Rock PI S audio output from PoE HAT's 3,5mm jack
Hi there!
I install debian from radxa webpage by etcher on the SD card.
I do apt install wget, alsa-utils, vlc.
If I insert an usb sound card to USB-A port, VLC starts play instantly. I get no sound from 3,5mm jack on the PoE HAT connector.
rock@rockpis:~$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
default
Playback/recording through the PulseAudio sound server
sysdefault:CARD=Loopback
Loopback, Loopback PCM
Default Audio Device
front:CARD=Loopback,DEV=0
Front speakers
surround21:CARD=Loopback,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Loopback,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Loopback,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Loopback,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Loopback,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Loopback,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=Loopback,DEV=0
Direct sample mixing device
dmix:CARD=Loopback,DEV=1
dsnoop:CARD=Loopback,DEV=0
Direct sample snooping device
dsnoop:CARD=Loopback,DEV=1
hw:CARD=Loopback,DEV=0
Direct hardware device without any conversions
hw:CARD=Loopback,DEV=1
plughw:CARD=Loopback,DEV=0
Hardware device with all software conversions
plughw:CARD=Loopback,DEV=1
usbstream:CARD=Loopback
Loopback
USB Stream Output
sysdefault:CARD=rockchiprk3308a
rockchip,rk3308-acodec,
dmix:CARD=rockchiprk3308a,DEV=0
dsnoop:CARD=rockchiprk3308a,DEV=0
hw:CARD=rockchiprk3308a,DEV=0
plughw:CARD=rockchiprk3308a,DEV=0
usbstream:CARD=rockchiprk3308a
USB Stream Output
rock@rockpis:~$ cat /etc/asound.conf
pcm.!default {
        type hw
        card 1
ctl.!default {
        type hw
        card 1
Also I do some things from:
https://forum.radxa.com/t/audio-support-rock-pi-s/1686/43
What I can do to play music from 3,5mm jack connector?
Best regards,
Jan
