Wifi disables itself after some time and the Bluetooth doesn’t work at all.
I also need to disable bluetooth scanning or this message will pop-up and disappear in a split second saying that bluetooth stopped working.
Its good to report more information when you report an error, eg what OS/desktop environment you are using.
It could be that power management is disabling your wifi/bluetooth to save power. If you don’t care abou the tiny power saving, you could install tlp
On ArchLinux or Manjaro, this is done with:
pacman -S tlp
systemctl enable --now tlp
My /etc/tlp.conf (optimised for performance, not power saving. Read the comments in that config file, some settings mean the opposite of what they sound like):
TLP_DEFAULT_MODE=AC
TLP_PERSISTENT_DEFAULT=1
CPU_SCALING_GOVERNOR_ON_AC=performance
CPU_SCALING_GOVERNOR_ON_BAT=performance
PLATFORM_PROFILE_ON_AC=performance
PLATFORM_PROFILE_ON_BAT=performance
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=off
SOUND_POWER_SAVE_CONTROLLER=N
PCIE_ASPM_ON_AC=performance
USB_AUTOSUSPEND=0
USB_EXCLUDE_AUDIO=1
USB_EXCLUDE_BTUSB=1
DEVICES_TO_ENABLE_ON_STARTUP=“wifi bluetooth”
DEVICES_TO_ENABLE_ON_AC=“wifi bluetooth”
I’m using Android 11 official radxa image. Also how do I disable the serial console? It says it on and impacting performance in the notification tab. I also get a “bluetooth keeps stopping” error message that pops up and disappears quickly when I have bluetooth scanning turned on. The bluetooth stops working after the first restart on a fresh image flash.
Hi Reclusive,
Sorry I aasumed you were using linux. I don’t know if tlp works on Android.
When you have a different question, you should post it seperately. Forums become impossible to use when the answer to the original question is buried amongst unrelated stuff ![]()
have you solved this ? i have exactly the same issue…offical android 11 on rock pi4c+ : wifi keep disconnecting after a while
Hi, I also have the same issue. Did you guys find a solution ?
Hi there,
Is there anybody that solved this problem?
I have it to on my official Radxa Android version.
Did anyone find a fix for the Bluetooth problem.
After fresh flash it works, after the first reboot it stops working.
