we burn rock3a (v1.3.1) using image:<rock-3a-ubuntu-focal-server-arm64-20221101-0219-gpt.img.xz>.
We found that PCIe Host initialization failed after the board was started.
How do I fix this Without changing the kernel version?
Thanks.
kernel version:
root@rock-3a:~# uname -a
Linux rock-3a 4.19.193-58-rockchip-gbac1feba87f0 #rockchip SMP Tue Oct 18 09:36:57 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
root@rock-3a:~#
pcie log:
[ 0.144991] pcie30_avdd0v9: 900 mV
[ 0.145172] reg-fixed-voltage pcie30-avdd0v9: Looking up vin-supply from device tree
[ 0.145186] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.145362] reg-fixed-voltage pcie30-avdd0v9: pcie30_avdd0v9 supplying 900000uV
[ 0.145514] pcie30_avdd1v8: 1800 mV
[ 0.145698] reg-fixed-voltage pcie30-avdd1v8: Looking up vin-supply from device tree
[ 0.145741] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.145921] reg-fixed-voltage pcie30-avdd1v8: pcie30_avdd1v8 supplying 1800000uV
[ 0.147050] pcie30_3v3: 100 <--> 3300 mV at 3300 mV
[ 0.480662] rk-pcie 3c0000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.480809] rk-pcie 3c0000000.pcie: Linked as a consumer to regulator.10
[ 0.481185] rk-pcie 3c0800000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.481286] rk-pcie 3c0800000.pcie: Linked as a consumer to regulator.10
[ 0.481298] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[ 0.481388] rk-pcie 3c0000000.pcie: Missing *config* reg space
[ 0.481432] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[ 0.481494] rk-pcie 3c0000000.pcie: err 0x300000000..0x3007fffff -> 0x00000000
[ 0.481551] rk-pcie 3c0000000.pcie: IO 0x300800000..0x3008fffff -> 0x00800000
[ 0.481606] rk-pcie 3c0000000.pcie: MEM 0x300900000..0x33fffffff -> 0x00900000
[ 0.493431] rk-pcie 3c0800000.pcie: missing legacy IRQ resource
[ 0.493489] rk-pcie 3c0800000.pcie: Missing *config* reg space
[ 0.493532] rk-pcie 3c0800000.pcie: host bridge /pcie@fe280000 ranges:
[ 0.493599] rk-pcie 3c0800000.pcie: err 0x380000000..0x3807fffff -> 0x80000000
[ 0.493684] rk-pcie 3c0800000.pcie: IO 0x380800000..0x3808fffff -> 0x80800000
[ 0.493740] rk-pcie 3c0800000.pcie: MEM 0x380900000..0x3bfffffff -> 0x80900000
[ 1.500353] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 1.500358] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 2.513751] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 2.540389] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 3.553680] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 3.587010] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 4.567024] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 4.620375] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 5.580503] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 5.633750] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 6.593719] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x1
[ 6.647046] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 7.607057] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 7.660433] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 8.620447] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 8.673766] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x1
[ 9.633807] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 9.687101] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 10.647009] rk-pcie 3c0000000.pcie: PCIe Linking... LTSSM is 0x0
[ 10.700421] rk-pcie 3c0800000.pcie: PCIe Linking... LTSSM is 0x0
[ 11.660543] rk-pcie 3c0000000.pcie: PCIe Link Fail
[ 11.665903] rk-pcie 3c0000000.pcie: failed to initialize host
[ 11.713878] rk-pcie 3c0800000.pcie: PCIe Link Fail
[ 11.718550] rk-pcie 3c0800000.pcie: failed to initialize host
