I’m using the model with NAND, BT & Wi-Fi.
I’ve been trying to get it to work for several days, but I haven’t been able to SSH into it. I’ve installed the official Debian image on the built-in flash and even tried booting from a USB stick (yes, I zeroed flash like the wiki specified) but nothing works. It doesn’t show up on the network at all, not with Ethernet nor with Wi-Fi. adb also wasn’t able to detect it, even though rkdevtool was.
Does anyone know what the problem could be?
EDIT 2023-11-23 11:29: I’ve installed the Rock Pi Debian image on a SD card and wiped the built-in flash again. A new IP shows up on my network, but its hostname is not rockpis and SSH connections are refused. adb still doesn’t detect the device.
EDIT 2023-11-23 11:34: Unknown device is gone from network.
EDIT 2023-11-23 12:04: The device appeared again and responded to pings but disappeared when an SSH connection was attempted.
FINAL EDIT: The issue was the power supply. I was using power directly from the PC. This was not sufficient.
