I have a rock pi 4 with a POE hat and the heatsink that goes underneath. I just plugged it into my kubernetes cluster and I noticed that services running on it seem to be gone after 20 or 30 mins. Thats when I noticed that the rock pi 4 board reboots by itself. Any idea about this ? Should I send it back ?
What about hiring someone to reason / debug the problem? I don’t (have) power via POE Hat but otherwise boards are not rebooting for no reason or act strange. In most cases software can fix things … unless design is failed beyond repair.
I ran an extreme stress testing session with Rockpi and … no problems:
https://dl.armbian.com/_test-reports/2020-06-22_18.40.37.html
Which poe hat are you using? Is your poe switch 802.3at or 802.3af? For 802.3af, 13W is not enough for ROCK Pi 4.
From my POE switch specification:
IEEE 802.3at Power over Ethernet (PoE+)
Provides up to 30 W per port, which allows support of the latest PoE+ capable devices such
as IP phones, wireless Access Points, and security cameras, as well as any IEEE 802.3af
compliant end device; reduces the cost of additional electrical cabling and circuits that would
otherwise be necessary in IP phone and WLAN deployments (Models: JH019A, JH328A,
JH330A)
I also updated the OS with armbian and a linux kernel 5. Seems to be running smoothly now. I ll let you know how it goes.
