Enabled hardware acceleration in Chrome!
Please share glmark2 score on bsp kernel. I will try to get some score on panfrost with mainline kernel.
Ok,I will do it…
In case you want to compare: xfce 1080p
glmark2-es2
arm_release_ver of this libmali is 'g2p0-01eac0', rk_so_ver is '4'.
glmark2 2021.02
OpenGL Information
GL_VENDOR: ARM
GL_RENDERER: Mali-G52
GL_VERSION: OpenGL ES 3.2 v1.g2p0-01eac0.327c41db9c110a33ae6f67b4cc0581c7
[build] use-vbo=false: FPS: 55 FrameTime: 18.182 ms
[build] use-vbo=true: FPS: 57 FrameTime: 17.544 ms
[texture] texture-filter=nearest: FPS: 58 FrameTime: 17.241 ms
[texture] texture-filter=linear: FPS: 57 FrameTime: 17.544 ms
[texture] texture-filter=mipmap: FPS: 58 FrameTime: 17.241 ms
[shading] shading=gouraud: FPS: 55 FrameTime: 18.182 ms
[shading] shading=blinn-phong-inf: FPS: 54 FrameTime: 18.519 ms
[shading] shading=phong: FPS: 55 FrameTime: 18.182 ms
[shading] shading=cel: FPS: 55 FrameTime: 18.182 ms
[bump] bump-render=high-poly: FPS: 54 FrameTime: 18.519 ms
[bump] bump-render=normals: FPS: 58 FrameTime: 17.241 ms
[bump] bump-render=height: FPS: 57 FrameTime: 17.544 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 55 FrameTime: 18.182 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 54 FrameTime: 18.519 ms
[pulsar] light=false:quads=5:texture=false: FPS: 57 FrameTime: 17.544 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 43 FrameTime: 23.256 ms
[desktop] effect=shadow:windows=4: FPS: 54 FrameTime: 18.519 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 36 FrameTime: 27.778 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 35 FrameTime: 28.571 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 34 FrameTime: 29.412 ms
[ideas] speed=duration: FPS: 38 FrameTime: 26.316 ms
[jellyfish] <default>: FPS: 55 FrameTime: 18.182 ms
[terrain] <default>: FPS: 20 FrameTime: 50.000 ms
[shadow] <default>: FPS: 54 FrameTime: 18.519 ms
[refract] <default>: FPS: 30 FrameTime: 33.333 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 58 FrameTime: 17.241 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 57 FrameTime: 17.544 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 58 FrameTime: 17.241 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 58 FrameTime: 17.241 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 56 FrameTime: 17.857 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 57 FrameTime: 17.544 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 57 FrameTime: 17.544 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 56 FrameTime: 17.857 ms
glmark2 Score: 51
glmark2
libGL error: unable to load driver: rockchip_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: rockchip
** GLX does not support GLX_EXT_swap_control or GLX_MESA_swap_control!
** Failed to set swap interval. Results may be bounded above by refresh rate.
glmark2 2021.02
OpenGL Information
GL_VENDOR: VMware, Inc.
GL_RENDERER: llvmpipe (LLVM 7.0, 128 bits)
GL_VERSION: 3.1 Mesa 18.3.6
[build] use-vbo=false: FPS: 74 FrameTime: 13.514 ms
[build] use-vbo=true: FPS: 71 FrameTime: 14.085 ms
[texture] texture-filter=nearest: FPS: 111 FrameTime: 9.009 ms
[texture] texture-filter=linear: FPS: 108 FrameTime: 9.259 ms
[texture] texture-filter=mipmap: FPS: 101 FrameTime: 9.901 ms
[shading] shading=phong: FPS: 48 FrameTime: 20.833 ms
[shading] shading=cel: FPS: 48 FrameTime: 20.833 ms
[bump] bump-render=high-poly: FPS: 26 FrameTime: 38.462 ms
[bump] bump-render=normals: FPS: 121 FrameTime: 8.264 ms
[bump] bump-render=height: FPS: 117 FrameTime: 8.547 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 57 FrameTime: 17.544 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 40 FrameTime: 25.000 ms
[pulsar] light=false:quads=5:texture=false: FPS: 101 FrameTime: 9.901 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 14 FrameTime: 71.429 ms
[desktop] effect=shadow:windows=4: FPS: 35 FrameTime: 28.571 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 37 FrameTime: 27.027 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 40 FrameTime: 25.000 ms
[ideas] speed=duration: FPS: 33 FrameTime: 30.303 ms
[jellyfish] <default>: FPS: 28 FrameTime: 35.714 ms
[terrain] <default>: FPS: 1 FrameTime: 1000.000 ms
[shadow] <default>: FPS: 37 FrameTime: 27.027 ms
[refract] <default>: FPS: 4 FrameTime: 250.000 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 68 FrameTime: 14.706 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 59 FrameTime: 16.949 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 66 FrameTime: 15.152 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 64 FrameTime: 15.625 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 58 FrameTime: 17.241 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 62 FrameTime: 16.129 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 63 FrameTime: 15.873 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 58 FrameTime: 17.241 ms
glmark2 Score: 57
How to enable that? I have Rock3A 2GB and 4GB versions, can it be done?
What do you use to enable this? Panfrost driver? Any documentation/info? @gacktex
