I have bought a few rockpi-4c-plus. In one of those, the upper USB port is not working. I have tried swapping sd-card from another rock-pi-4c-plus but still not working.
I suspect a hardware fault since any software /configuration issue should have been solved by swapping sd card from the working piece, How can I troubleshoot it and is there any to get it working?
it is not working, I get permisssion error. I run the command as sudo user. Also I have tried modifying dtb but no use,
The link that you have sent is working in other rock-pi-4c-plus I have. I have around 10 rockpi-4c-plus. Only one is having this issue, I have also tried using the sd card from anoher working rocpi-4c-plus. But it did not work.
It stopped working again on that particular piece only @RadxaYuntian. This time it is not working after having it powered down and then power up again after sometime.
Also when connecting and disconnecting something on that port , there are no messages at all when checked using sudo dmesg.
The hardware switch was removed since the 4C+ should fit some Raspberry Pi 4B cases without the switch exported, we use software Host/Device control instead.
