Rock Pi 4B+ v1.73
Followed this guide https://wiki.radxa.com/Rockpi4/install/eMMC
Was able to boot from uSD with both Ubuntu server 20.04 & Debian. Tried to dd to the emmc -> unplug -> remove uSD. Plug back in. Board shows solid green light. No blue light flashing. Screen does not show up. Does not boot from the emmc. Don’t know how to tell if this board has SPI and that is causing the issue or not. I have not tried connecting pin 23 & 25. I tried to connect the USB TTL serial cable to see logs but it is not working correctly either.
Any help would be greatly appreciated.
Also, when I plug the uSD back in it no longer shows the screen. See blue light flashing but no picture. Have to reflash the uSD then it works again.
Edit: Checked the purchase, looks like the board should have SPI flash (https://shop.allnetchina.cn/collections/frontpage/products/rock-pi-4-model-b-board-only-2-4-5ghz-wlan-bluetooth-5-0?variant=39284740685926). I guess i’ll have to wait for the connectors to show up to disable pin 23 & 25
