cb8c6d ...
