Rock Pi 4B 4 GB RAM - benchmarks
Hello guys,
I’ve made some benchmarks. Earlier (2018) Rock Pi was only with small heatsink (1cm x 1cm) and tiny fan (25 mm). Today’s test (2021) is with dedicated heatsink (the big one!) and a 50 mm fan.
See results below. There is performance increase! 7-Zip has changed so it may be not the same code.
2018:
2018-12-18
$ stress-ng --cpu 1 --cpu-method matrixprod --metrics-brief -t 60
stress-ng: info:  [1125] dispatching hogs: 1 cpu
stress-ng: info:  [1125] cache allocate: using built-in defaults as unable to determine cache details
stress-ng: info:  [1125] successful run completed in 60.22s (1 min, 0.22 secs)
stress-ng: info:  [1125] stressor       bogo ops real time  usr time  sys time   bogo ops/s   bogo ops/s
stress-ng: info:  [1125]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: info:  [1125] cpu                 253     60.22     60.19      0.00         4.20         4.20
$ stress-ng --cpu 6 --cpu-method matrixprod --metrics-brief -t 60
stress-ng: info:  [1147] dispatching hogs: 6 cpu
stress-ng: info:  [1147] cache allocate: using built-in defaults as unable to determine cache details
stress-ng: info:  [1147] successful run completed in 60.30s (1 min, 0.30 secs)
stress-ng: info:  [1147] stressor       bogo ops real time  usr time  sys time   bogo ops/s   bogo ops/s
stress-ng: info:  [1147]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: info:  [1147] cpu                 793     60.20    359.21      0.08        13.17         2.21
$ sysbench --test=cpu --cpu-max-prime=20000 --num-threads=1 --max-time=60 run
WARNING: the --test option is deprecated. You can pass a script name or path on the command line without any options.
WARNING: --max-time is deprecated, use --time instead
sysbench 1.0.11 (using system LuaJIT 2.1.0-beta3)
Running the test with following options:
Number of threads: 1
Initializing random number generator from current time
Prime numbers limit: 20000
Initializing worker threads...
Threads started!
CPU speed:
    events per second:   701.24
General statistics:
    total time:                          60.0014s
    total number of events:              42084
Latency (ms):
         min:                                  1.42
         avg:                                  1.42
         max:                                  6.72
         95th percentile:                      1.42
         sum:                              59964.36
Threads fairness:
    events (avg/stddev):           42084.0000/0.00
    execution time (avg/stddev):   59.9644/0.00
$ sysbench --test=cpu --cpu-max-prime=20000 --num-threads=6 --max-time=60 run
WARNING: --num-threads is deprecated, use --threads instead
Number of threads: 6
Threads started!
CPU speed:
    events per second:  2237.70
General statistics:
    total time:                          60.0024s
    total number of events:              134280
Latency (ms):
         min:                                  1.42
         avg:                                  2.68
         max:                                 22.67
         95th percentile:                      3.62
         sum:                             359842.66
Threads fairness:
    events (avg/stddev):           22380.0000/8091.23
    execution time (avg/stddev):   59.9738/0.01
$ 7z b
7-Zip [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=pl_PL.UTF-8,Utf16=on,HugeFiles=on,64 bits,6 CPUs LE)
LE
CPU Freq:  1064   979   894  1260  1651  1792  1792  1792  1792
RAM size:    3812 MB,  # CPU hardware threads:   6
RAM usage:   1323 MB,  # Benchmark threads:      6
                       Compressing  |                  Decompressing
Dict     Speed Usage    R/U Rating  |      Speed Usage    R/U Rating
         KiB/s     %   MIPS   MIPS  |      KiB/s     %   MIPS   MIPS
22:       4218   478    858   4104  |      92601   523   1509   7897
23:       4035   494    833   4112  |      87611   544   1394   7581
24:       3793   516    791   4079  |      84930   564   1323   7455
25:       3592   530    774   4102  |      81479   586   1237   7251
Avr:             504    814   4099  |              554   1365   7546
Tot:             529   1090   5823
2021:
2021-11-25
stress-ng: info:  [2154] dispatching hogs: 1 cpu
stress-ng: info:  [2154] successful run completed in 60.09s (1 min, 0.09 secs)
stress-ng: info:  [2154] stressor       bogo ops real time  usr time  sys time   bogo ops/s   bogo ops/s
stress-ng: info:  [2154]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: info:  [2154] cpu                 264     60.09     60.07      0.00         4.39         4.39
stress-ng: info:  [2105] dispatching hogs: 6 cpu
stress-ng: info:  [2105] successful run completed in 60.23s (1 min, 0.23 secs)
stress-ng: info:  [2105] stressor       bogo ops real time  usr time  sys time   bogo ops/s   bogo ops/s
stress-ng: info:  [2105]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: info:  [2105] cpu                 935     60.14    354.24      0.03        15.55         2.64
sysbench 1.0.18 (using system LuaJIT 2.1.0-beta3)
Threads started!
CPU speed:
    events per second:   704.18
General statistics:
    total time:                          60.0011s
    total number of events:              42254
Latency (ms):
         min:                                    1.42
         avg:                                    1.42
         max:                                    3.18
         sum:                                59965.61
Threads fairness:
    events (avg/stddev):           42254.0000/0.00
    execution time (avg/stddev):   59.9656/0.00
Threads started!
CPU speed:
    events per second:  2470.14
General statistics:
    total time:                          60.0017s
    total number of events:              148219
Latency (ms):
         min:                                    1.41
         avg:                                    2.43
         max:                                   34.67
         95th percentile:                        3.55
         sum:                               359831.26
Threads fairness:
    events (avg/stddev):           24703.1667/7799.87
    execution time (avg/stddev):   59.9719/0.01
$ 7z b
7-Zip (z) 21.03 beta (arm64) : Copyright (c) 1999-2021 Igor Pavlov : 2021-07-20
 64-bit arm_v:8 locale=pl_PL.UTF-8 Threads:6, ASM
Compiler: 9.2.1 20191025 GCC 9.2.1
Linux : 4.4.154-113-rockchip-gdb9dfc2cdd25 : #1 SMP Sat Aug 14 09:26:12 UTC 2021 : aarch64
PageSize:4KB hwcap:FF:CRC32:SHA1:SHA2:AES:ASIMD
LE
1T CPU Freq (MHz):   935  1301  1699  1797  1797  1797  1797
3T CPU Freq (MHz): 259% 1425   258% 1438
RAM size:    3811 MB,  # CPU hardware threads:   6
RAM usage:   1334 MB,  # Benchmark threads:      6
22:       5437   531    995   5290  |     130294   492   2256  11109
23:       5187   540    978   5286  |     129758   509   2205  11225
24:       4604   509    973   4951  |     125405   506   2174  11004
25:       4749   555    977   5422  |     121866   514   2108  10845
Avr:      4994   534    980   5237  |     126831   505   2185  11046
Tot:             520   1583   8142
