Hello 我购买的2个ROCK PI S无法启动,请帮忙看下是什么问题,谢谢!
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2020.02.25 08:34:14 =~=~=~=~=~=~=~=~=~=~=~=
DDR Version V1.26
REGFB: 0x00000032, 0x00000032
In
589MHz
DDR3
Col=10 Bank=8 Row=14 Size=256MB
msch:1
Returning to boot ROM…
INFO: Preloader serial: 0
NOTICE: BL31: v1.3(release):3a579d3
NOTICE: BL31: Built : 09:09:17, Jan 29 2019
INFO: Lastlog: last=0x100000, realtime=0x102000, size=0x2000
INFO: ARM GICv2 driver initialized
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe b
INFO: Entry point address = 0x600000
INFO: SPSR = 0x3c9
U-Boot 2017.09-02372-g98a8b2b378 (Nov 22 2019 - 09:59:57 +0000), Build: jenkins-linux-build-testing-2-103
Model: Radxa ROCK Pi S
PreSerial: 0
DRAM: 254 MiB
Relocation Offset is: 0f92b000
vdd_core 1044000 uV
vdd-core init 1044000 uV
MMC: dwmmc@ff480000: 0, dwmmc@ff490000: 1
Using default environment
In: serial@ff0c0000
Out: serial@ff0c0000
Err: serial@ff0c0000
Bootdev(atags): mmc 0
PartType: EFI
Error: Can’t overwrite “serial#”
Error inserting “serial#” variable, errno=1
get part misc fail -1
boot mode: None
CLK:
apll 816000 KHz
dpll 1300000 KHz
vpll0 1179647 KHz
vpll1 903167 KHz
aclk_bus 185714 KHz
hclk_bus 100000 KHz
pclk_bus 100000 KHz
aclk_peri 185714 KHz
hclk_peri 100000 KHz
pclk_peri 100000 KHz
hclk_audio 98303 KHz
pclk_audio 98303 KHz
Net: Net Initialization Skipped
No ethernet found.
Hit key to stop autoboot(‘CTRL+C’): 1 0:1…
Found /extlinux/extlinux.conf
Welcome to sysboot
pxefile_addr_str = 0x00500000
bootfile = /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
395 bytes read in 4 ms (95.7 KiB/s)
select kernel
1: kernel-4.4.143-34-rockchip-g3c9d2019dba7
Enter choice: Retrieving file: /hw_intfc.conf
reading /hw_intfc.conf
736 bytes read in 2 ms (359.4 KiB/s)
dtoverlay number: 0, name:/overlays/console-on-ttyS0.dtbo
hw_conf.valid = 1
hw_conf.i2c0 = 0
hw_conf.i2c1 = 0
hw_conf.i2c2 = 0
hw_conf.i2c3 = 0
hw_conf.pwm1 = 0
hw_conf.pwm2 = 0
hw_conf.pwm3 = 0
hw_conf.spi0 = 0
hw_conf.spi2 = 0
hw_conf.uart0 = 0
hw_conf.uart1 = 0
hw_conf.uart2 = 0
hw_conf.dts_overlay_count = 1
hw_conf.dts_overlay[0] = /overlays/console-on-ttyS0.dtbo
Retrieving file: /initrd.img-4.4.143-34-rockchip-g3c9d2019dba7
reading /initrd.img-4.4.143-34-rockchip-g3c9d2019dba7
5972635 bytes read in 256 ms (22.2 MiB/s)
Retrieving file: /vmlinuz-4.4.143-34-rockchip-g3c9d2019dba7
reading /vmlinuz-4.4.143-34-rockchip-g3c9d2019dba7
13649928 bytes read in 583 ms (22.3 MiB/s)
append: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=UUID=a84758d0-f922-43af-a5a1-d0b1f2d3ab42
Retrieving file: /dtbs/4.4.143-34-rockchip-g3c9d2019dba7/rockchip/rockpi-s-linux.dtb
reading /dtbs/4.4.143-34-rockchip-g3c9d2019dba7/rockchip/rockpi-s-linux.dtb
63447 bytes read in 13 ms (4.7 MiB/s)
fdt addr 0000000001f00000
fdt magic number edfe0dd0
fdt size 1048576
merge_dts_overlay
Retrieving file: /overlays/console-on-ttyS0.dtbo
reading /overlays/console-on-ttyS0.dtbo
359 bytes read in 3 ms (116.2 KiB/s)
overlay dtb(0x0000000001e00000) is valid
fdt_overlay_apply 0000000001f00000 0000000001e00000
Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to 0ef66000, end 0f51829b … OK
Loading Device Tree to 000000000ee63000, end 000000000ef65fff … OK
Adding bank: 0x00200000 - 0x10000000 (size: 0x0fe00000)
Starting kernel …
2 d29288 u77824
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64008
[ 0.000000] Kernel command line: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=UUID=a84758d0-f922-43af-a5a1-d0b1f2d3ab42
[ 0.000000] PID hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.000000] software IO TLB [mem 0x09e63000-0x0de63000] (64MB) mapped at [ffffffc009e63000-ffffffc00de62fff]
[ 0.000000] Memory: 169156K/260096K available (9278K kernel code, 658K rwdata, 2948K rodata, 384K init, 579K bss, 90940K reserved, 0K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] .init : 0xffffff8008c80000 - 0xffffff8008ce0000 ( 384 KB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008990000 ( 9280 KB)
[ 0.000000] .rodata : 0xffffff8008990000 - 0xffffff8008c80000 ( 3008 KB)
[ 0.000000] .data : 0xffffff8008ce0000 - 0xffffff8008d84808 ( 659 KB)
[ 0.000000] fixed : 0xffffffbffe7fd000 - 0xffffffbffec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB)
[ 0.000000] memory : 0xffffffc000200000 - 0xffffffc010000000 ( 254 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000963] Console: colour dummy device 80x25
[ 0.000991] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[ 0.001005] pid_max: default: 32768 minimum: 301
[ 0.001095] Security Framework initialized
[ 0.001108] AppArmor: AppArmor disabled by boot time parameter
[ 0.001167] Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.001178] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.001888] Initializing cgroup subsys io
[ 0.001912] Initializing cgroup subsys memory
[ 0.001949] Initializing cgroup subsys devices
[ 0.001965] Initializing cgroup subsys freezer
[ 0.001980] Initializing cgroup subsys net_cls
[ 0.001993] Initializing cgroup subsys perf_event
[ 0.002007] Initializing cgroup subsys net_prio
[ 0.002031] Initializing cgroup subsys hugetlb
[ 0.002044] Initializing cgroup subsys pids
[ 0.002364] sched-energy: CPU device node has no sched-energy-costs
[ 0.002378] Invalid sched_group_energy for CPU0
[ 0.002386] CPU0: update cpu_capacity 1024
[ 0.002433] ASID allocator initialised with 65536 entries
[ 0.035881] Detected VIPT I-cache on CPU1
[ 0.035935] Invalid sched_group_energy for CPU1
[ 0.035941] CPU1: update cpu_capacity 1024
[ 0.035946] CPU1: Booted secondary processor [410fd042]
[ 0.047906] Detected VIPT I-cache on CPU2
[ 0.047944] Invalid sched_group_energy for CPU2
[ 0.047948] CPU2: update cpu_capacity 1024
[ 0.047953] CPU2: Booted secondary processor [410fd042]
[ 0.059947] Detected VIPT I-cache on CPU3
[ 0.059983] Invalid sched_group_energy for CPU3
[ 0.059987] CPU3: update cpu_capacity 1024
[ 0.059991] CPU3: Booted secondary proces91.000 MB/sec
[ 0.236329] 32regs_prefetch: 1121.000 MB/sec
[ 0.236338] xor: using function: 32regs (1291.000 MB/sec)
[ 0.236369] pinctrl core: initialized pinctrl subsystem
[ 0.237581] NET: Registered protocol family 16
[ 0.248389] cpuidle: using governor menu
[ 0.248426] Registered FIQ tty driver
[ 0.248743] vdso: 2 pages (1 code @ ffffff8008996000, 1 data @ ffffff8008ce4000)
[ 0.248782] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.248996] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.252286] console [pstore-1] enabled
[ 0.252298] pstore: Registered ramoops as persistent store backend
[ 0.252310] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.269718] fiq debugger fiq mode enabled
[ 0.270638] console [ttyFIQ0] enabled
[ 0.270917] Registered fiq debugger ttyFIQ0
[ 0.384922] raid6: int64x1 gen() 224 MB/s
[ 0.453107] raid6: int64x1 xor() 195 MB/s
[ 0.521355] raid6: int64x2 gen() 336 MB/s
[ 0.589435] raid6: int64x2 xor() 250 MB/s
[ 0.657607] raid6: int64x4 gen() 450 MB/s
[ 0.725668] raid6: int64x4 xor() 289 MB/s
[ 0.793812] raid6: int64x8 gen() 346 MB/s
[ 0.930149] raid6: neonx1 gen() 389 MB/s
[ 0.998347] raid6: neonx1 xor() 331 MB/s
[ 1.066523] raid6: neonx2 gen() 544 MB/s
[ 1.134598] raid6: neonx2 xor() 407 MB/s
[ 1.202813] raid6: neonx4 gen() 680 MB/s
[ 1.270908] raid6: neonx4 xor() 467 MB/s
ay-passive property
[ 1.430982] failed to build thermal zone soc_thermal: -22
[ 1.431308] NET: Registered protocol family 2
[ 1.432019] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 1.432082] TCP bind hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.432132] TCP: Hash tables configured (established 2048 bind 2048)
[ 1.432222] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 1.432259] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 1.432510] NET: Registered protocol family 1
[ 1.432831] Trying to unpack rootfs image as initramfs…
[ 1.872089] Freeing initrd memory: 5832K
[ 1.872715] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.876537] audit: initializing netlink subsys (disabled)
[ 1.876647] audit: type=2000 audit(1.868:1): initialized
[ 1.877412] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 1.887196] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.888385] fuse init (API version 7.23)
[ 1.889126] JFS: nTxBlock = 1367, nTxLock = 10936
[ 1.891046] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 1.897677] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.897873] io scheduler noop registered
[ 1.897900] io scheduler deadline registered (default)
[ 1.897973] io scheduler cfq registered
[ 1.903244] dma-pl330 ff2c0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.903293] dma-pl330 ff2c0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[ 1.905572] dma-pl330 ff2d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 1.905609] dma-pl330 ff2d0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[ 1.905941] rockchip-pvtm ff000000.grf:pmu-pvtm: failed to get rst 0 pmu
[ 1.906099] rockchip-pvtm ff00c000.syscon:pvtm: failed to get rst 0 core
[ 1.907522] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[ 1.909892] ff0e0000.serial: ttyS4 at MMIO 0xff0e0000 (irq = 11, base_baud = 5078125) is a 16550A
[ 1.910891] [drm] Initialized drm 1.1.0 20060810
[ 1.913035] Unable to detect cache hierarchy for CPU 0
[ 1.914154] brd: module loaded
[ 1.921452] loop: module loaded
[ 1.921741] SCSI Media Changer driver v0.25
[ 1.924260] rk_gmac-dwmac ff4e0000.ethernet: clock input or output? (output).
[ 1.924315] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: tx_delay.
[ 1.924331] rk_gmac-dwmac ff4e0000.ethernet: set tx_delay to 0x30
[ 1.924373] rk_gmac-dwmac ff4e0000.ethernet: Can not read property: rx_delay.
[ 1.924388] rk_gmac-dwmac ff4e0000.ethernet: set rx_delay to 0x10
[ 1.924412] rk_gmac-dwmac ff4e0000.ethernet: integrated PHY? (no).
[ 1.929687] rk_gmac-dwmac ff4e0000.ethernet: init for RMII
[ 1.929826] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ 1.929844] Ring mode enabled
[ 1.929855] DMA HW capability register supported
[ 1.929864] Normal descriptors
[ 1.929876] RX Checksum Offload Engine supported (type 2)
[ 1.929886] TX Checksum insertion supported
[ 1.929896] Wake-Up On Lan supported
[ 1.929957] Enable RX Mitigation via HW Watchdog Timer
[ 2.043979] brian phy in rtl8201f_probe
WiFi SYS interface (V1.00) …
[ 2.052990] ff400000.usb supply vusb_d not found, using dummy regulator
[ 2.053090] ff400000.usb supply vusb_a not found, using dummy regulator
[ 2.166721] dwc2 ff400000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[ 2.167321] dwc2 ff400000.usb: DWC OTG Controller
[ 2.167371] dwc2 ff400000.usb: new USB bus registered, assigned bus number 1
[ 2.167425] dwc2 ff400000.usb: irq 18, io mem 0xff400000
[ 2.167636] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.167662] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.167694] usb usb1: Product: DWC OTG Controller
[ 2.167709] usb usb1: Manufacturer: Linux 4.4.143-34-rockchip-g3c9d2019dba7 dwc2_hsotg
[ 2.167724] usb usb1: SerialNumber: ff400000.usb
[ 2.168547] hub 1-0:1.0: USB hub found
[ 2.168612] hub 1-0:1.0: 1 port detected
[ 2.390139] phy phy-ff008000.syscon:[email protected]: charger = USB_SDP_CHARGER
[ 2.390870] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.390911] ehci-platform: EHCI generic platform driver
[ 2.394696] ehci-platform ff440000.usb: EHCI Host Controller
[ 2.394959] ehci-platform ff440000.usb: new USB bus registered, assigned bus number 2
[ 2.395129] ehci-platform ff440000.usb: irq 19, io mem 0xff440000
[ 2.406698] ehci-platform ff440000.usb: USB 2.0 started, EHCI 1.00
[ 2.406917] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.406943] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.406961] usb usb2: Product: EHCI Host Controller
[ 2.406982] usb usb2: Manufacturer: Linux 4.4.143-34-rockchip-g3c9d2019dba7 ehci_hcd
[ 2.406999] usb usb2: SerialNumber: ff440000.usb
[ 2.407682] hub 2-0:1.0: USB hub found
[ 2.407739] hub 2-0:1.0: 1 port detected
[ 2.408339] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 2.408418] ohci-platform: OHCI generic platform driver
[ 2.408780] ohci-platform ff450000.usb: Generic Platform OHCI controller
[ 2.409051] ohci-platform ff450000.usb: new USB bus registered, assigned bus number 3
[ 2.409209] ohci-platform ff450000.usb: irq 20, io mem 0xff450000
ual HCI driver ver 1.5
[ 2.473680] cpu cpu0: leakage=26
[ 2.473942] cpu cpu0: Failed to get pvtm
[ 2.475081] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[ 2.476497] Synopsys Designware Multimedia Card Interface Driver
[ 2.477630] dwmmc_rockchip ff480000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.477705] dwmmc_rockchip ff480000.dwmmc: Using internal DMA controller.
[ 2.477729] dwmmc_rockchip ff480000.dwmmc: Version ID is 270a
[ 2.477802] dwmmc_rockchip ff480000.dwmmc: DW MMC controller at irq 21,32 bit host data width,256 deep fifo
[ 2.490819] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.507859] dwmmc_rockchip ff480000.dwmmc: 1 slots initialized
[ 2.510274] dwmmc_rockchip ff490000.dwmmc: IDMAC supports 32-bit address mode.
[ 2.510331] dwmmc_rockchip ff490000.dwmmc: Using internal DMA controller.
[ 2.510354] dwmmc_rockchip ff490000.dwmmc: Version ID is 270a
[ 2.510427] dwmmc_rockchip ff490000.dwmmc: DW MMC controller at irq 22,32 bit host data width,256 deep fifo
[ 2.510501] dwmmc_rockchip ff490000.dwmmc: No vmmc regulator found
[ 2.510554] dwmmc_rockchip ff490000.dwmmc: No vqmmc regulator found
[ 2.526825] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 2.575123] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 2.577953] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.579306] usbcore: registered new interface driver usbhid
[ 2.579336] usbhid: USB HID core driver
[ 2.579501] rockchip-dmc dmc: failed to get the count of devfreq-event in /dmc node
[ 2.579799] rockchip-dmc dmc: Failed to get leakage
[ 2.579907] rockchip-dmc dmc: Failed to get pvtm
[ 2.580239] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 2.580274] rockchip-dmc dmc: don’t add devfreq feature
[ 2.581241] rknandc_base v1.1 2017-01-11
[ 2.581428] rksfc_base v1.1 2016-01-08
[ 2.586120] rk3308-acodec ff560000.acodec: Don’t need hp-ctl gpio
[ 2.586243] rk3308-acodec ff560000.acodec: Don’t need spk-ctl gpio
[ 2.586345] rk3308-acodec ff560000.acodec: Don’t need pa-drv gpio
[ 2.586359] rk3308-acodec ff560000.acodec: De-pop as much as possible
[ 2.586481] The acodec version is: b
[ 2.589277] mmcblk0: p1 p2
[ 2.598824] mmc_host mmc2: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[ 2.606782] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 2.642814] mmc_host mmc2: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[ 2.650801] mmc_host mmc1: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 2.669316] rk-multicodecs acodec-sound: rk3308-hifi ↔ ff320000.i2s mapping ok
[ 2.671485] input: rockchip,rk3308-acodec Headphones as /devices/platform/acodec-sound/sound/card1/input0
[ 2.672778] u32 classifier
[ 2.672865] Netfilter messages via NETLINK v0.30.
[ 2.673073] ip_set: protocol 6
[ 2.673691] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.673801] Initializing XFRM netlink socket
[ 2.675096] NET: Registered protocol family 10
[ 2.677470] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.677544] NET: Registered protocol family 17
[ 2.677619] NET: Registered protocol family 15
[ 2.677746] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.678316] Bridge firewalling registered
[ 2.678751] Bluetooth: RFCOMM TTY layer initialized
[ 2.678820] Bluetooth: RFCOMM socket layer initialized
[ 2.678891] Bluetooth: RFCOMM ver 1.11
[ 2.678944] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.678979] Bluetooth: HIDP socket layer initialized
[ 2.679014] 8021q: 802.1Q VLAN Support v1.8
[ 2.679088] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.679876] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.679942] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8723ds
[ 2.679966] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.679989] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.680172] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 0, flags = 0.
[ 2.680271] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.680310] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.680447] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.681210] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 135.
[ 2.681303] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 139.
[ 2.681420] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 2.681463] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[ 2.681599] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.681724] [BT_RFKILL]: ** disable irq
[ 2.682078] [BT_RFKILL]: bt_default device registered.
[ 2.682276] Key type dns_resolver registered
[ 2.682989] flash vendor_init_thread!
[ 2.683038] flash vendor storage:20170308 ret = -1
[ 2.685438] registered taskstats version 1
[ 2.690031] Btrfs loaded, integrity-checker=on
[ 2.690205] BTRFS: selftest: Running btrfs free space cache tests
[ 2.690290] BTRFS: selftest: Running extent only tests
[ 2.690343] BTRFS: selftest: Running bitmap only tests
[ 2.690404] BTRFS: selftest: Running bitmap and extent tests
[ 2.690485] BTRFS: selftest: Running space stealing from bitmap to extent
[ 2.690924] mmc_host mmc2: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0)
[ 2.692853] BTRFS: selftest: Free space cache tests finished
[ 2.692878] BTRFS: selftest: Running extent buffer operation tests
[ 2.692890] BTRFS: selftest: Running btrfs_split_item tests
[ 2.692982] BTRFS: selftest: Running find delalloc tests
:4, mode:0x24040c1
[ 3.182815] CPU: 3 PID: 132 Comm: vendor_storage_ Not tainted 4.4.143-34-rockchip-g3c9d2019dba7 #1
[ 3.182825] Hardware name: Radxa ROCK Pi S (DT)
[ 3.182834] Call trace:
[ 3.182859] [] dump_backtrace+0x0/0x1c4
[ 3.182874] [] show_stack+0x14/0x1c
[ 3.182889] [] dump_stack+0x98/0xc0
[ 3.182912] [] warn_alloc_failed+0xe4/0x114
[ 3.182925] [] __alloc_pages_nodemask+0x36c/0x664
[ 3.182937] [] alloc_kmem_pages+0x28/0x94
[ 3.182951] [] kmalloc_order+0x14/0x6c
[ 3.182968] [] vendor_init_thread+0x48/0x1b8
[ 3.182982] [] kthread+0xd8/0xe8
[ 3.182996] [] ret_from_fork+0x10/0x50
[ 3.183003] Mem-Info:
[ 3.183026] active_anon:0 inactive_anon:0 isolated_anon:0
[ 3.183026] active_file:779 inactive_file:36300 isolated_file:0
[ 3.183026] unevictable:3010 dirty:0 writeback:0 unstable:0
[ 3.183026] slab_reclaimable:338 slab_unreclaimable:1548
[ 3.183026] mapped:0 shmem:0 pagetables:0 bounce:0
[ 3.183026] free:395 free_pcp:118 free_cma:0
[ 3.183070] DMA free:1580kB min:1644kB low:2052kB high:2464kB active_anon:0kB inactive_anon:0kB active_file:3116kB inactive_file:145200kB unevictable:12040kB isolated(anon):0kB isolated(file):0kB present:260096kB managed:174988kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:1352kB slab_unreclaimable:6192kB kernel_stack:1328kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:472kB local_pcp:148kB free_cma:0kB writeback_tmp:0kB pages_scanned:1096348 all_unreclaimable? yes
[ 3.183081] lowmem_reserve: 0 0 0
[ 3.183116] DMA: 14kB (U) 18kB (U) 016kB 132kB (U) 264kB (UM) 1128kB (M) 1256kB (M) 2512kB (M) 01024kB 02048kB 0*4096kB = 1580kB
[ 3.183202] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[ 3.183211] 40098 total pagecache pages
[ 3.183225] 0 pages in swap cache
[ 3.183234] Swap cache stats: add 0, delete 0, find 0/0
[ 3.183242] Free swap = 0kB
[ 3.183249] Total swap = 0kB
[ 3.183256] 65024 pages RAM
[ 3.183265] 0 pages HighMem/MovableOnly
[ 3.183272] 21277 pages reserved
] kthread+0xd8/0xe8
[ 3.687046] [] ret_from_fork+0x10/0x50
[ 3.687054] Mem-Info:
[ 3.687076] active_anon:0 inactive_anon:0 isolated_anon:0
[ 3.687076] active_file:779 inactive_file:36300 isolated_file:0
[ 3.687076] unevictable:3010 dirty:0 writeback:0 unstable:0
[ 3.687076] slab_reclaimable:338 slab_unreclaimable:1548
[ 3.687076] mapped:0 shmem:0 pagetables:0 bounce:0
[ 3.687076] free:395 free_pcp:118 free_cma:0
[ 3.687122] DMA free:1580kB min:1644kB low:2052kB high:2464kB active_anon:0kB inactive_anon:0kB active_file:3116kB inactive_file:145200kB unevictable:12040kB isolated(anon):0kB isolated(file):0kB present:260096kB managed:174988kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:1352kB slab_unreclaimable:6192kB kernel_stack:1328kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:472kB local_pcp:160kB free_cma:0kB writeback_tmp:0kB pages_scanned:1499676 all_unreclaimable? yes
[ 3.687133] lowmem_reserve: 0 0 0
[ 3.687155] DMA: 14kB (U) 18kB (U) 016kB 132kB (U) 264kB (UM) 1128kB (M) 1256kB (M) 2512kB (M) 01024kB 02048kB 04096kB = 1580kB
[ 3.687242] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[ 3.687251] 40098 total pagecache pages
[ 3.687265] 0 pages in swap cache
[ 3.687274] Swap cache stats: add 0, delete 0, find 0/0
[ 3.687281] Free swap = 0kB
[ 3.687288] Total swap = 0kB
[ 3.687296] 65024 pages RAM
[ 3.687303] 0 pages HighMem/MovableOnly
[ 3.687310] 21277 pages reserved
[ 4.190836] vendor_storage_: page allocation failure: order:4, mode:0x24040c1
[ 4.190879] CPU: 0 PID: 132 Comm: vendor_storage_ Not tainted 4.4.143-34-rockchip-g3c9d2019dba7 #1
[ 4.190889] Hardware name: Radxa ROCK Pi S (DT)
[ 4.190909] Call trace:
[ 4.190933] [] dump_backtrace+0x0/0x1c4
[ 4.190947] [] show_stack+0x14/0x1c
[ 4.190961] [] dump_stack+0x98/0xc0
[ 4.190976] [] warn_alloc_failed+0xe4/0x114
[ 4.190988] [] __alloc_pages_nodemask+0x36c/0x664
[ 4.191000] [] alloc_kmem_pages+0x28/0x94
[ 4.191015] [] kmalloc_order+0x14/0x6c
[ 4.191029] [] vendor_init_thread+0x48/0x1b8
[ 4.191042] [] kthread+0xd8/0xe8
[ 4.191054] [] ret_from_fork+0x10/0x50
[ 4.191061] Mem-Info:
[ 4.191084] active_anon:0 inactive_anon:0 isolated_anon:0
[ 4.191084] active_file:779 inactive_file:36309 isolated_file:0
[ 4.191084] unevictable:3010 dirty:0 writeback:0 unstable:0
[ 4.191084] slab_reclaimable:338 slab_unreclaimable:1548
[ 4.191084] mapped:0 shmem:0 pagetables:0 bounce:0
[ 4.191084] free:395 free_pcp:118 free_cma:0
[ 4.191129] DMA free:1580kB min:1644kB low:2052kB high:2464kB active_anon:0kB inactive_anon:0kB active_file:3116kB inactive_file:145236kB unevictable:12040kB isolated(anon):0kB isolated(file):0kB present:260096kB managed:174988kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:1352kB slab_unreclaimable:6192kB kernel_stack:1328kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:472kB local_pcp:160kB free_cma:0kB writeback_tmp:0kB pages_scanned:1889340 all_unreclaimable? yes
[ 4.191146] lowmem_reserve[]: 0 0 0
[ 4.191167] DMA: 14kB (U) 18kB (U) 016kB 132kB (U) 264kB (UM) 1128kB (M) 1256kB (M) 2512kB (M) 01024kB 02048kB 04096kB = 1580kB
[ 4.191254] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[ 4.191262] 40098 total pagecache pages
[ 4.191277] 0 pages in swap cache
[ 4.191286] Swap cache stats: add 0, delete 0, find 0/0
[ 4.191294] Free swap = 0kB
[ 4.191301] Total swap = 0kB
[ 4.191308] 65024 pages RAM
[ 4.191315] 0 pages HighMem/MovableOnly
[ 4.191329] 21277 pages reserved
[ 4.695078] [] vendor_init_thread+0x48/0x1b8
[ 4.695091] [] kthread+0xd8/0xe8
[ 4.695104] [] ret_from_fork+0x10/0x50
[ 4.695111] Mem-Info:
[ 4.695133] active_anon:0 inactive_anon:0 isolated_anon:0
[ 4.695133] active_file:779 inactive_file:36309 isolated_file:0
[ 4.695133] unevictable:3010 dirty:0 writeback:0 unstable:0
[ 4.695133] slab_reclaimable:338 slab_unreclaimable:1548
[ 4.695133] mapped:0 shmem:0 pagetables:0 bounce:0
[ 4.695133] free:395 free_pcp:118 free_cma:0
[ 4.695190] DMA free:1580kB min:1644kB low:2052kB high:2464kB active_anon:0kB inactive_anon:0kB active_file:3116kB inactive_file:145236kB unevictable:12040kB isolated(anon):0kB isolated(file):0kB present:260096kB managed:174988kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:1352kB slab_unreclaimable:6192kB kernel_stack:1328kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:472kB local_pcp:160kB free_cma:0kB writeback_tmp:0kB pages_scanned:2278908 all_unreclaimable? yes
[ 4.695201] lowmem_reserve: 0 0 0
[ 4.695222] DMA: 14kB (U) 18kB (U) 016kB 132kB (U) 264kB (UM) 1128kB (M) 1256kB (M) 2512kB (M) 01024kB 02048kB 0*4096kB = 1580kB
[ 4.695308] Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
[ 4.695317] 40098 total pagecache pages
[ 4.695331] 0 pages in swap cache
[ 4.695341] Swap cache stats: add 0, delete 0, find 0/0
[ 4.695348] Free swap = 0kB
[ 4.695355] Total swap = 0kB
[ 4.695363] 65024 pages RAM
[ 4.695377] 0 pages HighMem/MovableOnly
[ 4.695384] 21277 pages reserved
[ 5.702739] vendor storage:20160801 ret = -12
