Question:
Did anyone experience the same behavior?
And if so, what can be done about?
I’m using a most recent rock3a (November 2021 delivery) with RADXA Ubuntu 20.04 with 3 HDDs (sda is a SSD) mounted and running on the - unfortunately still nonfunctional PENTA SATA HAT -
Once in a while 6 to 8 Hours after boot the whole thing (NO OVERHEATING detected yet) falls unresponsive to any external command with blue Led constantly blinking.
I need to reboot via Power Off and it takes about 5 Minutes for it , to return to life after this.
After a normal reboot the thing is back online within less then 30 seconds.
Curretly I’m booting from SD CARD
Could be lots of things:
- Out of Memory crash? (swap set-up?)
- Hibernation set-up?
Any information in the logs? (/var/log)
Out of Memory crash? (swap set-up?) NO! just SAMBA and NFS running
Hibernation set-up? Random Hybernation ??"Any information in the logs? (/var/log) That may take some time to analyze not really knowing what to look for!
I have 5 rock3a pi’s running k3s with ssd and fails often, seems to be missing kernel causing it. I don’t have the same with the rock4c those ones just works. I thought it’s either overheating or the missing network bridge kernel module. Hybernation makes sense but how do I check this?
