[rock pi 4b] Debian Can't show boot logo?
ERROR: Can’t find file:logo.bmp failed to display uboot logo
Is it caused by lack of logo.img?
What is the solution?
Thanks!
DDR Version 1.20 20190314
In
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x38
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x38
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x38
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0xB8
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x38
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 249
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=30436MB
FwPartOffset=2000 , 0
StorageInit ok = 56013
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT part: 0, name: loader1, start:0x40, size:0x1f40
GPT part: 1, name: loader2, start:0x4000, size:0x2000
GPT part: 2, name: trust, start:0x6000, size:0x2000
GPT part: 3, name: boot, start:0x8000, size:0x100000
GPT part: 4, name: rootfs, start:0x108000, size:0x3a69c60
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
Load OK, addr=0x200000, size=0xf1b44
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):0e7a845
NOTICE: BL31: Built : 16:13:46, Apr 17 2019
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-00026-g2431fa34678 (Feb 14 2022 - 21:41:40 +0800)
Model: Radxa ROCK Pi 4B
PreSerial: 2
DRAM: 3.9 GiB
Relocation Offset is: f5bdd000
Sysmem: init
I2c speed: 400000Hz
PMIC: RK808
vdd_center 900000 uV
vdd_cpu_l 900000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
Bootdev(atags): mmc 1
PartType: EFI
get part misc fail -1
boot mode: None
init_resource_list: failed to get resource part, ret=-1
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: eth0: ethernet@fe300000
Hit key to stop autoboot(‘CTRL+C’): 1 0
Here trying to boot from nvme
dcache off
Device 0: unknown device
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:4…
Found /extlinux/extlinux.conf
pxefile_addr_str = 0x00500000
bootfile = /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
423 bytes read in 5 ms (82 KiB/s)
select kernel
1: kernel-4.4.154-116-rockchip-g86a614bc15b3
Enter choice: Retrieving file: /hw_intfc.conf
reading /hw_intfc.conf
1970 bytes read in 4 ms (480.5 KiB/s)
dtoverlay number: 0, name:/overlays/console-on-ttyS2.dtbo
hw_conf.valid = 1
hw_conf.pwm0 = 0
hw_conf.pwm1 = 0
hw_conf.uart2 = 0
hw_conf.uart4 = 0
hw_conf.spi1 = 0
hw_conf.spi2 = 0
hw_conf.i2c2 = 0
hw_conf.i2c6 = 0
hw_conf.i2c7 = 0
hw_conf.dts_overlay_count = 1
hw_conf.dts_overlay[0] = /overlays/console-on-ttyS2.dtbo
Retrieving file: /initrd.img-4.4.154-116-rockchip-g86a614bc15b3
reading /initrd.img-4.4.154-116-rockchip-g86a614bc15b3
5567262 bytes read in 240 ms (22.1 MiB/s)
Retrieving file: /vmlinuz-4.4.154-116-rockchip-g86a614bc15b3
reading /vmlinuz-4.4.154-116-rockchip-g86a614bc15b3
20371464 bytes read in 870 ms (22.3 MiB/s)
append: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init rootfstype=ext4 rootwait root=UUID=6f416e7f-40c4-41df-a2f2-e6cdca370b34 console=ttyS2,1500000n8
Retrieving file: /dtbs/4.4.154-116-rockchip-g86a614bc15b3/rockchip/rk3399-rock-pi-4b.dtb
reading /dtbs/4.4.154-116-rockchip-g86a614bc15b3/rockchip/rk3399-rock-pi-4b.dtb
94557 bytes read in 17 ms (5.3 MiB/s)
fdt addr 0000000008300000
fdt magic number edfe0dd0
fdt size 1048576
merge_dts_overlay
Retrieving file: /overlays/console-on-ttyS2.dtbo
reading /overlays/console-on-ttyS2.dtbo
774 bytes read in 5 ms (150.4 KiB/s)
overlay dtb(0x0000000008200000) is valid
fdt_overlay_apply 0000000008300000 0000000008200000
Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
Loading Ramdisk to e9874000, end e9dc331e … OK
Loading Device Tree to 00000000e9771000, end 00000000e9873fff … OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 8787.193 ms
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.154-116-rockchip-g86a614bc15b3 (stephen@lara) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-6ubuntu2) ) #1 SMP Mon Jan 10 12:03:08 UTC 2022
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Reserved memory: failed to reserve memory for node ‘drm-logo@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
