内核部分:
commit id: 526c758e05e0
在关机或者重启的时候出现以下情况,在watchdog0超时以后触发重置
[ 22.460242] watchdog: watchdog0: watchdog did not stop!
[ 83.748310] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 83.748875] rcu: 2-...0: (1 GPs behind) idle=f8a/1/0x4000000000000000 softirq=3966/3967 fqs=5936
[ 83.749661] rcu: (detected by 3, t=18002 jiffies, g=3853, q=289)
[ 83.750224] Call trace:
[ 83.750468] __switch_to+0xc4/0x128
[ 83.750782] 0xffffff800803bb48
u-boot部分:
在插着一个没有系统的nvme盘的时候无法启动
U-Boot SPL board init
U-Boot SPL 2017.09-gf48bdfd82a-211223 #aghost (Dec 31 2021 - 21:09:55)
unknown raw ID phN
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(fe4f274c06...) + OK
## Checking uboot 0x00a00000 ... sha256(6d803699cb...) + OK
## Checking fdt 0x00b2f250 ... sha256(ed0e2abb0d...) + OK
## Checking atf-2 0x00068000 ... sha256(8d44036095...) + OK
## Checking atf-3 0xfdcd0000 ... sha256(e410275b51...) + OK
## Checking atf-4 0xfdcc9000 ... sha256(990c53fc01...) + OK
## Checking atf-5 0x00066000 ... sha256(315a4195a9...) + OK
Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000)
Total: 244.986 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-181-gc9a647cae:cl
NOTICE: BL31: Built : 10:55:41, Oct 18 2021
INFO: pmu v1 is valid
INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz
INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz
INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz
INFO: boot cpu mask: 0
INFO: Entry point address = 0xa00000
INFO: SPSR = 0x3c9
U-Boot 2017.09-gf48bdfd82a-211223 #aghost (Dec 31 2021 - 21:09:55 +0800)
Model: Radxa ROCK 3 Model A
PreSerial: 2, raw, 0xfe660000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: ed349000
Relocation fdt: eb9f6f20 - eb9fecd0
CR: M/C/I
Using default environment
Bootdev: nvme 0
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
No resource partition
Failed to load DTB, ret=-19
Failed to get kernel dtb, ret=-19
I2c0 speed: 100000Hz
vsel-gpios- not found! Error: -2
vdd_cpu 1025000 uV
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
of_get_regulator: Get (vccio3-supply) regulator: 0 failed, ret=-19
of_get_regulator: Get (vccio5-supply) regulator: 0 failed, ret=-19
of_get_regulator: Get (vccio7-supply) regulator: 0 failed, ret=-19
io-domain: OK
rockchip_set_ethaddr: vendor_storage_write failed -19
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
apll 816000 KHz
dpll 528000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 24000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 50000 KHz
aclk_top_high 300000 KHz
aclk_top_low 200000 KHz
hclk_top 150000 KHz
pclk_top 50000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
No misc partition
Net: No ethernet found.
Hit key to stop autoboot('CTRL+C'): 0
Device 0: Vendor: 0x14a4 Rev: 1.01 Prod: P02738110277
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
... is now current device
Scanning nvme 0:1...
no mmc device at slot 1
no mmc device at slot 0
starting USB...
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
## Booting FIT Image FIT: No boot partition
FIT: No FIT image
Could not find misc partition
ANDROID: reboot reason: "(none)"
optee check api revision fail: -1.0
optee api revision is too low
### ERROR ### Please RESET the board ###
