Rock Pi E cases
I wanted to provide links to cases found:
  1. case by DinikS
    https://www.thingiverse.com/thing:4943843
  2. KKSB Steel Case
    KKSB Rock Pi E Case - Radxa ROCK Metal Enclosure — KKSB Cases
  3. Case by targeted (Hinge on I/O port)
    https://thangs.com/designer/targeted/3d-model/ROCK%20Pi%20E%20Single%20Board%20Computer%20Case-205683
  4. my own case supporting my DC/RS-232 Hat
    https://www.thingiverse.com/thing:5662300
Here is a variant with a DIN rail bracket (STL for my DC/RS-232 hat or without)
  1. Rock Pi E Developers package
    Rock Pi E Developers package – ALLNET China
  2. ALLNet ABS Case
    https://shop.allnet.de/detail/index/sArticle/347968/sCategory/3776
  3. Not a RockPi E case sofar…
    But a cool tool to create cases
    (Maybee one might be able to extend this for RockPi E ?)
    GitHub - hominoids/SBC_Case_Builder: Autonomous SBC case generation using SBC Model Framework
  4. ecoPI E housing (AllNet)
    Powder coated aluminium with WiFi socket.
    Could be large enough for PoE
    (not tried, but outer height is 33,5mm; mine is 28mm(inner height about 23mm)
Do any of these cases have room for the RockPi-E PoE HAT?
Hi Mr.X,
Not yet tried but my own (the orange blue 3D printed) have space for a board I made
(2x RS232 and 24V DC input) - which is mounted very much like the Radxa PoE board.
(probably only needs trimming the stacking pins on the top)
I just have ordered 3 PoE Boards from AllNet. Will have them in house next few days and
will provide you further feedback…
Kind Greetings,
Marcovaldo
The original diniks case I have remixed should work too
Anyone tried this case from AllNet?
Thx for hint! I have added it to the above gallery…
Does it look like the Allnet case would fit the PoE module?
Just wanted to get one (its the lowest price case around I think) - but it is sold out.
Anyway will get 3 PoE hats next week and will report back in the above overview which
of the cases support PoE (I can test my 3D printed = ident with DinikS; also I have the KKSB one)
Greetings, M.
I am happy to support this as the Rock Pi E is a valuable platform for me, and the more
are using it - the longer it will be available (anyway all statements from Radxa and Distris
were stating long term availability more than fit for industrial use)
I like especially the low power passive cooling features
Its low power / not too high clock rate also make it easy to stay within CE/UKCA and other EMI standards.
If any of you has ideas for ‘nice to have’ interfaces/hats , please let me know. maybee I can combine it
with what is in the pipeline allready here.
Unfortunately I received weong PoE Hats (box was marked OK, but inside was Rock-PI 4 PoE.
Will have to further wait or get them elsewhere…
Hi All,
Today I received the PoE Hats for RockPi E.
They do NOT fit to my 3DP Cases and probably not to some of the others,
as the PCB size of the PoE Hat exceeds the size of the RockPi E
by 4mm in total (length).
I will make a modified 3DP case that allows for the use of the official PoE
Hat.
Possibly there is also the opportunity to use a poor man’s PoE circuit.
(my RS-232 / 24V DC Hat has a DC/DC converter on it)
I will investigate…
Greetings,
   Marcovaldo
also the transformator of the PoE hat collides a litte bit with the glue on top heatsink I normally
glue on the SOC (they touch and prevent the hexbolts to sit properly on the RochPi E PCB.
a gap between 0.5 and 1mm stays (no mayor issue)
Thank you for reporting back.
Disappointing that they don’t make a case that fits the PoE module (or a module that fits their PoE)
Not sure if I am designing a passive PoE. To my experience the Rock Pi E normally needs much less
power than specified (The low power/passive cooling/low EMI are thepoints I love this board for.
I have allready done a 24V DC in / Dual RS232 board for Rock Pi E, so I have a board outline,
connector position etc. allready - and might extend this to optionally use passive PoE
like many of the cheaper Ethernet cameray, or WiFi APs…
I have made a variant of the orange blue case above with a hole for a RPSMA socket above the SD slot. STL on request
