Hi there,
I’ve got a radxa CM3 IO board and out of 4 different nics and 5 pci-e cards in total, only one gets detected by rockbuntu 20.04.
Also in conjunction with a 12V 5A powersupply.
It is installed to eMMC since sd boot straight up does not work.
This is the dmesg | grep pcie output for the nic that works:
[ 0.387794] rk-pcie 3c0000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.387904] rk-pcie 3c0000000.pcie: Linked as a consumer to regulator.2
[ 0.388290] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[ 0.388332] rk-pcie 3c0000000.pcie: Missing config reg space
[ 0.388363] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[ 0.388405] rk-pcie 3c0000000.pcie: err 0x300000000…0x3007fffff -> 0x00000000
[ 0.388422] rk-pcie 3c0000000.pcie: IO 0x300800000…0x3008fffff -> 0x00800000
[ 0.388453] rk-pcie 3c0000000.pcie: MEM 0x300900000…0x33fffffff -> 0x00900000
[ 0.623894] ehci-pci: EHCI PCI platform driver
[ 1.394532] rk-pcie 3c0000000.pcie: PCIe Link up, LTSSM is 0x130011
[ 1.394763] rk-pcie 3c0000000.pcie: PCI host bridge to bus 0000:00
[ 1.394787] pci_bus 0000:00: root bus resource [bus 00-0f]
[ 1.394797] pci_bus 0000:00: root bus resource [??? 0x300000000-0x3007fffff flags 0x0] (bus address [0x00000000-0x007fffff])
[ 1.394808] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x800000-0x8fffff])
[ 1.394816] pci_bus 0000:00: root bus resource [mem 0x300900000-0x33fffffff] (bus address [0x00900000-0x3fffffff])
[ 1.394855] pci 0000:00:00.0: [1d87:3566] type 01 class 0x060400
[ 1.394885] pci 0000:00:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 1.394933] pci 0000:00:00.0: supports D1 D2
[ 1.394937] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 1.399880] pci_bus 0000:01: busn_res: can not insert [bus 01-ff] under [bus 00-0f] (conflicts with (null) [bus 00-0f])
[ 1.399967] pci 0000:01:00.0: [10ec:8125] type 00 class 0x020000
[ 1.400139] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 1.400176] pci 0000:01:00.0: reg 0x10: [io size 0x0100]
[ 1.400271] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x0000ffff 64bit]
[ 1.400332] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 1.400368] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 1.400847] pci 0000:01:00.0: supports D1 D2
[ 1.400852] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.415170] pci 0000:00:00.0: BAR 8: assigned [mem 0x300900000-0x3009fffff]
[ 1.415214] pci 0000:00:00.0: BAR 6: assigned [mem 0x300a00000-0x300a0ffff pref]
[ 1.415225] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.415241] pci 0000:01:00.0: BAR 2: assigned [mem 0x300900000-0x30090ffff 64bit]
[ 1.415299] pci 0000:01:00.0: BAR 6: assigned [mem 0x300910000-0x30091ffff pref]
[ 1.415308] pci 0000:01:00.0: BAR 4: assigned [mem 0x300920000-0x300923fff 64bit]
[ 1.415361] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 1.415391] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 1.415404] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.415416] pci 0000:00:00.0: bridge window [mem 0x300900000-0x3009fffff]
[ 1.417415] pcieport 0000:00:00.0: Signaling PME with IRQ 97
[ 1.418051] pcieport 0000:00:00.0: AER enabled with IRQ 106
rock@rockcm3:~$
While this is displayed on the ones that don’t work:
[ 0.387682] rk-pcie 3c0000000.pcie: Looking up vpcie3v3-supply from device tree
[ 0.387794] rk-pcie 3c0000000.pcie: Linked as a consumer to regulator.2
[ 0.388212] rk-pcie 3c0000000.pcie: missing legacy IRQ resource
[ 0.388257] rk-pcie 3c0000000.pcie: Missing config reg space
[ 0.388289] rk-pcie 3c0000000.pcie: host bridge /pcie@fe260000 ranges:
[ 0.388342] rk-pcie 3c0000000.pcie: err 0x300000000…0x3007fffff -> 0x00000000
[ 0.388360] rk-pcie 3c0000000.pcie: IO 0x300800000…0x3008fffff -> 0x00800000
[ 0.388396] rk-pcie 3c0000000.pcie: MEM 0x300900000…0x33fffffff -> 0x00900000
[ 0.623472] ehci-pci: EHCI PCI platform driver
[ 1.394759] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 2.408170] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 3.424701] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.434743] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.447976] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x1
[ 6.461568] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 7.474759] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 8.488061] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 9.501514] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 10.514796] rk-pcie 3c0000000.pcie: PCIe Linking… LTSSM is 0x0
[ 11.527975] rk-pcie 3c0000000.pcie: PCIe Link Fail
[ 11.528059] rk-pcie 3c0000000.pcie: failed to initialize host
What could be the cause of this?
