Rock Pi S OTG in Host Mode
Hello friends,
I want to connect a USB flash drive via OTG port on Rock Pi S. I have used a type C OTG connector as shown in picture
But after connecing it and using “lsusb” command it does not show any device connected.
Any idea what I’m doing wrong??
Hi, to configure ROCK Pi S Type-C port to work in host mode, you can check these two guides.
https://wiki.radxa.com/RockpiS/Ubuntu#USB or https://wiki.radxa.com/RockpiS/Debian#USB.
Hi Stephen,
That solution did not worked.
First of all, there is no overlay file named “rk3308-usb20-host” in my /boot/dtbs/4.4.143-48-rockchip-geacd15ae244f/rockchip/overlay folder
This I can understand because my Kernel version is 4.4.143-48 but the guide you mentioned recommends version >=4.4.143-51.
So I followed the commands mentioned at https://wiki.radxa.com/RockpiS/Debian#Update_necessary_packages
but again it failed the kernel update command “sudo apt-get install -y linux-4.4-rockpis-latest” mid-process with the error that the required file was not found in the repository (shown in below image)
not to mention that even the above command was trying to install kernel version 4.4.143-49 and not the recommended 4.4.143-51.
I am using the latest Debian Buster image from Radxa (image dated: 28/05/2020)
Try
sudo su
apt-get update
apt-get install linux-4.4-rockpis-latest
And the following information should be shown.
root@rockpis:/home/rock# apt-get install linux-4.4-rockpis-latest
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  linux-firmware-image-4.4.143-51-rockchip-gb2a02deb3cbd linux-headers-4.4.143-51-rockchip-gb2a02deb3cbd
  linux-image-4.4.143-51-rockchip-gb2a02deb3cbd
The following NEW packages will be installed:
The following packages will be upgraded:
1 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 17.9 MB of archives.
After this operation, 107 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Just a question - does using USB OTG in Host mode on Pi S works on the latest images with kernel 6.1? I don’t see any specific overlay in the images here https://github.com/radxa-build/rock-pi-s/releases
This overlay works if someone needs:
/dts-v1/;
/plugin/;
	compatible = "rockchip,rk3308";
	fragment@0 {
		target = <&usb20_otg>;
		__overlay__ {
			dr_mode = "host";
			status = "okay";
Thank you for this, @kolsi. I’m looking to try this on Armbian, do you have a link to the full process of adding this overlay? I assume once created it could be referenced in armbianEnv.txt ?
Also, dr_mode is currently set to “peripheral” in the RK3308 overlay. If it were set to otg instead of host would the port then be auto-detecting?
Ok, so I think these pages might have the answer, haven’t tried it yet.
https://docs.armbian.com/User-Guide_Armbian_overlays/
and
It looks like, I would create a file called something like rk3308-usb-otg.dts in the /boot/overlay-user folder, with the contents you wrote above.
execute armbian-add-overlay rk3308-usb-otg.dts
reboot
That should be it?
Doesn’t seem to work. :frowning:
I’m also feeling like Armbian isn’t loading ANY overlays. I wonder if anyone can confirm?
Where do you incert that overlay?
Anyone been able to get an overlay to work on the Rock-Pi-S? I’ve had no luck at all.
