Rock Pi N10 model C only show 3GB for CPU memory
Recently bought a Rock Pi N10 model C and expected to see 4GB memory for CPU and 4GB memory for NPU, but when I run “free -m” or “top” and all show only has 2.99GB (3GB) total memory. Does any one encounter the same issue? How to fix it? By the way is there a cmd to check NPU memory size?
I installed debian buster for my unit on a microSD card. Am I missing something? Please help.
Thank you.
Mine looks right (4GB)
rock@rockpin10:~$ cat /etc/os-release
NAME=“Ubuntu”
VERSION=“18.04 LTS (Bionic Beaver)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 18.04 LTS”
VERSION_ID=“18.04”
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
rock@rockpin10:~$ free -m
total used free shared buff/cache available
Mem: 3808 66 1965 32 1776 3680
Swap: 0 0 0
rock@rockpin10:~$ uname -a
Linux rockpin10 4.4.167-8-rockchip-g1175e66f8e9a #1 SMP Thu Mar 5 08:40:28 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
Note the cma-reserved/reserved:
[ 0.000000] Memory: 3630808K/4061184K available (13054K kernel code, 1586K rwdata, 4580K rodata, 1152K init, 2107K bss, 168232K reserved, 262144K cma-reserved)
@heitbaum
Thank you for your information.
My installation is:
PRETTY_NAME=“Debian GNU/Linux 10 (buster)”
NAME=“Debian GNU/Linux”
VERSION_ID=“10”
VERSION=“10 (buster)”
VERSION_CODENAME=buster
ID=debian
HOME_URL=“https://www.debian.org/
SUPPORT_URL=“https://www.debian.org/support
BUG_REPORT_URL=“https://bugs.debian.org/
Questions:
  1. do you think because of debian limited to 3GB? (very unlikely, right?)
  2. when I type “uname -a”, the cma-reserved info did not show up and only show up:
rock@rockpin10bc:~/rk3399pro$ uname -a
Linux rockpin10bc 4.4.167-14-rockchip-g53bdb2fa44e8 #1 SMP Fri May 22 09:11:08 UTC 2020 aarch64 GNU/Linux
What cmd should I type to see the NPU memory? or which file I should cat to see the cma-reserved info?
  1. where did you install your OS: microSD card? or eMMC? (would this matter?)
Thanks a lot for your help.
For the cma - run the following: dmesg | grew cma
Maybe also dmesg | pastebinit and share the url.
I would think Debian would support the whole 4GB. Is your N10 a B series maybe?
I did the sd card boot first, and then replaced the eMMC image with the downloaded file from dl.radxa.com using dd if=xxxx of=/dev/mmcXXX
I think you bought from allnet which advertised 5 GB RAM.
Seeedstudio said it only 3GB for CPU RAM and 1 GB for NPU RAM
@heitbaum
Yes, it is confirmed by the vendor somehow they mislabeled my unit as Model C but indeed the memory configuration shows it is Model B instead. I already requested for either to refund or replace my unit with a real Model C unit. A bit of confusing…
