used a USB3 Ethernet/HUB with compatible Realtek Chipset
–plugged in USB with ESXi Installer
–plugged in USB for ESXi install target
–plugged in Cat5
–plugged in USB Keyboard into hub ( Required for install ----> 2 USB thumb drives & the KBD all into the hub )
Install ESXi
–select USB NIC deselect the onboard NIC
–regular ESXi install otherwise
Remove install USB and re-boot
Also, there is a much simpler install of Proxmox on the Rock5A & Rock5B Checck my prior posts
Wow!
It’s inspiring
Hm. Making host with x4 physical ram (even slower) for about $300 and 30-50W power consumption gives me a lot of opportunities
Thank you
You sent me down a rabbit hole, but I appreciate the challenge and have learned some things.
I have both the Rock5a & Rock5B booting ESXi 8
The Rock5a does not need a USB nic, but the Rock5B needs a USB nic, could explore adding drivers for the nic, but not there yet.
The Rock5a boots from a thumb drive, the Roc5B will boot from the NVME, but I was only able to install ESXi8 to the NVME while it was in a USB case, then screw it on to the board & ofcoarse both require the correct UEFI from https://github.com/edk2-porting/edk2-rk3588?tab=readme-ov-file
