Vitaly
September 3, 2019, 11:33am
1
Description of the problem:
We have two singleboard computers RockPI 4A v1.4 and RockPI 4B v1.3
While working with RockPI 4B 1.3, a problem was detected with the RTC real-time clock. If you connect the battery to RTC, the time is not saved after a rebooting.
Example:
sudo date –set “2019-08-08 12:00:00”
sudo hwclock –r
“2013-06-06 9:05:23”
sudo hwclock -w
sudo hwclock –r
“2019-08-08 12:00:23”
sudo reboot
sudo hwclock –r
This problem does not repeat on RockPI 4A v1.4, the clock remains synchronized even after a long power outage.
The situation was checked with three distribitivs: Ubuntu Server 18.04, Armbian Bionic, Debian 9
Please, help us with the solving of the problem
jack
September 3, 2019, 1:01pm
2
Hi, Vitaly
RTC should work on both v1.3 and v1.4 boards. The following command works fine here with RTC battery attached:
date -s 20190909
hwclock -w
Power off the board and remove the power adapter. Wait for some minutes, power on
hwclock -r
The date is still 20190909.
If you have issue with RTC time, maybe it’s a hardware issue, the battery connector is somehow defective.
Check also:
Real Time Clock (RTC)
RTC alarm:
Does the rtc on rockpi4 support wakealarms - #2 by jack
Vitaly
September 4, 2019, 7:59am
3
Hi, jack
We have tried this scenario on RockPI 4B 1.3.
hwclock -r
2013-01-18 12:56:37.713703+0400
date -s 20190904
Wed Sep 4 00:00:00 MSK 2019
hwclock -w
Then power off for two minutes. After boot:
hwclock -r
2013-01-18 12:51:06.312073+0400
The very same SD card with OS image and same RTC battery works fine on Rock PI 4A 1.4.
jack
September 4, 2019, 11:36am
4
It seems there is some hardware issue with your rock pi 4b v1.3. You can try to measure the voltage of RTC connector 2 pins. If you are not familiar with hardware, just ask for a RMA with the distributor.
Vitaly
September 4, 2019, 1:56pm
5
Thank you, jack!
It was hardware issue. One pin was poorly soldered.
