Great!! 补上P2的dts,看有没有能参考的
/dts-v1/;
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/pwm/pwm.h>
#include <dt-bindings/pinctrl/rockchip.h>
#include <dt-bindings/input/rk-input.h>
#include <dt-bindings/display/drm_mipi_dsi.h>
#include <dt-bindings/sensor-dev.h>
#include "rk3568.dtsi"
#include "rk3568-linux.dtsi"
compatible = "rockchip,rk3568-firefly-core", "rockchip,rk3568";
audiopwmout_diff: audiopwmout-diff {
status = "disabled";
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "rockchip,audiopwmout-diff";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,bitclock-master = <&master>;
simple-audio-card,frame-master = <&master>;
simple-audio-card,cpu {
sound-dai = <&i2s3_2ch>;
master: simple-audio-card,codec {
sound-dai = <&dig_acodec>;
dc_12v: dc-12v {
compatible = "regulator-fixed";
regulator-name = "dc_12v";
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
hdmi_sound: hdmi-sound {
simple-audio-card,mclk-fs = <128>;
simple-audio-card,name = "rockchip,hdmi";
sound-dai = <&i2s0_8ch>;
sound-dai = <&hdmi>;
pdmics: dummy-codec {
compatible = "rockchip,dummy-codec";
#sound-dai-cells = <0>;
pdm_mic_array: pdm-mic-array {
simple-audio-card,name = "rockchip,pdm-mic-array";
sound-dai = <&pdm>;
sound-dai = <&pdmics>;
rk809_sound: rk809-sound {
status = "okay";
simple-audio-card,name = "rockchip,rk809-codec";
simple-audio-card,widgets =
"Microphone", "Mic Jack",
"Headphone", "Headphone Jack";
simple-audio-card,routing =
"Mic Jack", "MICBIAS1",
"IN1P", "Mic Jack",
"Headphone Jack", "HPOL",
"Headphone Jack", "HPOR";
sound-dai = <&i2s1_8ch>;
sound-dai = <&rk809_codec>;
spdif-sound {
status = "okay";
simple-audio-card,name = "ROCKCHIP,SPDIF";
sound-dai = <&spdif_8ch>;
sound-dai = <&spdif_out>;
spdif_out: spdif-out {
status = "okay";
compatible = "linux,spdif-dit";
vad_sound: vad-sound {
compatible = "rockchip,multicodecs-card";
rockchip,card-name = "rockchip,rk3568-vad";
rockchip,cpu = <&i2s1_8ch>;
rockchip,codec = <&rk809_codec>, <&vad>;
vcc3v3_sys: vcc3v3-sys {
regulator-name = "vcc3v3_sys";
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&dc_12v>;
vcc5v0_sys: vcc5v0-sys {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&vcc5v0_host_en>;
regulator-name = "vcc5v0_host";
vcc5v0_otg: vcc5v0-otg-regulator {
enable-active-high;
gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_otg_en>;
regulator-name = "vcc5v0_otg";
vcc3v3_lcd0_n: vcc3v3-lcd0-n {
regulator-name = "vcc3v3_lcd0_n";
regulator-boot-on;
regulator-state-mem {
regulator-off-in-suspend;
vcc3v3_lcd1_n: vcc3v3-lcd1-n {
regulator-name = "vcc3v3_lcd1_n";
regulator-boot-on;
test-power {
status = "okay";
&cpu0 {
cpu-supply = <&vdd_cpu>;
&dfi {
status = "okay";
&dmc {
center-supply = <&vdd_logic>;
&gpu {
mali-supply = <&vdd_gpu>;
status = "okay";
&hdmi {
status = "okay";
&hdmi_in_vp0 {
status = "okay";
&hdmi_in_vp1 {
&hdmi_sound {
status = "okay";
&i2c0 {
status = "okay";
vdd_cpu: tcs4525@1c {
compatible = "tcs,tcs452x";
reg = <0x1c>;
vin-supply = <&vcc5v0_sys>;
regulator-compatible = "fan53555-reg";
regulator-name = "vdd_cpu";
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1390000>;
regulator-ramp-delay = <2300>;
fcs,suspend-voltage-selector = <1>;
regulator-boot-on;
rk809: pmic@20 {
compatible = "rockchip,rk809";
reg = <0x20>;
interrupt-parent = <&gpio0>;
interrupts = <3 IRQ_TYPE_LEVEL_LOW>;
pinctrl-names = "default", "pmic-sleep",
"pmic-power-off", "pmic-reset";
pinctrl-0 = <&pmic_int>;
pinctrl-1 = <&soc_slppin_slp>, <&rk817_slppin_slp>;
pinctrl-2 = <&soc_slppin_gpio>, <&rk817_slppin_pwrdn>;
pinctrl-3 = <&soc_slppin_gpio>, <&rk817_slppin_rst>;
rockchip,system-power-controller;
wakeup-source;
#clock-cells = <1>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
//fb-inner-reg-idxs = <2>;
/* 1: rst regs (default in codes), 0: rst the pmic */
pmic-reset-func = <0>;
/* not save the PMIC_POWER_EN register in uboot */
not-save-power-en = <1>;
vcc1-supply = <&vcc3v3_sys>;
vcc2-supply = <&vcc3v3_sys>;
vcc3-supply = <&vcc3v3_sys>;
vcc4-supply = <&vcc3v3_sys>;
vcc5-supply = <&vcc3v3_sys>;
vcc6-supply = <&vcc3v3_sys>;
vcc7-supply = <&vcc3v3_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc3v3_sys>;
pwrkey {
status = "okay";
pinctrl_rk8xx: pinctrl_rk8xx {
gpio-controller;
#gpio-cells = <2>;
rk817_slppin_null: rk817_slppin_null {
pins = "gpio_slp";
function = "pin_fun0";
rk817_slppin_slp: rk817_slppin_slp {
pins = "gpio_slp";
function = "pin_fun1";
rk817_slppin_pwrdn: rk817_slppin_pwrdn {
pins = "gpio_slp";
function = "pin_fun2";
rk817_slppin_rst: rk817_slppin_rst {
pins = "gpio_slp";
function = "pin_fun3";
regulators {
vdd_logic: DCDC_REG1 {
regulator-boot-on;
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <1350000>;
regulator-init-microvolt = <900000>;
regulator-ramp-delay = <6001>;
regulator-initial-mode = <0x2>;
regulator-name = "vdd_logic";
vdd_gpu: DCDC_REG2 {
regulator-boot-on;
regulator-name = "vdd_gpu";
vcc_ddr: DCDC_REG3 {
regulator-boot-on;
regulator-name = "vcc_ddr";
regulator-on-in-suspend;
vdd_npu: DCDC_REG4 {
regulator-boot-on;
regulator-name = "vdd_npu";
vdda0v9_image: LDO_REG1 {
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
regulator-name = "vdda0v9_image";
vdda_0v9: LDO_REG2 {
regulator-boot-on;
regulator-name = "vdda_0v9";
vdda0v9_pmu: LDO_REG3 {
regulator-boot-on;
regulator-name = "vdda0v9_pmu";
regulator-suspend-microvolt = <900000>;
vccio_acodec: LDO_REG4 {
regulator-boot-on;
regulator-name = "vccio_acodec";
vccio_sd: LDO_REG5 {
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-name = "vccio_sd";
vcc3v3_pmu: LDO_REG6 {
regulator-boot-on;
regulator-name = "vcc3v3_pmu";
regulator-suspend-microvolt = <3300000>;
vcca_1v8: LDO_REG7 {
regulator-boot-on;
regulator-max-microvolt = <1800000>;
regulator-name = "vcca_1v8";
vcca1v8_pmu: LDO_REG8 {
regulator-boot-on;
regulator-name = "vcca1v8_pmu";
regulator-suspend-microvolt = <1800000>;
vcca1v8_image: LDO_REG9 {
regulator-boot-on;
regulator-name = "vcca1v8_image";
vcc_1v8: DCDC_REG5 {
regulator-boot-on;
regulator-name = "vcc_1v8";
vcc_3v3: SWITCH_REG1 {
regulator-boot-on;
regulator-name = "vcc_3v3";
vcc3v3_sd: SWITCH_REG2 {
regulator-boot-on;
regulator-name = "vcc3v3_sd";
rk809_codec: codec {
compatible = "rockchip,rk809-codec", "rockchip,rk817-codec";
clocks = <&cru I2S1_MCLKOUT>;
clock-names = "mclk";
assigned-clocks = <&cru I2S1_MCLKOUT>, <&cru I2S1_MCLK_TX_IOE>;
assigned-clock-rates = <12288000>;
assigned-clock-parents = <&cru I2S1_MCLKOUT_TX>, <&cru I2S1_MCLKOUT_TX>;
pinctrl-names = "default","spk_gpio";
pinctrl-0 = <&i2s1m0_mclk>;
pinctrl-1 = <&spk_ctl_gpio>;
hp-volume = <20>;
spk-volume = <3>;
//mic-in-differential;
capture-volume = <0>;
io-channels = <&saradc 4>;
hp-det-adc-value = <1000>;
spk-ctl-gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>;
status = "okay";
&i2s0_8ch {
status = "okay";
&i2s1_8ch {
status = "okay";
rockchip,clk-trcm = <1>;
pinctrl-0 = <&i2s1m0_sclktx
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
&iep {
status = "okay";
&iep_mmu {
status = "okay";
&jpegd {
status = "okay";
&jpegd_mmu {
status = "okay";
&mpp_srv {
status = "okay";
&nandc0 {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
nand@0 {
reg = <0>;
nand-bus-width = <8>;
nand-ecc-mode = "hw";
nand-ecc-strength = <16>;
nand-ecc-step-size = <1024>;
&pmu_io_domains {
status = "okay";
pmuio1-supply = <&vcc3v3_pmu>;
pmuio2-supply = <&vcc3v3_pmu>;
vccio1-supply = <&vccio_acodec>;
vccio3-supply = <&vccio_sd>;
vccio4-supply = <&vcc_1v8>;
vccio5-supply = <&vcc_3v3>;
vccio6-supply = <&vcc_1v8>;
vccio7-supply = <&vcc_3v3>;
&pwm4 {
status = "okay";
&pwm5 {
status = "okay";
&rk_rga {
status = "okay";
&rkvdec {
status = "okay";
&rkvdec_mmu {
status = "okay";
&rkvenc {
venc-supply = <&vdd_logic>;
status = "okay";
&rkvenc_mmu {
status = "okay";
&rknpu {
rknpu-supply = <&vdd_npu>;
status = "okay";
&rknpu_mmu {
status = "okay";
&bus_npu {
bus-supply = <&vdd_logic>;
pvtm-supply = <&vdd_cpu>;
status = "okay";
&saradc {
status = "okay";
vref-supply = <&vcca_1v8>;
&sdhci {
bus-width = <8>;
supports-emmc;
non-removable;
max-frequency = <200000000>;
status = "okay";
&sdmmc0 {
max-frequency = <150000000>;
supports-sd;
bus-width = <4>;
cap-mmc-highspeed;
cap-sd-highspeed;
disable-wp;
sd-uhs-sdr104;
vmmc-supply = <&vcc3v3_sd>;
vqmmc-supply = <&vccio_sd>;
pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
status = "okay";
&spdif_8ch {
status = "okay";
&tsadc {
status = "okay";
&u2phy0_host {
phy-supply = <&vcc5v0_host>;
status = "okay";
&u2phy0_otg {
vbus-supply = <&vcc5v0_otg>;
status = "okay";
&u2phy1_host {
status = "okay";
&u2phy1_otg {
status = "okay";
&usb2phy0 {
status = "okay";
&usb2phy1 {
status = "okay";
&usb_host0_ehci {
status = "okay";
&usb_host0_ohci {
status = "okay";
&usb_host1_ehci {
status = "okay";
&usb_host1_ohci {
status = "okay";
&usbdrd_dwc3 {
dr_mode = "otg";
extcon = <&usb2phy0>;
status = "okay";
&usbdrd30 {
status = "okay";
&usbhost_dwc3 {
status = "okay";
&usbhost30 {
status = "okay";
&vad {
rockchip,audio-src = <&i2s1_8ch>;
rockchip,buffer-time-ms = <128>;
rockchip,det-channel = <0>;
rockchip,mode = <0>;
&vdpu {
status = "okay";
&vdpu_mmu {
status = "okay";
&vepu {
status = "okay";
&vepu_mmu {
status = "okay";
&vop {
status = "okay";
assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
&vop_mmu {
status = "okay";
&pinctrl {
pmic {
pmic_int: pmic_int {
rockchip,pins =
<0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
soc_slppin_gpio: soc_slppin_gpio {
rockchip,pins =
<0 RK_PA2 RK_FUNC_GPIO &pcfg_output_low_pull_down>;
soc_slppin_slp: soc_slppin_slp {
rockchip,pins =
<0 RK_PA2 RK_FUNC_1 &pcfg_pull_up>;
soc_slppin_rst: soc_slppin_rst {
rockchip,pins =
<0 RK_PA2 RK_FUNC_2 &pcfg_pull_none>;
spk_ctl_gpio: spk_ctl_gpio {
rockchip,pins = <3 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
usb {
vcc5v0_host_en: vcc5v0-host-en {
rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
vcc5v0_otg_en: vcc5v0-otg-en {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
