tjcs90
September 10, 2020, 1:53am
41
Additional patch (rolled up from Andi Kleen):
https://www.cen64.com/uploads/rockpix/lto-5.8.patch
Kernel is now compiled with FLTO (full link time optimization) which reduces kernel size when compressed by ~2.75%. Biggest benefits of this are more efficient code execution due to compiler optimizations that are performed by GCC though.
Anyways, new kernel is posted. Hope you enjoy.
I will briefly look into compiling kernel with -Os instead of -O2 next.
Darmur
September 12, 2020, 4:23pm
42
Updated to latest release, no problems so far
tjcs90
September 24, 2020, 9:55pm
43
Added links for Linux 5.8.11.
Is it possible to include the USB Type-C drivers? Or are they not necessary?
Could you also add FUSE?
jack
September 25, 2020, 2:12pm
45
USB C doesnât need driver, the PD/QC protocol is managed by an IC.
But is it possible to retrieve information from the IC? Could it act like a regular USB-C port in the case that Iâm using battery power?
tjcs90
September 26, 2020, 12:39am
48
I added USB-C software support just in case, but without any PD protocol support.
FUSE also added.
Debs are republished with same names.
jack
September 26, 2020, 9:01am
49
The PD/QC protocol IC doesnât talk to the processor. It only talks to the power adapter.
Gavan1
October 1, 2020, 3:08pm
50
Didnât workout for me with a fresh install of Ubuntu 20.04, error on the last command.
could you advise on the removal command.
dpkg --remove �
Thank you.
Looking forward to it being compatible.
tjcs90
October 31, 2020, 1:23am
51
Updated to Linux 5.8.17.
Patches rebased against new kernel:
Are you gonna be updating the patches for 5.9?
tjcs90
November 6, 2020, 1:22am
53
No. Itâs too much work to rebase for every series, and nothing about 5.9 is particularly earth-shattering for the Rock Pi Xâs components/Silvermont.
can this kernel support GPIOs and SPI port? where is the .config file?
tjcs90
November 6, 2020, 1:40pm
56
.config is in the deb, just run ar -x blahblah.deb and then tar -xf data.tar.xz.
Try it, I enabled everything that made sense for this board.
cat boot/config-5.8.17 | grep 'GPIO\|SPI' | grep -v '^#'
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y
CONFIG_QUEUED_SPINLOCKS=y
CONFIG_REGMAP_SPI=m
CONFIG_KEYBOARD_GPIO=m
CONFIG_SERIAL_MCTRL_GPIO=m
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_PXA2XX=m
CONFIG_SPI_PXA2XX_PCI=m
CONFIG_SPI_DYNAMIC=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_GPIO_ACPI=y
CONFIG_GPIOLIB_IRQCHIP=y
CONFIG_GPIO_SYSFS=y
CONFIG_SND_SPI=y
CONFIG_SND_SOC_I2C_AND_SPI=m
CONFIG_RTC_I2C_AND_SPI=y
CONFIG_INTEL_INT0002_VGPIO=m
So perhaps maybe for 5.10?
Also it seems you didnât update the patches, as I keep getting failed builds during the patch phaseâŚ
tjcs90
November 10, 2020, 10:53pm
59
The patches in my build tree match what are posted. It must be a problem with your build process as these apply cleanly to the 5.8.17 sources.
build-host $ md5sum *.patch
3b507ca4337a078e01542143de2ddae8 brcmfmac-5.8.patch
de39747f4146bdec5ff461784c79cd58 lto-5.8.patch
2ec0ded441d2ed15357e8bbd36af25b8 mtune-silvermont.patch
me@test:~/sandbox/linux-5.8.17$ patch -Np1 -i ~/Downloads/brcmfmac-5.8.patch
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/fwsignal.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/common.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/msgbuf.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/p2p.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/bcmsdh.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.h
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/core.c
patching file drivers/net/wireless/broadcom/brcm80211/brcmfmac/fweh.c
me@test:~/sandbox/linux-5.8.17$ patch -Np1 -i ~/Downloads/lto-5.8.patch
patching file Documentation/kbuild/lto-build.rst
patching file Makefile
Hunk #3 succeeded at 949 (offset -4 lines).
Hunk #4 succeeded at 1130 (offset -4 lines).
Hunk #5 succeeded at 1772 (offset -4 lines).
patching file arch/x86/Kconfig
patching file arch/x86/kernel/alternative.c
patching file arch/x86/purgatory/Makefile
patching file arch/x86/realmode/Makefile
patching file drivers/firmware/efi/libstub/Makefile
Hunk #1 succeeded at 56 (offset -1 lines).
Hunk #2 succeeded at 123 (offset -1 lines).
patching file drivers/gpu/drm/amd/amdkfd/kfd_iommu.c
patching file drivers/media/platform/sti/delta/delta-ipc.c
patching file drivers/misc/lkdtm/Makefile
patching file drivers/xen/time.c
patching file include/asm-generic/export.h
patching file include/asm-generic/vmlinux.lds.h
Hunk #1 succeeded at 439 (offset 2 lines).
patching file include/linux/compiler_attributes.h
patching file include/linux/export.h
patching file include/linux/init.h
patching file include/linux/linkage.h
patching file init/Kconfig
patching file kernel/Makefile
patching file kernel/bpf/core.c
patching file kernel/locking/spinlock.c
patching file scripts/Makefile
patching file scripts/Makefile.build
patching file scripts/Makefile.crc
patching file scripts/Makefile.lib
patching file scripts/Makefile.lto
patching file scripts/Makefile.modfinal
patching file scripts/elf_file_offset
patching file scripts/gcc-ld
patching file scripts/genksyms/genksyms.c
patching file scripts/genksyms/genksyms.h
patching file scripts/genksyms/parse.y
patching file scripts/kallsyms.c
Hunk #4 succeeded at 145 with fuzz 2 (offset 10 lines).
Hunk #5 succeeded at 173 (offset 14 lines).
Hunk #6 succeeded at 188 (offset 14 lines).
Hunk #7 succeeded at 411 (offset 14 lines).
Hunk #8 succeeded at 434 (offset 14 lines).
Hunk #9 succeeded at 478 (offset 14 lines).
Hunk #10 succeeded at 528 (offset 14 lines).
Hunk #11 succeeded at 565 (offset 14 lines).
Hunk #12 succeeded at 846 (offset 14 lines).
Hunk #13 succeeded at 859 (offset 14 lines).
Hunk #14 succeeded at 889 (offset 14 lines).
patching file scripts/link-vmlinux.sh
patching file scripts/mod/modpost.c
Hunk #1 succeeded at 1988 (offset 9 lines).
Hunk #2 succeeded at 2014 (offset 9 lines).
Hunk #3 succeeded at 2031 (offset 9 lines).
Hunk #4 succeeded at 2076 (offset 9 lines).
Hunk #5 succeeded at 2114 (offset 9 lines).
patching file scripts/patchfile.c
tjcs90
November 15, 2020, 8:57pm
60
Found some cycles this weekend, decided to rebase everything onto 5.9(.8) this weekend and got it booted⌠doing some testing prior to releasing.
Andi Kleen may have stopped supporting the FLTO patches (as Clang LTO is supported instead for 5.10rc presumably?) and I donât know how long I can keep them going as itâs very detailed kernel work.
There was a tricky little optimization that broke the LTO builds hopping from 5.8 to 5.9 that I had to figure out that would have ordinarily been a part of those patches.
tjcs90
November 17, 2020, 2:18am
61
Kernel 5.9.8 binary and patches posted.
New patch set lto-tjs.patch is my patches on top of Andi Kleenâs LTO patches. It was needed because they now do pointer comparison for some optimization, and the LTO was reordering the functions during the link step that broke the pointer comparison optimization.
