i have 2 emmc modules by radxa. (both confirmed working on a 4C+).
unfortunately i cant get the 4D to boot from EMMC.
i noted the hint on the docu page stating, emmc wont work due to the default image on the SPI.
So i erased it via RKDevTools.
After that i tried both emmc with different images(the 4k block size for UFS and the standard 512 image). It won’t boot with any of it.
The blue led stays off when the SPI is empty.
After flashing the img to the SPI again, i tried both again - same result, but the blue led turns on but keeps on (no blinking)
For the ROCK 4D with SPI Flash soldered, it can not support eMMC Module because the SPI Flash and eMMC share the same pin. This is what we don’t like for RK3576 and RK3588s and we reported it to Rockchip but they don’t think it’s a problem.
Only the ROCK 4D without on board SPI flash can support eMMC module or UFS module.
Technically you’re saying Radxa cannot build even a custom board for us (given the volumes to be above 500 units) which can support eMMC module?
If this is true, then whats the way to have eMMC modules on Rock 4D and Rock 5C boards? And why eMMC slot is present on the boards at all? Also its written in the specs in Radxa website that it supports eMMC.
