Hi. Working with Rock 3 CM V1.31A on a Rock3 Compute Module IO Board. So far have not been able to get audio output either from the jack or using Bluetooth. Maybe a separate problem but the Bluetooth will not pair. Any experience with this is appreciated. I used the speaker test and the audio mixer showed an output but no sound. Speaker connected works.
Bluetooth I don’t know what the story is. Devices show up but only a MAC address. They will not pair. I think I have all the latest updates.
Thanks,
Dave
feng
June 6, 2023, 6:08am
2
Which mirror are you using?
What log would you like to see?
I will have to check. I am not sitting with the system at the moment. Will let you know tomorrow.
feng
June 7, 2023, 2:41am
6
Take a look at the log from the system startup to when you try to play the sound.
Here is what it says when I run update.
[sudo] password for rock:
Get:1 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Hit:2 http://apt.radxa.com/bullseye-stable bullseye InRelease
Hit:3 http://httpredir.debian.org/debian bullseye InRelease
Get:4 http://httpredir.debian.org/debian bullseye-updates InRelease [44.1 kB]
Get:5 http://httpredir.debian.org/debian bullseye-backports InRelease [49.0 kB]
Get:6 http://security.debian.org/debian-security bullseye-security/main arm64 Packages [241 kB]
Get:7 http://security.debian.org/debian-security bullseye-security/main Translation-en [161 kB]
Get:8 http://httpredir.debian.org/debian bullseye-backports/main arm64 Packages.diff/Index [63.3 kB]
Get:9 http://httpredir.debian.org/debian bullseye-backports/main arm64 Packages T-2023-06-08-2009.32-F-2023-06-08-2009.32.pdiff [897 B]
Fetched 607 kB in 4s (161 kB/s)
Reading package lists… Done
Building dependency tree… Done
1 package can be upgraded. Run ‘apt list --upgradable’ to see it.
would this be syslog? I’m not sure what to look for. There don’t appear to be any errors related to sound or audio or pulseaudio.
