I am trying to interface with the ROCK 4’s VPU via V4L2. I am running Linux 6.1 which provides two drivers that provide this interface, the hantro (mainlined in 6.0, supporting MPEG2 & VP8 decode on the RK3399’s VPU) driver, as well as the staging rkvdec driver (providing H264 & VP9 decode capability).
When I query the available V4L2 to devices via v4l2-ctl, though, the devices describe different capabilities:
/dev/video1, provided by rkvdec can only convert NV12 to H264 slices, i.e., it can encode raw data. -
/dev/video2, provided by hantro as ‘rk3399-vpu-enc-source’, but advertises JPEG as its only input and YM12, NM12, YUYV, and UYVY as possible targets, which would make it a decoder (I assume?) -
/dev/video3, provided by hantro as ‘rk3399-vpu-dec-source’ advertises conversion of NV12 to MPEG2 Slices, making it an encoder.
For completeness: there is a /dev/video0, provided by the rockchip-rga driver and two devices video-dec0 and video-{enc,dec}0 of unknown origin (they don’t appear to offer v4l2 capabilites and can’t be successfully probed by udevadm).
I am at a bit of a loss here, both because I don’t understand the mismatch between what I’d expect looking at the kernel, as well as the seemingly mislabeled driver devices. Am I doing something wrong here?
Thanks!
v4l2-ctl -d /dev/video1 --all:
Driver Info:
Driver name : rkvdec
Card type : rkvdec
Bus info : platform:rkvdec
Driver version : 6.1.24
Capabilities : 0x84204000
Video Memory-to-Memory Multiplanar
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04204000
Streaming
Extended Pix Format
Media Driver Info:
Model : rkvdec
Serial :
Media version : 6.1.24
Hardware revision: 0x00000000 (0)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Pad 0x01000002 : 0: Source
Link 0x02000008: to remote pad 0x1000004 of entity 'rkvdec-proc': Data, Enabled, Immutable
Priority: 2
Format Video Capture Multiplanar:
Width/Height : 48/48
Pixel Format : 'NV12' (Y/UV 4:2:0)
Field : None
Number of planes : 1
Flags :
Colorspace : Rec. 709
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
Plane 0 :
Bytes per Line : 48
Size Image : 4608
Format Video Output Multiplanar:
Pixel Format : 'S264' (H.264 Parsed Slice Data)
Field : None
Flags :
Plane 0 :
Bytes per Line : 0
Size Image : 4608
Codec Controls
h264_level 0x00990a67 (menu) : min=0 max=15 default=0 value=0
0: 1
1: 1b
2: 1.1
3: 1.2
4: 1.3
5: 2
6: 2.1
7: 2.2
8: 3
9: 3.1
10: 3.2
11: 4
12: 4.1
13: 4.2
14: 5
15: 5.1
h264_profile 0x00990a6b (menu) : min=0 max=4 default=2 value=2
0: Baseline
1: Constrained Baseline
2: Main
4: High
vp9_profile 0x00990b00 (menu) : min=0 max=0 default=0 value=0
0: 0
Stateless Codec Controls
h264_decode_mode 0x00a40900 (menu) : min=1 max=1 default=1 value=1
1: Frame-Based
h264_start_code 0x00a40901 (menu) : min=1 max=1 default=1 value=1
1: Annex B Start Code
h264_sequence_parameter_set 0x00a40902 (unknown): type=200 flags=has-payload
h264_picture_parameter_set 0x00a40903 (unknown): type=201 flags=has-payload
h264_scaling_matrix 0x00a40904 (unknown): type=202 flags=has-payload
h264_decode_parameters 0x00a40907 (unknown): type=204 flags=has-payload
vp9_frame_decode_parameters 0x00a40a2c (unknown): type=261 flags=has-payload
vp9_probabilities_updates 0x00a40a2d (unknown): type=260 flags=has-payload
v4l2-ctl -d /dev/video2 --all:
Driver Info:
Driver name : hantro-vpu
Card type : rockchip,rk3399-vpu-enc
Bus info : platform: hantro-vpu
Streaming
Extended Pix Format
Device Capabilities
Streaming
Extended Pix Format
Media Driver Info:
Model : hantro-vpu
Serial :
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Link 0x02000008: to remote pad 0x1000004 of entity 'rockchip,rk3399-vpu-enc-proc': Data, Enabled, Immutable
Priority: 2
Width/Height : 96/32
Pixel Format : 'JPEG' (JFIF JPEG)
Field : None
Flags :
Colorspace : JPEG
Plane 0 :
Bytes per Line : 0
Size Image : 6768
Pixel Format : 'YM12' (Planar YUV 4:2:0 (N-C))
Field : None
Number of planes : 3
Flags :
Colorspace : JPEG
Plane 0 :
Bytes per Line : 96
Size Image : 3072
Plane 1 :
Bytes per Line : 48
Size Image : 768
Plane 2 :
Bytes per Line : 48
Size Image : 768
Selection Video Output: crop, Left 0, Top 0, Width 96, Height 32, Flags:
Selection Video Output: crop_default, Left 0, Top 0, Width 96, Height 32, Flags:
Selection Video Output: crop_bounds, Left 0, Top 0, Width 96, Height 32, Flags:
JPEG Compression Controls
compression_quality 0x009d0903 (int) : min=5 max=100 step=1 default=50 value=50
active_markers 0x009d0904 (bitmask): max=0x00070001 default=0x00070001 value=0x00070001
v4l2-ctl -d /dev/video3 --all:
Driver Info:
Card type : rockchip,rk3399-vpu-dec
Streaming
Extended Pix Format
Device Capabilities
Streaming
Extended Pix Format
Media Driver Info:
Model : hantro-vpu
Serial :
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Pad 0x01000010 : 0: Source
Link 0x02000016: to remote pad 0x1000012 of entity 'rockchip,rk3399-vpu-dec-proc': Data, Enabled, Immutable
Priority: 2
Field : None
Flags :
Colorspace : JPEG
Plane 0 :
Bytes per Line : 48
Size Image : 3456
Pixel Format : 'MG2S' (MPEG-2 Parsed Slice Data)
Field : None
Flags :
Colorspace : JPEG
Plane 0 :
Bytes per Line : 0
Size Image : 4608
vp8_frame_parameters 0x00a409c8 (unknown): type=240 flags=has-payload
mpeg_2_sequence_header 0x00a409dc (unknown): type=251 flags=has-payload
mpeg_2_picture_header 0x00a409dd (unknown): type=252 flags=has-payload
mpeg_2_quantisation_matrices 0x00a409de (unknown): type=250 flags=has-payload
