Source based Linux distribution CRUX-ARM adhering to ideology keep it simple, has its own package system, also supports the port system.
the image building system now supports slaсkwarearm, slarm64, crux-arm
crux-arm-3.6-aarch64-core-rock_pi_e-5.12.6-build-20210526.img.zst
crux-arm-3.6-aarch64-core-rock_pi_e-5.12.6-build-20210526.img.zst.sha256
<debug_uart>
U-Boot TPL 2021.04-rk3328 (May 26 2021 - 10:25:37)
DDR3, 333MHz
BW=32 Col=10 Bk=8 CS0 Row=14 CS=1 Die BW=16 Size=512MB
Trying to boot from BOOTROM
Returning to boot ROM...
<debug_uart>
U-Boot SPL 2021.04-rk3328 (May 26 2021 - 10:25:37 +0300)
Trying to boot from MMC1
NOTICE: BL31: v2.5(release):v2.5-dirty
NOTICE: BL31: Built : 10:24:33, May 26 2021
NOTICE: BL31:Rockchip release version: v1.2
U-Boot 2021.04-rk3328 (May 26 2021 - 10:28:03 +0300)
Model: Radxa Rockpi E
DRAM: 510 MiB
PMIC: RK8050 (on=0x40, off=0x00)
MMC: mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
Net: eth0: ethernet@ff540000
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
1689 bytes read in 4 ms (412.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
54 bytes read in 3 ms (17.6 KiB/s)
52487 bytes read in 8 ms (6.3 MiB/s)
28723712 bytes read in 1248 ms (21.9 MiB/s)
libfdt fdt_path_offset() returned FDT_ERR_NOTFOUND
Failed to load '/boot/uInitrd'
Moving Image from 0x2080000 to 0x2200000, end=3e00000
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Device Tree to 000000001deba000, end 000000001df2ffff ... OK
Starting kernel ...
[ 2.885856] gpio-syscon ff100000.syscon:grf-gpio: can't read the data register offset!
[ 3.267430] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
[ 3.728531] rk_gmac-dwmac ff550000.ethernet: Can not read property: tx_delay.
[ 3.729214] rk_gmac-dwmac ff550000.ethernet: set tx_delay to 0x30
[ 3.729788] rk_gmac-dwmac ff550000.ethernet: Can not read property: rx_delay.
[ 3.730430] rk_gmac-dwmac ff550000.ethernet: set rx_delay to 0x10
[ 3.731104] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_refout
[ 3.731926] rk_gmac-dwmac ff550000.ethernet: cannot get clock clk_mac_speed
CRUX-ARM 64b (rock-pi-e) (ttyS2)
rock-pi-e login: root
You are required to change your password immediately (administrator enforced).
New password:
Retype new password:
___ ___ _ _ _ _ ___ ___ ___ _____
| _|| _|| | ||_'_||___|| .'|| _|| |
|___||_| |___||_,_| |__,||_| |_|_|_|
_ _
___ ___ ___ | |_ ___ |_| ___
| _|| . || _|| '_| | . || | | -_|
|_| |___||___||_,_| | _||_| |___|
|_|
