Can I boot android (downloaded from official page https://wiki.radxa.com/Rock3/downloads) from SD card after flashing it with Etcher? Or should I build image using this tutorial (https://wiki.radxa.com/Rock3/Android11)
Yes, you can just write the Android image to SD card with Etcher and boot.
Hi jack
I write the Android image to SD card using etcher and boot, but an error happens when boot. Do you know what’s the reason?
Another question is: does android support ethernet for accessing internet through internet cable? If yes, what’s the dts configuration for this?
Thanks
For the boot error, can you take a picture?
Yes, ethernet is enabled by default.
HI Jack
the boot error is like below attached log.
Thanksboot.zip (25.8 KB)
first boot itsrecovery then it arrange the partions and reboots at the end
then it boot and you have to wait a little to pass the kernel bootscreen
I’m a newer of OS, I can only describe the phenomenon. The android OS will loop reboot again and again. The log is what I have pasted in attachment. Does anyone can give some advice about this issue?
