Hi all,
Im using Android 9 tablet version on rock pi 4B. Audio output is perfectly fine, but microphone is not working. I’m sure that my headphone is 4pin connector.
Any idea?
Thanks.
Hi all,
Any idea?
Thanks.
Hi, @ryan.low, I am facing the same problem here… Were you able to solve it? Could you get a bluetooth device to work instead?
Hi @ryan.low @King_Aslan were you guys able to solve this issue? I’m also facing the same issue. Onboard microphone, 3.5mm audio IN, Bluetooth microphone none of the 3 are working.
Hi, I`ve the same problem. Android 9 is installed and tried to connect a mini mic via usb. at sound recorder it’s not detected. also at Skype it’s not working. Yet I didn’t try out audio jack…
Hello, @ryan.low. I had a similar issue on rock pi 4c. Have you tried opening alsamixer and changing differential mux parameter from lin1-rin1 to lin2-rin2?
Hello @kultzak I am having the same problem with 4C with Ubuntu. Can you please share the solution with me as I’m trying to solve this issue for a long time?
With alsamixer I’m not getting the CHIP selected and no MIC option below to set. Please see the image attached below.
Have you solved this problem? I I have the same problem.
Hi I have this problem with a ROCK 4C+. The mic is an electret type with the 4 pole 3.5mm jack, that is recognised and works on my Linux Mint PC. I have fiddled with amixer but I cannot see the mic under Input Devices. I used to have this working on a ROCK 4 SE, but now that is behaving the same way. I have done an upgrade and am on Debian Bullseye 4.4. Any bright ideas?
