Following error i got while flash/erase the nand flash.
root@ELMPC-158:/home/elmpc-158# rkdeveloptool ld
DevNo=1 Vid=0x2207,Pid=0x330e,LocationID=101 Maskrom
root@ELMPC-158:/home/elmpc-158# rkdeveloptool db /media/elmpc- 158/CC1EB40A1EB3EC18/Dhevan/Rock_pi/RockPi_S/rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin
Opening loader failed, exiting download boot!
Please give solution for this error.
Thanks & Regards
Vasu
jack
December 21, 2019, 2:14am
2
You need to cd to the path where you put the rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin and use rkdeveloptool in the current path.
rkdeveloptool db ./rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin
akal
February 10, 2021, 10:40pm
3
I have a success with this command : rkdeveloptool db ./rk3308_loader_uart0_m0_emmc_port_support_sd_20190717.bin
But in the next step : sudo rkdeveloptool wl 0 system.img
I got this error:
Write LBA failed, err=2, can’t open file: system.img
Please help me.
Thank you.
jack
February 10, 2021, 11:58pm
4
sudo rkdeveloptool wl 0 system.img system.img is the image you downloaded, it should be rockpi-xxx-gpt.img
akal
March 9, 2021, 6:50pm
5
Thank you, it was because i have’n extracted the gz file.
