Rock Pi 4B plus Penta hat
Was ok. Had mdadm RAID-5 created, and samba configured, all seemed fine, and it used to reboot just fine. I powered it down so that I could move it and cable to LAN, but now it takes several minutes to boot, and when it does the drives /dev/sda b c d are all missing and thus of course also /dev/md1. Oddly the Penta hat display had stopped working too. So, I reinstalled the Penta hat integration, and rebooted again, and now the hat display is working, but still no SATA drives visible.
here’s a filtered output from dmesg:
root@rock:/home/rock# dmesg | egrep -i “error|fail|seve|crit”
[ 0.000000] Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x0000000000000000, size 0 MiB
[ 1.767683] phy phy-ff770000.syscon:usb2-phy@e450.1: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 1.767915] phy phy-ff770000.syscon:usb2-phy@e450.1: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e450/otg-port failed
[ 1.767927] phy phy-ff770000.syscon:usb2-phy@e450.1: Failed to get VBUS supply regulator
[ 1.769718] phy phy-ff770000.syscon:usb2-phy@e460.3: Looking up phy-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[ 1.769948] phy phy-ff770000.syscon:usb2-phy@e460.3: Looking up vbus-supply property in node /syscon@ff770000/usb2-phy@e460/otg-port failed
[ 1.769960] phy phy-ff770000.syscon:usb2-phy@e460.3: Failed to get VBUS supply regulator
[ 1.771838] phy phy-ff770000.syscon:phy@f780.4: Looking up phy-supply property in node /syscon@ff770000/phy@f780 failed
[ 1.772597] phy phy-ff7c0000.phy.5: Looking up phy-supply property in node /phy@ff7c0000/dp-port failed
[ 1.772703] phy phy-ff7c0000.phy.6: Looking up phy-supply property in node /phy@ff7c0000/usb3-port failed
[ 1.773181] phy phy-ff800000.phy.7: Looking up phy-supply property in node /phy@ff800000/dp-port failed
[ 1.773288] phy phy-ff800000.phy.8: Looking up phy-supply property in node /phy@ff800000/usb3-port failed
[ 1.773646] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[ 1.775806] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed
[ 1.776391] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 1.776970] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 2.301977] rockchip-pcie: probe of f8000000.pcie failed with error -110
[ 2.303684] rk-vcodec ff650000.vpu_service: Looking up vcodec-supply property in node /vpu_service@ff650000 failed
[ 2.308278] rk-vcodec ff660000.rkvdec: Looking up vcodec-supply property in node /rkvdec@ff660000 failed
[ 2.318196] pwm-regulator vdd-log: lookup for GPIO enable failed
[ 2.318228] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 2.318443] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 2.318516] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 2.331393] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[ 2.336413] rockchip-drm display-subsystem: failed to parse loader memory
[ 2.367438] mali ff9a0000.gpu: Failed to get regulator
[ 2.367896] mali ff9a0000.gpu: Power control initialization failed
[ 2.487190] rockchip-dwc3 usb0: fail to get drvdata hcd
[ 3.130436] rockchip-dwc3 usb1: fail to get drvdata hcd
[ 3.316122] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.320124] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.325055] rk808 0-001b: lookup for GPIO dvs failed
[ 3.325693] rk808 0-001b: lookup for GPIO dvs failed
[ 3.327574] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.328666] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.329479] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.330454] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.332119] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.333637] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.335154] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.336676] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.338199] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.339724] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.341277] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.342825] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.343691] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.344554] pwm-regulator vdd-log: Looking up pwm-supply property in node /vdd-log failed
[ 3.391032] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 3.391086] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 3.392282] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 3.396128] dwmmc_rockchip fe320000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe320000 failed
[ 3.396869] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO cd failed
[ 3.396934] dwmmc_rockchip fe320000.dwmmc: lookup for GPIO wp failed
[ 3.432549] sdhci-arasan fe330000.sdhci: lookup for GPIO wp failed
[ 3.433688] sdhci-arasan fe330000.sdhci: Looking up vmmc-supply property in node /sdhci@fe330000 failed
[ 3.433730] sdhci-arasan fe330000.sdhci: Looking up vqmmc-supply property in node /sdhci@fe330000 failed
[ 3.482845] rockchip-saradc ff100000.saradc: Looking up vref-supply property in node /saradc@ff100000 failed
[ 3.859666] dwmmc_rockchip fe310000.dwmmc: Looking up vmmc-supply property in node /dwmmc@fe310000 failed
[ 3.859707] dwmmc_rockchip fe310000.dwmmc: Looking up vqmmc-supply property in node /dwmmc@fe310000 failed
[ 3.860870] dwmmc_rockchip fe310000.dwmmc: lookup for GPIO wp failed
[ 4.031572] asoc-simple-card es8316-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[ 4.033034] asoc-simple-card es8316-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[ 4.034319] es8316 1-0011: ASoC: Failed to create Left Hp mixer debugfs file
[ 4.034965] es8316 1-0011: ASoC: Failed to create Right Hp mixer debugfs file
[ 4.035642] es8316 1-0011: ASoC: Failed to create HPCP L debugfs file
[ 4.036237] es8316 1-0011: ASoC: Failed to create HPCP R debugfs file
[ 4.036853] es8316 1-0011: ASoC: Failed to create HPVOL L debugfs file
[ 4.037552] es8316 1-0011: ASoC: Failed to create HPVOL R debugfs file
[ 6.298217] CFG80211-ERROR) wl_setup_wiphy : Registering Vendor80211
[ 6.303605] CFG80211-ERROR) wl_init_prof : wl_init_prof: No profile
[ 186.105980] ttyS0 - failed to request DMA, use interrupt mode
[ 187.265010] Disable tdls_auto_op failed. -1
[ 187.297529] dhd_preinit_ioctls Set scancache failed -23
[ 187.331743] CFG80211-ERROR) wl_cfg80211_event : Event handler is not created
[ 187.332908] dhd_preinit_ioctls failed to set ShubHub disable
[ 187.334770] dhd_wl_ioctl_get_intiovar: get int iovar wnm_bsstrans_resp failed, ERR -23
[ 187.334775] failed to get wnm_bsstrans_resp
[ 187.335429] failed to set WNM capabilities
Is there anyone here who might be able to help?
